Precat Deletes + Upgraded Jpipe + No 3rd Cat + Stock Exhaust = very sexy exhaust note
Old 02-10-2009, 11:47 PM
  #41
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
put them on photobucket or something like that free webhost
Old 02-11-2009, 12:15 AM
  #42
acroNtypeS's Avatar
gotcha thanks!
Old 02-11-2009, 12:34 AM
  #43
acroNtypeS's Avatar
stock exhaust, atlpjpipe, richiesracepipe+precatdelete+injenintake
videos arent that good sorry about that hope u guys enjoy!
http://s479.photobucket.com/albums/r...t=P2100004.flv
http://s479.photobucket.com/albums/r...t=P2100005.flv
Old 02-11-2009, 12:37 AM
  #44
acroNtypeS's Avatar
This one put your speakers up cant really hear it
Old 02-11-2009, 01:50 AM
  #45
I have car ADD
BLACKURA_NY's Avatar
where on LI are ya? looks like the northern state parkway behind you... i think i've seen your car at LA fitness once or twice
Old 02-11-2009, 07:42 AM
  #46
practicing nihilist
NedShneebly's Avatar
acroNtypeS,
video's never fully tell the story as far as sound goes but I heard mostly intake with a bit of a growl, which is all I could hope for with all the RV6 products on stock exhaust. Maybe do a recording from inside the cabin with some rev's and WOT runs.
Old 02-11-2009, 09:46 AM
  #47
94 DC4 RS LSV/Turbo
stillhere153's Avatar
actually the neutral rev's was wat i was talking bout shit sounds straight fire
Old 02-11-2009, 10:07 AM
  #48
04 "NBP TL" 6mt
CHiNaMaN440's Avatar
That sounds really good. All I need now are precats to achieve that sound
Old 02-16-2009, 12:09 PM
  #49
All motor
Sonnick's Avatar
Yea that does sound good. I need PC deletes ugh
Where on LI are you? I'm off exit 37 on the LIE but am in the Amityville/Copiague area a lot too.
Old 02-16-2009, 12:11 PM
  #50
greco9885's Avatar
^I live in amityville and always around
Old 02-16-2009, 05:03 PM
  #51
All motor
Sonnick's Avatar
^^ Oh awesome. When I come home next we should meet up
Old 02-17-2009, 07:33 AM
  #52
practicing nihilist
done
Installed RV6 Triple Threat and UR Crank Pulley yesterday. Pre-cats/J-pipe/Test Pipe took about 3 1/2 - 4 hours with help of a rented lift, but I read a lot and had assembled tools days prior. Small, lady-like hands would have made half of this job much easier. O2 Sensor brackets and leads were not a fun way to start the job and the last reat cat heat shield bolt and wriggling that sucker out took a lot of attacks from the top and the bottom.
Crank pulley was much easier this time with the help of a 3 ft lead breaker bar (plus pulley tool). Only suck part of that was when the serpentine belt slipped off a couple pulleys and we sat there like a couple chimps trying to solve an algebra problem before some dude that is working on "putting a rear mounted turbo on a 3.5L TL" routed it in 2 seconds. Kid was totally full of crap but saved our butts.
By the way, never heard it mentioned but the weight savings of gutting the factory exhausts components is insane. After putting all the stock stuff back in the box of RV6 parts, I almost pulled a testicle not expecting how much heavier the box had become. The only heat shield involved with this job that I left on was the main exhaust shield that runs down the spine of the car.
Tone is perfect. Wife won't even notice but I hear the faintest growl when I press the angry pedal now. It's civil enough that I'm ready to straight pipe the 3rd muffler and factory resonator. There is some slight off idle rasp/drone and in the higher rpm it sounds like she's thank you for unlocking her inner demon. Can't say much about quickness yet since I had 200 lbs of parts and tools in my trunk but, a few blasts from rolling stop and I can feel her scrambling to keep my 245/35/19's planted. Very nice, Rich!
Old 02-17-2009, 07:41 AM
  #53
Under construction
alexSU's Avatar
Thanks for the pics and write up! Sounds like it was well worth the money and effort Enjoy it!
Old 02-17-2009, 07:56 AM
  #54
practicing nihilist
For the DIY'ers, heed Stillheres warning about sliding a piece of cardboard between the passenger fan and radiator. I did so without question and then saw exactly when I probably would have punched a hole right through that thing!
Also, I installed all the O2 sensors on the pre-cats before bolting them on to the manifold, except for the front lower sensor, which blocked us from snaking it into it's resting place.
Be patient with the all the sensor leads and jumper plugs. My pops and I have fat fingers and the little clip release levers are obviously made for another race of humans to manipulate. The jobs starts off smooth with basic removal of crap to get at the cats and then you start messing with all the electrical leads. Maybe their just my kryptonite, but I fricken hate these plugs and I have broken plenty in the past. And both of the upper O2 sensor jumper plugs *must* be removed from their bracket holding them in place before you can actually disconnect the lead. If you breezed over this line in the DIY, you could easily find yourself breaking out the blow torch to go midevil on a stupid plastic connector.
