Ok Dumb newb question on j-pipe
Old 07-10-2011 | 02:34 PM
cinobyte's Avatar
I see tons of post on it. I also see that its an exhaust pipe atleast from the pictures i found on google. anyway why is it so popular and what is the purpose of it?
Old 07-10-2011 | 02:52 PM
Hi speed's Avatar
runnin a little boost
Since the 3G or 3rd generation TL's have the header or exhaust manifold cast into the block. The catalytic converters attach to the engine directly and the J- pipe is the exhaust piece that connects the front and back cats to the rest of the exhaust system. The stock j- pipe is small and restrictive and the aftermarket ones are better designed and produce more power.
Old 07-10-2011 | 05:13 PM
Bearcat94's Avatar
AZ Community Team
Side-by-side shows the restriction in the stock pipe:
Originally Posted by Bearcat94
Just got mine in yesterday. With the help & hospitality of mmade22 ( ).
Great fit, great design: Props to Mike at ATLP. Bolts in super smooth. And you can see where the gains come from: much less flow restriciton.
Old 07-10-2011 | 05:38 PM
libert69's Avatar
18psi
after looking at that picture, almost makes me wonder why acura made the j pipe so restrictive from the factory. They possibly could of advertised the 04 TL as having closer to 285hp from the factory if they used a more free flowing j pipe
Old 07-10-2011 | 06:28 PM
cinobyte's Avatar
wow that really looks like a poor design on there part. looks like a real easy diy HP gain unless its really hard to get to.
Your response leads me to another question..so there is no manifold gasket? the manifold is built right on the block?
Do you have to remove at cat to install the j pipe and if so what about the o2 sensors and such?
Old 07-10-2011 | 06:57 PM
Hi speed's Avatar
The J-pipe connects the bottom or exits of the two cats. Unless your bolts are rusty it should be a pretty easy DIY.
Old 07-10-2011 | 07:36 PM
jav540's Avatar
took me about an hour in my garage on ramps and towers, go for it.......
Old 07-10-2011 | 10:23 PM
purplerims's Avatar
Does any one kno if the pipe diameter is different between the alt jpipe vs the factory one? I have a 7th gen v6 accord so we too have the same restrictive jpipe
Old 08-09-2011 | 07:59 PM
Damian0216's Avatar
you can ask richie, he makes the accord and tl j pipes
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
navtool.com
31
11-16-2015 09:30 PM
lanechanger
10-13-2015 11:56 AM
navtool.com
09-25-2015 06:15 PM
Quick Reply: Ok Dumb newb question on j-pipe
