Newest Ultimate clutch, flywheel...J&R twin disc
#41
Well glad to see you on the forum kikazz,I have to thank kikazz for funding us to get the twin disc made and working this was a very tring project took quite a few trials but glad to say it came thru ,he will also be a big part of helping us getting a gearset made for the Tl as this will be the next adventure ,as I see this necessary with the high horsepower builds coming around ,which is great to see ...
#43
+1
I have seen 405WHP fully built engines pushing 7psi making serious power and loss of traction by not having the ability to properly put down the power. With that power you better be looking into some custom axels.
Good luck and let us all know how it goes. Remember, the higher the numbers really don't mean much because its all about what you can hold/put down.
Yes Vato, thanks again for everything.
#44
I'm going to disagree on axles as a concern unless the typeS axles are considerably weaker than the 04 base models ,at 479 whp and 470 lb tq I've yet to change axles better yet there still the same oem from the car left the factory and even with full traction off the line I sheered third gear instead of the axles so I'm going to say the trans is what needs attention first and Dss will build a set for about 1600$ so that shouldn't be an issue as far as stronger axles ...
#46
^^ bmeyer the gears will be a while as no one want to jump on them asap due to funding as they require a order of 5 or more to get started asap but we will get them done but I'm going to say in a few months we will have some info as to where we are with it ..
#47
Former Sponsor
Op, I know you made 4 passes but I didn't mean they would brake that soon. Over a couple of months/ hard launches I guarantee they will break/crack. They break from excessive wheel hop (trying to burn out on all seasons or winter tires) /no traction and hard launches.
If you turn your wheel and you hear a clicking, then they're cracked but that also doesn't mean its not drivable.
#48
^^ I understand and don't mind constructive criticsm as this educates and aware us ,I'm going to say that the Tl S are probably the weaker of the bunch as I've heard quite a few complaint about that clicking noise on car that aren't even modiified idk ,but kikazzbuild will surely let us know what will need to be addressed ...
#51
What type of gains do you see/feel when rolling? Obviously the biggest improvement will be off the light, but I am curious about how much of a performance improvement the car sees otherwise.
To put it another way, do you believe that there is any performance benefit when the clutch is fully engaged?
#53
Im not arguing but they are weak. I my self have gone through 5 sets as well as many other people I know. More so for the 6 spds. At 405 WHP I was advised that custom ones were needed by a reputable mechanic. If custom built ones for $900 are rated up to 500WHP, how can stock be better? Maybe you didn't change the axels but the other 20+ people that I know who have changed them numerous times or ordered them from my ACURA dealer had a problem. I haven't changed them in 2 years since I changed my driving habit.
#56
347hp/300tq @ 4psi
one guy i know that drives another 7th gen accord at the track with NOS, snapped the axle right in half off a hard launch. eventually, they will definetly need to be addressed with the insane amount of power you turbo guys are producing...
im also with rodney that beefing up the tranny should be our #1 priority and glad to hear you have something in the works with stronger gear sets all this newfound power is useless, until this issue is resolved.. im living proof of this
lastly regarding this new clutch kit, though it looks promising, my only concern would be longevity.. my friend who owns an evo 9, has to get his ACT twin disc replaced every 10-12k miles or so. yes, driving style does play a role in it too, but IMO a good single disc setup will always last longer than any twin setup. i guess this is something we'll find out as time comes..
#58
J36Twingt28r's,nextgt30r
#60
All motor
Just an update. I put an extra muffler on the to quite it down, and i lost some hp and torqe. I am guessing i am sitting around 250-260.
before 275 whp, pcd, stock j pipe 3 in exhaust small race muffler.
stock clutch slipping
13.48 @ 109 w/ 2.38 60ft
now 250-260 whp, pcd, stock j pipe 3 in exhaust huge magnaflow muffler, and small race muffler, and J and R twin disc
13.05 @ 107 w/ 2.017 60ft
my best 60 of the night was 1.99
This is in a full weight street prelude. Im going to be doign some weight savings to it, and fix the exhuast flow problem, and build a custom intake manifold for it.
With the J and R stand alone coming out, i am hoping to see a little over 300 whp, and break into the 11's with a little weight savings.
