Mid Muffler Removal QUESTIONS!
#42
yeah worked out great, totally happy with it. Only issue was the straight pipe was hitting the shield so I had to take it on the lift a second time but took 10min for the guys at the shop to fix. Camera was taped with some supertape I found at work, strong as hell and didnt leave a mark!! tempted to try some more filming....
#44
so now I am thinking precat deletes... total emission blower but I read somewere you can see 15whp with those things! I still have 3.5 yrs before I have to do a emission test so wtf not....
#48
Sandy Eggo
Honestly with the dynamax res I have absolutely no drone.. You cant really hardly hear the exhaust at all.. Having my GF or my mom in the car and they could not tell the difference from stock.. Only YOU will know..
#51
i had stage 4 and had a really annoying drone from 22-2700rpm on my 5AT. i ended up getting the stock resonator back on till i get my hands on a dynomax. anyone else get that drone? if you want to see the video's here's the link
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/videos-mid-muffler-resonator-delete-694501/
#52
$43 and 25 minutes later. Notice some improvement in sound. I like it. Worth the $43 for sure. I got prices of over $100 to the $43 I paid. One guy tried to charge me more because he said it would make my car fail inspection. not... it's not a cat it's a muffler. lol
#55
Learn to read...FFS
Stage 3.
(Tone result TBA)
Stock exhaust.
Remove mid-muffler. Replace with 2.5" straight pipe.
Remove stock resonator. Replace with Dynomax resonator part# WLK-24215.
Dynomax resonator is a 12" long resonator, which is a bit shorter and less dampening than the magnaflow resonator, thus it should give you a bit more loudness/tone than stage 2.
Cost: Dynomax resonator costs around $40. Install ranges from $60 - $90 w/aluminized pipping.
#67
AZ Community Team
Received 7,771 Likes
The correct part number is Dynomax 24234.
Whatever size that is, is what was originally recommended in Mike's (aznbo187's) thread on chopping the stock exhaust.
#68
OK I found the Dynomax #24234. 2.25" opening on both ends-$49.95
The Dynomax # 24215. 2.5" opening on both ends-$39.95
Strange, same exact length, diameter.
What diameter is our OEM TL exhaust? My car is at Acura having the body kit being put on, otherwise I would go measure.
#72
AZ Community Team
mglax, you are correct that in the original stock exhaust mod thread, Milke (aznbo187) started with the Dynomax 24215 (sorry, JD, I went back and re-read the thread and my previous post was incorrect).
However there was much discussion later on whether the 2.5" or 2.25" was "correct" or "better". Don't know that a concensus was ever reached, but I am sure people have bought, installed and used both with no issues.
I can vouch for the 24234 working on the TL-S - I've had it in for ~18 months.
Here is where a lot of the 2.5" v 2.25" Dynomax resonator discussion begins: https://acurazine.com/forums/showthr...=24234&page=18
Post #687:
i got my stage 3 exhaust done today.
JUST A NOTE FOR EVERYONE..
originally.. aznboi mentioned about using WLK-24215.. but the problem is.. the ID is 2.5 inches.. and our car comes with probably la 2 inch ID... so itz better off if you go for 24234 which has ID of 2.25 inch =)
this is only the case for people with stock exhaust! i mean.. if you have comptech cat-back.. you might wanna measure it.. and i am guessing 24215 would work best.
i will post some video/audio clips later =)
to recap
STOCK EXHAUST ---> use DYNOMAX 24234
to recap
#73
New shoes on my
Bearcat, I did not know that. Learn something new every day! That's why these forums are so great! I'm surprised that I never came across this since I searched "dynomax" about 20 times before I bought the thing.
Well I already have the 24215, so I'll go ahead with that since I don't feel like returning it to summit!
#76
AZ Community Team
Regardless, it doesn't really matter. Altering the stock exhaust gets you near 0 gains; it's more about changing the tone a little bit.
I think the real bottle necks are at the J-Pipe, the Cats, the y-pipe and the mid-muffler.
#77
I cut out all the resonators after the cats and added the atlp jpipe....got rid of the drone and got very nicely loud sounds better than any g35 junk out there...plus theres no tone to listen to at stop lights its just quiet until u go over 2000rpm
#78
I took mine too a local shop and they charged me $100 for deleting the mid-muffler and switching my stock resonator out for a magnaflow. But on the reciept...the mid-muffler delete came out to $20
#80
Another chance to order.. WHICH ONE ???
I just got an e-mail from MotorWeb.com that the Dyno # 24234 is no longer available.
I have a stock 2006 TL.
I am going to now order from Summit, I should have ordered from them in the first place but they were $10 more then MotorWeb.
Which one is the best to order?
#24215 or #24234
HELP.
Thankyou J.D.
