Just got an AEM V2 now...help on LI
Old 01-25-2009, 07:16 PM
  #81
I caught the mod flu
BLKURA's Avatar
For anyone who has a TB spacer and V2 installed, did you have to cut the intake tube in order to accommodate the intake?
Old 01-25-2009, 09:55 PM
  #82
New shoes on my
mglax13's Avatar
+1...That was my next question on all of this.
Old 01-25-2009, 09:59 PM
  #83
greco9885's Avatar
I think the purpose of adding the TBS is so there is an extra inch of air that can be held. Wouldn't cutting the intake negate the inch you just gained performance wise?
Old 01-26-2009, 08:01 PM
  #84
BLKURA's Avatar
I may be wrong here, but I don't believe that's how the TB works. If that was the case, the intake fabricaters would simply add 1" to their tubes.
The idea behind the spacer is simply to cool the air some.
Old 01-26-2009, 08:18 PM
  #85
greco9885's Avatar
How is it supposed to work? A throttle body spacer is designed to straighten the airflow snaking through the crooked plumbing of a vehicle’s factory air box and intake tubing. The idea is that the straightened flow is much more prone to efficient atomization, pairing better with fuel molecules and burning more completely than before. Some spacers even offer another twist: a machined vortex pattern in the surface that swirls the incoming air, much like the integrated parts in GM’s Vortec engines (you’ve probably also seen this in products like the Tornado).
http://searchwarp.com/swa235350.htm
I was wrong.
Its not for cooling, its right next to the engine = alot of heat
Old 01-26-2009, 08:22 PM
  #86
minkl81's Avatar
it was shortened a bit for perfect fitting with the bracket.
Old 01-27-2009, 12:07 AM
  #87
New shoes on my
mglax13's Avatar
About how much did you cut off? 3/4" for a 3/4" spacer?
Old 01-27-2009, 06:29 AM
  #88
JD TL-S's Avatar
I think the "Tornado" effect is whats supposed to help.
Is it worth getting with the V2 CAI ?
Does it whissle like the article said?
Does is really add HP on the Dyno on the 3.2 liter engine?
To make it fit the V2 has to be trimmed??? WTF
Old 01-27-2009, 01:07 PM
  #89
Rick_TL-S's Avatar
Received 1,239 Likes on 703 Posts
As far as I've read, the whistle may depend on the car and/or mods. And no, the V2 requires zero trimming. Mine was installed perfectly, & even without removing the front bumper.
Old 01-27-2009, 03:00 PM
  #90
BLKURA's Avatar
Rick do you also have a TB spacer installed?
Old 01-27-2009, 03:40 PM
  #91
ON DA LOW CAR CLUB
ac08odl's Avatar
why are you guys worring just install the thing y ou dont need nothning
Old 01-27-2009, 04:30 PM
  #92
SHAWD 04TL is in
TRIOD3SIGNS's Avatar
Dyno test! Dyno test!
Old 01-27-2009, 06:39 PM
  #93
ON DA LOW CAR CLUB
ac08odl's Avatar
yes dyno test because i think im pushin a lil more the 275
Old 01-27-2009, 07:59 PM
  #94
JD TL-S's Avatar
Well ?
Do You Rick
Old 01-27-2009, 11:27 PM
  #95
minkl81's Avatar
about half inch should do. but just in case cut quarter inch at a time and test fit several times
Old 01-27-2009, 11:28 PM
  #96
greco9885's Avatar
I am assuming you have a type-s correct?
Old 01-27-2009, 11:35 PM
  #97
ON DA LOW CAR CLUB
ac08odl's Avatar
no i dont have a type s.. but my car pulls man trust me my car chirps gears sometimes and its auto... maybe its cause i changed the air sensor? the car club in in had 6 tls and one type s and they only one that is fast is the type s and even the type s guy said he wants to run it with me one day to see if my car will keep up
  #98
Rick_TL-S's Avatar
No, I don't, but it's on the to-do list right after the J-Pipe & Race Pipe (followed by a dyno run).
Old 01-27-2009, 11:40 PM
  #99
greco9885's Avatar
so the intake and muffler delete gave you +/- 40whp?
Old 01-28-2009, 12:16 AM
  #100
Rick_TL-S's Avatar
Sounds a bit far fetched since the intake should only add, what, 5 extra horses at max?
Old 01-28-2009, 12:23 AM
  #101
ON DA LOW CAR CLUB
ac08odl's Avatar
im sorry, please tell me where i said the intake gave me 40hp?
Old 01-28-2009, 05:00 AM
  #102
BLKURA's Avatar
Zero trimming because you don't have a TB.
Old 01-28-2009, 05:16 AM
  #103
JD TL-S's Avatar
A dyno was done in a Magazine somewhere on AZ where a Comtech catback and AEM intake added 25whp to a 3.2 TL. I guess that would be about 29 crank hp.
08 TL-S 286 Crank HP
06 TL 258 Crank HP + 29 Crank HP = 287 Crank HP.
Plus if your 258hp+29hp 3.2 TL has a manual I would think it would be FASTER the an automatic 08 TL-S.
I had an 07 TL-S AUTO, and my current 06 3.2 TL manual feels faster with NO current mods except Stage III exhaust... BUT friday my V2 will be here!!!
Old 01-28-2009, 07:53 AM
  #104
greco9885's Avatar
You didnt, but you said you thought you were around 275whp. actual wheel horse power for the 3.2 is ~230. even at the crank i think it was 258 or something.
Old 01-28-2009, 08:01 AM
  #105
"Like None Other"
djbonsu's Avatar
04-06 manual TLs ARE FASTER if not just as fast as a TL-S....i have left a cpl in my day with NO MODS!!...lol
Old 01-28-2009, 01:57 PM
  #106
ON DA LOW CAR CLUB
ac08odl's Avatar
really only 230? so y it says 258 im lost?
Old 01-28-2009, 01:58 PM
  #107
ON DA LOW CAR CLUB
ac08odl's Avatar
what happen to the tl s?
Old 01-28-2009, 03:52 PM
  #108
greco9885's Avatar
258 is at the crank. The actual power going to the wheels is less. Alot of power is lost at the crank. Don't ask me how it really works because I have no idea lol
Old 01-28-2009, 03:58 PM
  #109
ON DA LOW CAR CLUB
ac08odl's Avatar
i was just about to ask you how does that work lol... damn so i only have 230 to the wheels... damn but 230 is kinda fast... i dont understand all this bs like 258 hp and 270 tork????? help
Old 01-28-2009, 04:04 PM
  #110
greco9885's Avatar
^^^Hahaha I honestly have no idea, and I don't want to make a bs attempt that will be fatally wrong.
But I do know, torque gets the car going aka low end, HP keeps it going aka high end
jmaxima03
09-27-2015 10:22 AM
kingbharj
09-25-2015 07:25 PM
Quick Reply: Just got an AEM V2 now...help on LI
