Performance Upgrades
Old Jul 3, 2007 | 09:41 PM
ajbarbato15's Avatar
7th Gear
I recently purchased a TL Type-S 5AT. I was some serious horsepower and speed. Im currently in school so the S/C is def out of the question just because of the cost. Does anyone have any suggestions on what I can do???
Old Jul 3, 2007 | 11:45 PM
ussi's Avatar
I (don't) whine.
bro, if you read any of the threads in the 'performance parts & mods' section, you'll be able to answer your own question and more.
Old Jul 4, 2007 | 01:20 AM
csmeance's Avatar
E-Shift Pro Cats - good fro about 20 HP and 11 TQ at the wheels
AEM Cold Air Intake - about 7-10 hp at the wheels
Outlaw Engineering Thermoblock spacers - 1 hp, but reduces heat
Exhaust - depending on brand, can get you gains, preassembled one is from comptech
UR crank pully - 1 hp
Rear sway bar - from comptech, helps stability of the car in cornering
weight reduction:
Free stuff:
remove spare tire
remove any extra stuff such as manuals and cargo
Costs:
Lightweight rims
UR pulley
Old Jul 4, 2007 | 03:20 PM
I hate cars's Avatar
You purchased the wrong car for that. Sorry.
Old Jul 8, 2007 | 04:58 PM
Alin10123's Avatar
Does the TLs already have a thicker rear sway bar?
Old Jul 8, 2007 | 06:36 PM
csmeance's Avatar
stock tl - 17 mm
stock tls - 20 mm
comptech - 22mm
progressive - 24 mm
\The TLs does, but the progress bar will make it even better. There is a group buy in teh black market.
Old Jul 8, 2007 | 09:31 PM
06WDP-TL's Avatar
Hondata > *
bigger does not always mean better.
Old Jul 8, 2007 | 09:33 PM
csmeance's Avatar
I am happy with the comptech one that i have (i had 17mm before) and it was an improvement. But the ride quality was unchanged for the most part, except for the cornering stability. To big of a bar and the ride might get a bit off.
Old Jul 8, 2007 | 09:57 PM
Alin10123's Avatar
stock tl - 17 mm
stock tls - 20 mm
comptech - 22mm
progressive - 24 mm
hmm... so i take it that since progress it not only thicker, but it also has polyurethane bushings, that it should provide even better results than the comptech? If i'm not mistaken, the front sway bar is 27mm in the TLs?
Old Jul 8, 2007 | 10:21 PM
crzygosu87's Avatar
Down for a photoshoot?
+1
Old Jul 8, 2007 | 10:46 PM
06WDP-TL's Avatar
Hondata > *
its not neccessarily that its "better". it all depends on your goals for suspension and how you want your car to handle.
if u want the rear to kick out more, then go bigger in the rear, or smaller in the front. For a neutral handling feel (which i prefer for street driving), comptech rear sway + A-Spec yields these results.
although i dont think u'll feel much of a difference between the 2 bars on the street. Pick whichever you prefer, both would be better than stock.
Old Jul 9, 2007 | 04:07 AM
ussi's Avatar
I (don't) whine.
i agree with what you say..., except that you will feel a big difference in comptech and progressive.
why does your description say hondata? just curious...
Old Jul 9, 2007 | 04:53 PM
AMGala's Avatar
Lamborghini Aventador FTW
Also, diameter isn't everything. Some bars are hollow while others are solid.
Old Jul 9, 2007 | 06:36 PM
csmeance's Avatar
he might work for them or has gotten one of their more recent reflashes I remember before someone posted with a similar name that to wait a little more as hondata was about to release the reflash, so its a better chance that he works for them.
Old Jul 9, 2007 | 07:42 PM
06WDP-TL's Avatar
Hondata > *
i do little side projects with them. Mainly dual ecu setups and harnesses associated with it.
but i have it there b/c i think Hondata rocks. They do extraordinary things using the simplest of things. They've helped me accomplish the impossible, and are continuing to help me with my personal R&D
As for the reflash, all i can say is that there is DEFINITELY good reason why they cannot release it.
Old Jul 9, 2007 | 08:13 PM
csmeance's Avatar
06wdp, one question, since you do side projects with them you might know the answer to this question:
When hondata reflashes the ECU for a TL or TSX, is the electronic speed governor removed or killed? I head a friend saying that the governor is programed inside or ECU so reflashing it might erase it right?
Old Jul 9, 2007 | 08:27 PM
06WDP-TL's Avatar
Hondata > *
with Hondata reflashes, generally that part is left alone. As it is unsafe to even travel at governor speeds. You can check Hondata.com and see what the other reflashes for other cars do. None state anything messing with the governor, as its not involved in any tuning aspect.
With the K-series, they are not modified, but then again, I do not believe there is a speed governor on the RSX. i've topped 150mph on the dyno at the end of 4th gear on my RSX auto. The gauge cluster reads 140mph max.
As for TL reflash, the next time i talk to them, i will see if theres any progress in the TL flash. Heck, i cant even get the flash. And i want it as bad as everyone.
Old Jul 9, 2007 | 09:43 PM
ussi's Avatar
I (don't) whine.
TRUST me, i know
Old Jul 9, 2007 | 10:04 PM
06WDP-TL's Avatar
Hondata > *
i still want it
Old Jul 16, 2007 | 06:55 PM
lilbitt626's Avatar
can somebody send me some links for a 07 tl type s parts i wanna make it quick
Old Jul 16, 2007 | 07:13 PM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
TRUST me, i know
I want to know to, for curiosity sake.
Old Jul 16, 2007 | 10:22 PM
ussi's Avatar
I (don't) whine.
^i updated my other thread - JPipe.
mlody
Dec 4, 2019 02:11 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
c1souk
Sep 28, 2015 11:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
