The Multiple Benefits of Owning an HDS/HIM Tool - Everything You Need to Know
#42
"I would have paid $200+ to get the SRS system diagnosed"
They may want to charge you for a "mechanical" fix but you wouldn't have to pay for the diagnosis. This is especially true because any SRS issue means airbags don't deploy.
I assume this is because you swapped interiors?
http://owners.acura.com/Documentum/W...s/BWL35759.pdf
#43
SRS systems aren't warranted against owner negligence which is what happened in this case from me swapping my interiors. Nothing was inherently wrong, but it's still time and labor.
If it would have been the seat belts, warranty would have likely covered it. I couldn't play the "I don't know, they just came on" card with both of my cars. Maybe if it was just one.
#47
I tried this on my car using dorman tpms and it was a no go not even with the hds. I was thinking I was doing something wrong and went to the dealer and they wasn't able to get it to work too so I went oem.
#48
yeah I don't think the hds is going to solve any tpms related issues, it will just tell you what is wrong. i believe it will tell you if the tpms is not communicating but that is pretty self explanatory anyways.
btw, there is an internal part number for the tpms that multiple car manufacturers use. cheaper to get a new one this way rather than going through the dealership. just have to make sure it's the correct frequency.
#49
#52
#53
Your post threw a monkey wrench into my plans.
Issue: Dorman tpms isn't communicating properly with the car. Solution, get it reset at the dealer for whatever it's going to cost - some say it'll be $100 - $150.
so now it's
1. get new OEM tpms sensors, pay for them to get installed probably around $100 - $150.
2. try and get these dorman ones reset at the dealer (now i see someone has tried and failed) probably like $100 - $150
3. this tool which someone used on their odyssy ..tool is $150.
4. or now this HDS/HIM method, this seems to be $150 too.
thank you for adding to my dilemma, haha.
so now it's
#55
#56
The dorman operate at the same frequency but but but. The frequency the the tpms unit use to activate the sensor is different every time the ecu WAN tire information the tpms unit one on every fender and quarter panel send a signal to the sensors and the sensor answer with information like tire pressure and tire temperature the ecu just display the pressure. I learned that using my hds with my dorman tpms every time I was programming it it say nor respond from sensor.
#57
#60
Do you have to have the power cable plugged in?
Basically you have to run an extension?
I plugged it into my laptop and the OBDII port and it lit up but no work...I would have to get an extension now...
#62
#65
2 questions:
There is a crankshaft position adjustment required after doing the TB? Any more info on this?
Also, I don't see any idle screw adjustments on my stock TB, or is it only on th 3.7 TB?
The governor is only on automatics for 07-08, which include base and type S. 04-06 has no governor, auto or manual. And 07-08 type S no governor as well
#67
As for CKP, allegedly that is just a step that Honda throws in after anything that involves engine work. Similar to how the service manual requires you to unplug your battery before changing a light bulb etc. A Honda tech commented earlier and said it's not necessary. But for what it's worth, the service manual does have this as a step listed during the timing belt change.
This one. It's good for all Honda/Acura vehicles from 2002-2009.
#68
well, sadly this did not fix the bucking issue with the 3.7 TB. It still jerks hard in 1st/2nd gear at low speed when letting off the throttle, and 3rd/4th gear still have a noticeable jerking when letting off the throttle from 1-3% - DomGSR had the same results and I wanted to confirm.
voltage adjusted from .92 to .88 and ran both of the inspection processes under PGM FI > ECMS (TACS) (sp?). The first one I ran was the limit check, which passed just fine. Then I ran the valve angle inspection that made some interesting clicking/buzzing sounds from the TB (as Gerzand advised it would do), and then went to drive the car around.
I'm fresh out of ideas on the 3.7 bucking issues. Neither FlashPro or HDS seem to help.
#70
i wish i could laugh at that but the reality is I am constantly shifting gears in order to keep the car from bucking - whenever i want to just take my foot off the pedal as i speed up and down in traffic, the only way to avoid the jerking is to depress the clutch. I spend way more time in neutral than I should now too.
my throwout bearing is going to fail on me a lot sooner now due to how i have to compensate in order to drive the car smoothly.
.........but yes, at WOT some of that is made up for
#72
HDS tool to the rescue again.
VSA/ABS/exclamation point lights came on the other day. Blindsided with this since you can't normally figure out the cause without taking it to the dealership and having them read the code. Turns out my right rear wheel speed sensor went out. HDS tool saved me another $80 for the DTC reading fee that dealerships normally charge.
Happy New Year all!
Happy New Year all!
#73
is this the HDS Tool?
http://www.ebay.com/itm/OBD-Tuning-HDS-Cable-OBD2-Diagnostic-Cable-for-Honda-/190801021973?pt=Motors_Automotive_Tools&hash=item2c6ca08c15&vxp=mtr
And i'm guessing the HDS (Like the HIM), works on 3G TL's 04-06?
And does the HDS program key immobilizer?
#74
thats just a cable
#77
So just to clarify. The HIM can reprogram a new ECU to my vin number as well as sync the immobilizer to it? Or is that the HDS? The reason I'm unclear is because I asked a seller of the HIM on eBay and they said it couldn't.
#78
can't do without connecting to the honda database. It think I am going to sell mine with the usb to serial cable. Unless I can get verison 2.027. looks like all the 3.xx version suck