This clutch is amazing!
Did you dyno before/after the Magnaflow muffler? Is it straight through or chambered? I'd be extremely shocked if you lost even 5whp from the Magnaflow straight through muffler, let alone the 15-20 you are estimating.
The difference in trap could've been due to DA conditions or even just the car having a bad day. It's happened to me too many times.
Any plans on changing out the Jpipe? Or do you think stock is just fine? It seems to be working rather well....
#61
That is a very impressive trap! Great times as well!
It is a 3 chamber muffler, 48 " long, 3 in inlet 3 in outlet, 8inch total diameter. The power loss was noticible. I may to stick it on the dyno friday to check it before The race on sunday.
It could all be in my head but i am pretty sure i lost quite a bit.
I contacted richie at rv6 trying to get some parts from him, but it is becoming more hassel than its worth,to so i will be building a complete setup my self. I will be using 2.5 off each head, a x pipe 1 resonator on each side, and 1 small straight through muffler on each side. I just need to try keep it quite, i may be doing the front half in stainless, and after the resonators everything back in twin 2.5 alumninum.
#62
All motor
Ah you went with chambered, that's why you felt a loss. The "straight thru" mufflers are much better in terms of 'maintaining' hp/tq while keeping the exhaust relatively quiet. I'd definitely recommend one of their straight thru mufflers in the future.
48" long? That's nuts. I thought mine was big and it's 36". No homo
Oh...with a true dual you will need much more than a small pair of resos/mufflers on each side to keep it anywhere near respectable sound levels lol.
#64
Ohh, and it takes up almos the entire center section from the j pipe to the 90 bend at the rear of my prelude.
#65
All motor
I have the 6in round 30in body muffler. It's huge. But when I called Magnaflow, they said the round mufflers aren't the best for sound deadening because not as much packing can be stuffed into a circle as compared to a rectangle.
#67
All motor
Very impressive!!! How much does the Prelude weigh? I looked online and I saw around 3050lbs. Do you have any weight reduction? Also, forgive me if you already posted it, but what mods do you have on the TL-s motor?
#68
If i had to guess, i would say the car weights right around 3000 lbs plus about 230 for my big arse. Only weight reduction i have is the trunk is emptied, and the front bumper support is cut a bit, and the rear is off the car. Other than that its full weight, full interior. Im probably right around stock weight, considering the j motor weighs just a little more than the factor h22.
Mods, im currntly running a j32a3 intake manifold (the j35 manfold was badly damaged in the engine fire the motor experienced before i bought it. Custom intake, pcd, stock j pipe, 3 in exhasut to huge magnaflow muffler, 3 in to cherry bomb race muffler at the back of the car.
I will post the videos later, I have one of my car alone and you can hear it making the pass, then i have some of me racing the other competators, and theres are crazy loud.
#72
All motor
108 is a really nice trap. You should try going with a custom Jpipe to mate up to your 3in exhaust. I think you'd definitely gain some power throughout the band. That's my plan for this month.
#74
New personal best a few weeks back at the IFO wichita event. My fastest time so far. I have had better trap speeds but everything is going to change one i get my new exuast setup and stand alone in.
http://www.youtube.com/watch?v=wtqtB2FYYuU
the vid shows a little abuse i put on the clutch.
#76
All motor
Those are some serious trap numbers for the stock Jpipe.
#77
forget the 3.5 i already have plans for a 3.8 or 3.9 setup. Im thinking 13.5-14:1 compression setup with a little juice. Will stick me near 600 to the wheels.
I will be looking for 115 to 120 with the new exhast and tune. 11sec full weight prelude here i come.
Ohh and if i can get my hands a TL for a good enough price, next season the built motor will be going into a TL drag car.
#78
All motor
115-120? You expect a 7-10mph improvement from just a new exhaust and a tune? What kind of math are you doing? Lol.
When you say new exhaust, do you mean a new Jpipe as well or just a catback with different mufflers?
13.5-14:1 CR! Wow! How do you figure a 3.8L?
#79
big bore j37 will get me 3.8-4.1 if i desire. To go 4 liters + though it will require wet sleeves. I should be able to use a complte j37 blockk from a mdx with my type s heads and trans.
