Omg! Aem = Awesomes!
#41
Originally Posted by Timmahh
Desper - would you rather have the dealer plate or AEM plate?
Atleast with the AEM plate another TL'r might say "hey.. this guy did something to his car.. maybe he's on Acurazine!"
A SiQ TL has the comptech exhaust; im scheduled to listen to it in person on Monday to see if I like it
#42
I Also have the Comptech Catback....
I hate that cheapr ass plate... that is why i put on an aftermarket chrome plate that only says "TL" on the back.. I am painting the TL part to match my cars color this weekend.....
Please no AEM plate the black looking cheap thing does not flow well with the good look of the TL
#43
it's me, Alan Rickman.
^^ See, I hate that though =/
The car already says TL on the back of it; why get a plate that says the same thing, or one that says Acura.. again, we already know what the hell it is, I guess if anything i'll just have to get a blank one or something that says something funny
i blogged your girlfriend.
#44
AZ Community Team
Received 7,771 Likes
May I recommend, South Park.
#45
here's some footage i took....u can actually here churps from intake
http://www.youtube.com/watch?v=H_sZgNjhu0w
#46
Nah.. AEM has pretty darn good instructions; I followed them and had no problems.. I did NOT end up draining a gallon of coolant like the instructions say; I just had a small piece tupperware and caught what little (like... maybe 1/4 cup) coolant came out and poured it back into my reserve tank
#47
aem cai option
i love my aem at WOT too, its sweet sounding and seems more responsive.
bty, did/has anyone done the 'optional power adder'? Moving the IAT sensor from the throttle body to the intake pipe is suppose to add 10hp. but I'm wondering if it will cause the engine light to come on? There isn't emission testing where i live so i could get away with it if it doesn't cause damage and/or engine light to come on...
#48
when i moved mine, the check engine light came on. I unplugged and replugged in the battery and its been off since.
#49
#50
Originally Posted by 1meand
I don't know if the Fujita is different from the AEM or if it's because I have an 07, but the instructions said to replace the factory coolant line with a supplied 8mm hose. I didn't do that because I couldn't figure out the purpose of this. I used a longer than the factory piece of 10mm hose for the breather line, but didn't touch the coolant line. Can someone explain the reason for changing the coolant line?
It gets changed out because you have to use a different setup for the breather tubing to reburn crank case fumes; if you leave it as is you just have an open tube.. i've gotten a ticket for "no smog device" because i had an open tube once; $90 + smog check @ state station + fix it ticket = not fun
I suppose you can leave it as is, but it looks weird with half of that item disconnected.. also note that i had like.. 1/18th of a soda can leak out and i just held a tupperware container below it and poured it back into the resevoir
#51
Here is a link that is dedicated to discussing the pros and cons to moving the IAT sensor.
In the link provided below, be warned that some people called the IAT sensor as a O2 (oxygen) sensor. It is *not* an oxygen sensor. It is an Intake Air Temperature sensor.
AEM CAI low end torque? (click here)
#52
#53
My Garage not
1 Post
^^u can leave it the way u have it. the way aem wants u to set it up will get rid of the now unused tube so u can get rid of the entire metal bracket that holds the tubes. it's a cleaner looking install and also i think the tubes that aem supplies are a little thicker if i remember it right.
#55
The AEM sits up pretty high, you'd have to have the entire bottom half of the bumper submerged in water to get hydrolock i think.. fujita goes down lower
#56
Black Mamba
I just received my AEM CAI from Excelerate today and I'm going to install it tomorrow however, I can't figure out what kind of drill I need. I've never had to drill to remove the resonator when installing CAI's so this is a first. For those of you that have installed the CAI, what kind of drill did you use and is it absolutely necessary? Can I buy the drill at a autozone or Pepboys? Any help is greatly appreciated.
#57
Former Sponsor
#58
Black Mamba
Originally Posted by Excelerate
You have to drill out the little rivets. You can use any drill. A unibit works well or you could even cut the tabs off or punch them out with a screwdriver. It doesn't require anything special.
#60
My Garage not
1 Post
if u take the bumper off u don't have to drill out the metal rivets which hold 2 pieces of the stock intake together. after the bumper is off u can take the whole thing out as 1 piece. this will make putting the stock intake back in easier if u ever have to do that.
or, u can just drill the rivets out with any old drill or dremel tool and pull then pull the 2 separated pieces out separately. if u ever plan on putting the a-spec bodykit on yourself just buy a dremel tool and use it for both installs.
