Project ssm ua6 brembo swap begins
2009 g37s 6mt
http://webmail.aol.com/41095/aol/en-....jpg:thumbsup:
stripped and painted, awaiting stencil kit and pads, lines, rotors.
Purchased from stillhere153 in great condition, 16k on them.
sanded, 2 coats primer, 5 coats duplicolor high temp paint and going to clearcoat after brembo stencil. Got some stoptechs slotted to go with em.
94 DC4 RS LSV/Turbo
I am confused what ur plans are jo... you were supposed to paint the flat area white, apply the stencil, then spray it all red.... unless you will be placing the stencil under the clear coat... which would also be perfect
94 DC4 RS LSV/Turbo
I told jo to have him make him a backup set which I will send out to richie v6 to mass produce
havent spoken to richie about it, but sure it wont be a problem
New shoes on my
The method you're using sounds fine, but for anyone in the future, it might actually be easier if you're putting lighter letter on a darker background (ie white letters on black calipers) to paint the caliper white with a few coats, then stick the letters on, then paint black a few coats, then peel the letters off and you'll have white letters on black calipers. Sometimes, painting white letters on a black or red base coat can come out with the letters being a tad tinted or dingy. You should layer darker colors on lighter colors. Lets say you're doing black letters on yellow calipers, then you'd definatly paint the yellow first, and make a stencil for the black.
I've never painted brake calipers though, just other things. I'm not saying my way is the right way, it's just another way.
That aside, looks sick! I want Brembos!
2009 g37s 6mt
