J35 12:1 heads/cam build, complete
#81
Ethanol? Was it high compression or did he just tune it to take advantage of the octane?
#82
No, Ethanol was his screen name on here. I'll have to find that thread from a few years ago where he was talking about running the Bisimoto stage one cams. You had some posts in that thread.
#83
All motor
I would expect at least 108 traps from this fully built TL-s. I trapped a best of 104.5 in 500ft DA, with most others in the 103.2 - 103.7 range. Don't forget the 106.66 in -2000+ DA lol.
Now that FlashPro is out, the rev limiter increase will definitely help. Mine is currently set at 7100 and it sounds awesome.
#86
Not to But here is a short vid of my freshly built 3.7
Driving with my knees, shifting with one hand, holding camera with the other. Hard to tell in vid, but 2nd i was modulating throttle to about 2/3 to minimize wheel spin, Around 70 i start going up hill until i let off in vid for traffic ahead. Throttle response is amazing. I need to get rid of the stock 3.2 throttle body and get my dual throttle bodies on and get my long tubes built yet
Sonnick (11-01-2013)
#88
I ask because compare it to mine, a J30A5 almost fully bolted.
#93
All motor
Adam, I tell you this all the time, buddy....it's too hard to compare speedo vids. I'm not sure what mods are done to the 3.7, but comparing acceleration vids of the same car are really hard to do. Sometimes, I've caught myself looking at speedo vids online, thinking "wow, that moves pretty quick," yet it's a video of a car going 13.9 @ 101. Point is, they are not an accurate assessment of speed.
#95
Since we're doing this, here's my ex's CL65 AMG Mercedes. I was filming with one hand which was kind of hard with 700+ hp from a dig. This video was meant to show how slow it gets when heat soaked but I never got around to making a video of when it was cool and making full power. It sucks I let off before 80 because that car pulls just as hard from 80-140 but it was a short street. It actually makes the same power as my GN but with total luxury. The downside is it weighs 1200lbs more than my car.
#96
In case the vid doesn't work.
#97
just a quick update on this -
I was talking with King yesterday because they are doing YAWSPORT's J35a8 build for their SCCA TL and I was curious what is being done - aside from the bottom end raising compression using some custom Mahle pistons, King sent the cams off to Megacycle for some R&D. I'm pretty sure it will be a completely custom cam.
Depending on the results of that, I may revise this build with one of their cams. These would not be regrinds.
the main thing though, is that there is R&D going on for custom cams on a j35a8, which is encouraging.
The following 3 users liked this post by i_love_cars:
#98
Problem is valve stem depression and the oem rocker arm ratio (roller diameter). A billet cam can only do so much if you cant generate any more lift due to usable stem height. The heads need modified as well as the rockers, (or heck, just replacement rocker design and head work).....period.
Has anyone seen Web Cam's replacment vtec killer rockers for B or K series motors? sick.
TBMotorworx might release this in 2014.....its already been done just not started up and ran!
#99
curious to see what TBM has in store, I will have to start following them.
#100
#101
^ hmm who can make roller bearings? I have my j35a8 ready to install. Just need to press in those stupid camshaft seals and make sure I don't install it in the wrong direction again.
http://www.timken.com/en-us/products...s/default.aspx
#104
Are you using the heads with the exhaust manifolds built in(it looks like you are)? If you ran ones without them built in and custom long tube headers I think you can see better gains. Just look at p2r's stock internal 3.2 build. It is making 300-305whp and over 270 wtq with only bolt ons and a tune.
King motorsport does good work but they do not know much about the j series. I have spoken with them on the phone about a N/A engine build and they warned me away from it because of R&D costs since they have never worked on the engine before.
That is why the price is so high.
#105
^ just the regular j35a8, budget is around 1500. Already had stuff PnP, another 250 or so for the gasket that needs to go in/replace, valve stems, camseals, and etc.
I also called King's and it was like 3200 for just top end build. That's pretty much the cost of a J36 parts only.. lol They do good work, but the money doesn't grow on trees.
Can't do j32a2 head since car will eventually go back to CA.
simione (05-12-2014)
#106
#107
Are you talking about the bowl area or the actual seat (angles??)?
It wasn't too many years ago when 330-350cfm was Nascar territory. That's badass for a streetable car.
#108
Im speaking of maching down the valve guides on the valvetrain side and performing a mapped CNC port job on j32a2 cylinder heads to achieve revised valvetrain geometry clearance for the rockers when equipped with new rollers, and peak flow. Im sure its also possible on the 2nd gen J motors (j30a4, j32a3, j35a8 to name a few) with just a bit less performance due to exhaust restrictions of the cast-in manifold. Yes, its awesome stuff and is already a reality.
#110
So what's wrong with a smaller base circle and longer stemmed valves in this engine?
#112
Curious, I'm looking at sending the RL heads (they're actually the same as 07/08 Type-S heads with RL cams) I just bought from andy there to be disassembled, pnp, decked (maybe bump compression) and re-assembled. Then I'm going to do the install work myself.
#115
$16k not counting the price of the car?? maybe it's because i do all of my own work, but i had $16k in my 2001 corvette making 540bhp and 500lbs of torque, counting the price of the car ($13k + $2k in engine, $1k in suspension)
still very cool this info is out there for this platform, and it shows what it takes/makes, so thanks for that.
#116
ah, just read the whole thing and saw how much $$ you lost in r&d, basically. christ that's horrible.
after all that, you should go into business like Bisimoto, just selling corrected cams and cam gears! i mean, you sound to be the ONLY PERSON on the planet that seems to have found this information first hand.
if it makes you feel any better, i turboed a FWD Altima years back, and wasted about $6000 in "this part is good" or "this part will work" or having a shop "finish it" only to find i had to undo everything. if i want unique in the future, ill swap in a domestic engine. i just hate dealing with the veil of unknowns, misinformation, and dishonest people that plagued my import work. maybe it's different if you're working on a gt-r, but for the normal day to day stuff, if you dont buy brand new and do it yourself (and even your post revealed that didnt work for you) you're taking a gamble
#117
#118
Then another 4k in cam labor that should have been about 1k in a perfect world.
Knowing what we know now, that build would cost probably 7k - basically 2500 for porting the cylinder heads, another 600 for decking, and another 1250 for cams. That plus the labor to re-install everything, degree cams, etc. would put you probably in the neighborhood of 7k.
all that said, the money is long gone now and I'm over it. End-of-year bonus time is coming up in a month which should put another 20-30k in my pocket, so I'll be picking up a few things for the BMW and possibly prepping the TL to sell for somewhere in the 15-17k range. We'll see.
#119
King wants a lot of money to port these heads, I got the 2500 quote from them as well and 2900 if they matched intake runners to the heads & IM gasket.
I got a much more reasonable quote of 600 + shipping from NVA-AV6 to have essentially the same work done by him. I know where I'll be sending them.
#120
^ i wouldn't say the same, since Paul doesn't bench each port to match flow. But its good for the money.
I had a local machine shop do my head and they did an A+ job with the valve job, hot tank, and gasket matching everything.