I'll post more pointers as I remember them.
Old 02-17-2009, 11:21 AM
  #55
acroNtypeS's Avatar
can u put up a sound clip very curious with the resonator 3rd cat.
Old 02-17-2009, 11:32 AM
  #56
Looks real GOOD. i still have mine sitting in the box rv6x3 and pulley. i'll get to it one day. i saw stillhere install acron precats and totally understand the cardboard as well. WELL NEEDED!!!
Good install. have fun!
Old 02-17-2009, 12:29 PM
  #57
Sandy Eggo
pffpffpass's Avatar
Heyyyy!! Ned!!
You installed the exact same thing I did!!! Cheater!!!
But I feel you on the plastic plugs that hold the o2 sensors.. NOT FUN.. but doable..
You will feel a big difference in about 200 miles or soo.. I didnt believe the hype about resetting the ECU.. But after 400 miles I can absolutely feel the difference between the first drive I took..
About Deleting the midmuff & Resonator I would not recommend it.. It produces a very noticable rasp from 2-3k which is VERY annoying.. I was kinda embarrassed it was so loud.. Thats what I had when I first installed my parts, then I traded another member for his stock exhaust and all rasp went away.. Now sounds just like your car I assume.. So if you want the sleeper look/sound stick with all stock exhaust for now..
I will until I get my ATLP base..
Old 02-17-2009, 02:08 PM
  #58
Under construction
alexSU's Avatar
Originally Posted by pffpffpass
Heyyyy!! Ned!!
I have that right now sometimes it is embarrassing cuz it sounds like you have a tin can instead of a real exhaust hopefully with a few more mods I can have it sounding deeper
Old 02-17-2009, 04:06 PM
  #59
practicing nihilist
I have a 2 year old and a 3 month, so won't promise anything soon but I'll try.
Heyyyy!! Ned!!
Pff, didn't you have an aftermarket exhaust at first? I'm thinking about straight piping the stock mid resonator and mid muff but keeping the stock exhaust. Did you have this setup, too? I definitely am not an attention grabber and I don't want my fillings falling out of my teeth when driving at highway speeds. Might not take the gamble.
Old 02-17-2009, 04:26 PM
  #60
practicing nihilist
So you have full RV6 package --> straight pipe where stock mid muffler and stock resonator were --> stock rear muffler packs? Also, do you have the resonated ('test pipe') or non-resonated ('race pipe') 3rd cat delete?
I guess I was surprised at how minimal the note changed that I could squeeze a few more ponies out with running straight pipe the rest of the way, but I don't want to sound like a rusted out Pinto rolling down the street.
*UPDATE* It was noted in one of the other threads but had my 1st true cold start this morning. Sounded like a handfull of pennies rolling out of the manifold and down the pipes...Nasty - briefly thought I'd screwed up but it went away in less than 30 seconds. ULEV cold start logic strikes again. 4.0 after that.
Old 02-18-2009, 11:33 AM
  #61
Under construction
alexSU's Avatar
No, I don't have the RV6 package, just the mid-muffler deleted and resonator deleted. I think with a full RV6 package the raspy sound will disappear somewhat...hopefully
Old 02-18-2009, 11:46 AM
  #62
2008 335i e92 6MT
MobTownTL's Avatar
how much do you think an install like this will cost you if you bring it into a shop and will it be worth it? dont want to risk anything since i've never messed with my car like this
Old 02-18-2009, 11:53 AM
  #63
KICKED IN THE BALLS
anarchy[sear]'s Avatar
Heyyyy!! Ned!!
Yeah PFFPFF's car was really raspy with the race pipe,richies jpipe and pre cat deletes. But without all those other mods his setup sounds really nice on my car. Thanks again for the set up.
Old 02-18-2009, 12:51 PM
  #64
greco9885's Avatar
Probably 2 hours at their labor rate. They don't go by realtime, they go by AEM's(or manufacturer of product) install time
Old 02-18-2009, 02:04 PM
  #65
Sandy Eggo
pffpffpass's Avatar
They will charge you an arm and a leg..
Prob around 500ish..
Anarchy(Phong) good lookin on your exhaust..
Car sounds really good now.. And pulls hard!!
Old 02-18-2009, 02:12 PM
  #66
Rick_TL-S's Avatar
Received 1,194 Likes on 687 Posts
Depends on the shop. A muffler shop quoted me $50, but the shop thought my TL was some kind of 350Z before they saw it.
Jotech, though, priced me $95/hour and I talked them down to $65.
Ended up having my buddy come & do the pipes instead.
Old 02-18-2009, 02:29 PM
  #67
greco9885's Avatar
LOL no way. $500 = 5 hours of labor, install book time is 2 hours, real time, more like an hour
for $500, they better detail your car, drive you to the guys house, so you can fuck his wife while he installs the intake
Old 02-18-2009, 02:34 PM
  #68
KICKED IN THE BALLS
Well if your doing precats and all the way back they will probably charge you a crap load of money
Old 02-18-2009, 02:39 PM
  #69
Rick_TL-S's Avatar
Well, of course. Doing a full exhaust system all at once isn't cheap, but I don't think it should really cost more than $300.
