My '06 Acura TL with almost full bolt ons dyno video..
Made 225 at the wheels. Heres the video
2006 Acura TL 5AT Full Bolt-On Dyno Run:
These next 3 videos were before the precat and throttle body spacer install, but check them out anyways.
Exhaust Fly-by :
Exhaust rev # 1 :
Exhaust rev # 2 :
Exhaust Fly-by :
Exhaust rev # 1 :
Exhaust rev # 2 :
Mods in dyno video:
AEM Cold Air Intake
RV6 V3 Hi-Flow PreCats
P2R Throttle Body Spacer
P2R Thermal TB Gaskets
ATLP V2 J-Pipe
ATLP High Flow 3rd Cat
XLR8 Base Single-Tipped Duals (non-resonated)
Weight Reduction:
Hood Insulation Delete (1.8lbs)- done
Weather Strip (above hood) Delete (2lbs) - done
Engine Bay Covers Delete (6lbs) - done
Spare Tire Delete (34lbs) - done
Rear Seat Arm Rest Delete (6lbs) - done
Rear Floor Mats (6lbs) - done
Trunk Insulation Delete (23lbs) - done
Total Weight Savings - 78lbs
AEM Cold Air Intake
ATLP V2 J-Pipe
Weight Reduction:
Technically, it's 225 at the hubs, not the wheels, but at least you have a point of reference for future mods. Seems a bit lower than I would have expected, but dynos don't mean much anyway. They all read differently.
I'd take it and get a time slip when weather permits. That's a much better indicator of what your car is capable of, IMO.
EvilVirus (01-20-2016)
I'm also not sure what gear he did the pulls in. Could have been one of the powerless gears (most of 4th, all of 5th). All I know is that car pulls WAY harder than a 225 at the hubs/wheels/whatever should. I think it's making a bit more than that.
Reason I think that is because I clocked a 6.2 0-60 with just an intake before I really started modding my car, and I measured it with two different apps on my iPhone. So something isn't right.
don't worry about the dyno. It's just a tool for keeping track of your mod. Also we don't know what you dyno pre-mod, and how are they doing the calibration. SAE? Smoothing 2,3,4?
So don't be disappointed. I dyno 251whp at the hub on my accord v6 6mt and I have everything.
I really want to finish off the project and buy the 3.7 intake manifold and throttle body but what kind of gains would I see and would it even be worth to invest into it? That would make my car truly full "safe" bolt ons as far as the exhaust and intake parts go. No pulleys for me. Hearing too much about reliability issues and the price to performance ratio is way off.
Numbers are pretty good for a Dynapack. In my experience they dyno lower than dynojets on sub 400WHP vehicles. I'd make a SWAG that you are close to 240 - 250 on a dynojet, which is pretty nice for an auto.
Have you already bought a FIC? If not, have you considered looking for a JnR eu? That would give you better control over the ecu parameters than the FIC.
I thought dynapack always read higher because you are bolted on to the machine. So you don't have to account for tire traction and addition rotational mass like rims and tires.
That is the common misconception. If it was done at Church's then I'd say yes the numbers are high as they have/had a notoriously optimistic dyno, but that was years ago. I'm not sure if they even have a dynapack anymore.
Lots of Corvette shops use dynapacks as they are much better for tuning than a dynojet, and cheaper than a mustang dyno. The general consensus, at least it used to be, was that for most cars in the 350+ range, they were very comparable to dynojet numbers, but the low and mid hp cars (typically imports) always were disappointed as the numbers were a good bit lower.
People can rag on dynos and differences as much as they want, but "in general" they are very accurate, and very repeatable. People will agree with a number if it matches what their held belief is, but not if it is outside that belief. For instance, the same day, my buddy's H22 CD5 Accord made 180whp on a dynojet. No surprise, that's perfect for that engine. My stock (Hondata only) 04 6MT TL made 240whp, and people laugh and say ok, sure whatever.
My stock 05 6MT TL made 230WHP and no one complained. Only when they hear something they don't think is believable do they call B.S. My 05 ran 99 in the 1/4, haven't run the 04 yet, but it's on narrow tire 18s, so it might not do as well. The funny thing is, if it went 102, people would say the track was wrong, so it doesn't matter, you can't win, so why worry about it.
As long as your car is staying out of knock, and running properly, I'd say you're making more than 225whp on a dynojet.
Mr. Detail
I know you have the stock wheels on your car, but heavier or light wheels will show up as losses (heavier) or gains (lighter) on a dyno. One of the car mags several years ago picked up 5-8 hp across the board just by going to a lighter wheel, using the same dyno of course. Just something to think about to those who have gone to larger, heavier wheels and wonder why your car isn't putting down the power it should be.
FWIW, the new GT350 with carbon wheels shows significant acceleration gains over the heavier aluminum wheels:
Do the Shelby GT350R?s Carbon-Fiber Wheels Help Performance? ? Feature ? Car and Driver | Car and Driver Blog
First time is aluminum, 2nd is carbon
ACCELERATION
30–50 MPH, TOP GEAR 10.8 sec 9.9 sec
50–70 MPH, TOP GEAR 10.5 sec 9.7 sec
30–130 MPH, 4TH GEAR 17.7 sec 16.5 sec
ACCELERATION
depending on the calibration it may read 8-10% lower than a dynojet.
I also found the mystery TL that made 728whp again
Videos & Updates
Videos & Updates
From what I've seen, it's not the calibration. The dynapack just seems to dyno lower than dynojets on sub 400whp vehicles. Lots of Vette shops use dynapacks since they are good for tuning. When the occasional import comes in, they leave disappointed when their sub 300whp car dynos lower than what they expected to get (dynojet type numbers).
I'll never understand why people get so wrapped up in a three digit number that means so little. You've got Mustangs, Dynojets, Dynapacks; they all read different, they're all calibrated differently, they're all run by different operators. Hell, most people who get that readout in their hands don't even know if the run was SAE, STD or uncorrected. They're a good tool to track progress, but don't get so wrapped up that final number or even attempt to compare it to others' numbers.
I've seen readouts for First Gen basic bolt-on Si's and TSX's from Church's (the place Screamin Z28 mentioned) that "made" over 250 whp. That's utterly laughable, but you know those guys dropped that number in every possible situation they could. The reality is, they still had low/mid 14 second cars (Si) and upper 14 second cars (TSX) with inflated dyno numbers that ultimately meant nothing.
Get out there and run some cars (safely) and go to a track to see where your car stands.
EvilVirus (02-08-2016)
Nah I'm serious. Not much left I can do (safely) beside test pipe and maybe porting/polishing upper and lower intake runners/throttle body/intake mani. I'm not wasting money on spacers again.
Agree, 1/4 mile time and speed is more telling, I need to get the drag strip