Old 02-18-2009, 02:40 PM
  #70
greco9885's Avatar
precats, jpipe = 4 hours
catback = 2 hours
aem = 2 hours
pulley = 2 hours
total = 10hours = ~1000.
my install took 10 hours
Old 02-18-2009, 03:09 PM
  #71
Under construction
alexSU's Avatar
Old 02-18-2009, 04:48 PM
  #72
practicing nihilist
A couple guys got quoted from dealers and competent shops in the $90-150 range for the cats and j-pipe. A good shop wouldn't need more than 2 hours labor.
1st time install of pre-cats and j-pipe should be in the 5-6 hour range, if you study before hand and get your tools together prior. I'm just a backyard mechanic and my dad can usually unfuck whatever I'm stuck on, but with the lift and about 3 months of drooling over these posts it was a legitimate 4 hour job. You'll spend a quarter of that on the last fricken bolt on the year cat heat shield.
if you can get the leverage and a long breaker bar on the pulley, that is seriously like a 30 minute job. Ned's Tip: study, draw or have a diagram of the serpentine belt alignment before you loosen the tensioner pulley to get the belt of the crank!
CAI...yeah, removing all that factory junk was a chore but don't remove the front bumper. All you have to take off is the weather guards in the wheels well and under the front left bumper.
Old 02-20-2009, 09:05 PM
  #73
The Kinetics of Bleu
TLAdvanced's Avatar
I installed my precat deletes tonight. I already had ATLP J-pipe, RV6 test pipe, stage 3 exhaust mod and stock Type-S cat-back. I have a VERY annoying rasp. I guess I need to put the stock resonator back in...
Old 02-20-2009, 09:10 PM
  #74
practicing nihilist
bummer, man. I don't want to be annoying to other people or myself. But I think my next grand laying around will have to go to the new ATLP base exhaust.
Old 02-20-2009, 10:17 PM
  #75
Sandy Eggo
pffpffpass's Avatar
I told you guys that was gunna happen!!!! Stage 3 + precat deletes = rasp..
Old 02-20-2009, 10:44 PM
  #76
TLAdvanced's Avatar
You think I'll be ok replacing the Dynomax with the factory resonator?
Old 02-23-2009, 09:56 PM
  #77
Bored at work
tl2slow's Avatar
i just put mine in, it sounds great with stock exhaust. but when the car is cold i get a lil buzzing sound???? and did anyone have fitment issues with the j pipe...it didnt line up with the cat deletes or the stock ones....whats up with that...but it still pulls hard as hell now....
Old 12-13-2009, 01:52 AM
  #78
TheBadS's Avatar
This thread is awesome. Thanks to everyone that has given input of all your expierences! ive been studying the hell out of this forum.
So pretty much what you guys are saying is if you install the RV6 Pre cat deletes, atlp jpipe,atlp high flow, and all stock exhaust from highflow cat back it will sound great with NO rasp? Do you guys have any problems with check engine lights?? Also any problems with local acura dealers for taking out the pre cats?
I'm torn between doing the PCD+jpipe+highflow cat+stock exhaust, OR stock cats up top, j pipe, highflow cat and atlp quad exhaust when it becomes available. I know the pcd route will prevail best gains. and the other route might be alittle more sound friendly? tell me if im wrong guys, im VERY new to the V6 scene.
How does it sound with PCD all the way back into a atlp quad exhaust? havent heard u guys mention much about that?
Old 12-13-2009, 11:05 PM
  #79
gerzand's Avatar
I see how/why you are debating between these two setups.
However, the first thing to keep in mind is the striking difference in the decibel level both IN and OUTSIDE of he cabin with an ATLP quad compared to stock catback with PCD's/Jpipe/HFC. For some people there are reasons which a louder exhaust wont work for them. It all depends how agressive and you want your car to sound on the street/in your neighborhood/ or possibly with family and kids in the car with you. With retaining the stock PC's and using a high flow cat, you wont have rasp but the car is going to be LOUD (even when the exhaust is broken in after ~500 to 100 miles)...... so if you want a relatively tame sounding car, but SOME performance.....go for the PCD+stock catback solution.
Otherwise go all out
Old 12-14-2009, 08:35 AM
  #80
1FAST_TL's Avatar
this weekend i pulled out my cats and cleaned them, it tooks me about an our and half to put them back again so it tooks me about 2 hours for the all thing 2 person, dont spend money in a shop do it youself its really easy, and you learn about what you have, im also installing tomorrow the evo2 exaust, and ur pulley, aint paying no shit to any shop.
Quick Reply: Precat Deletes + Upgraded Jpipe + No 3rd Cat + Stock Exhaust = very sexy exhaust note
