J-Pipe replacement only real legal exhaust HP upgrade possible?
Two 3G TL Baller
Location: Coppell, TX (4 miles N of Dallas Cowboys' HQ)
Please pardon the following noob performance questions. I've been focused on aesthetic mods up to this point.
Between the pre-cats, J-pipe, and 3rd cat, from what I can gather, you get the greatest HP gains by doing pre-cat deletes, but it's illegal and smelly. You can also get good HP gains by replacing 3rd cat with a test pipe, but that's also illegal. So does that mean out of these three things, the only real legal exhaust upgrade is the J-pipe? I've contemplated getting quad exhaust to replace base exhaust, but that would make possible Ron Jon aero kit upgrade difficult I believe (RJ rear bumper replacement meant for base exhaust, not quad).
For you guys who do the pre-cat deletes and test pipes and live in a large metro area, how do you pass the emissions testing every year (or every other year)? Do you have to temporarily replace them with the stock pre-cats and 3rd cat every time, just so you can pass the emissions test?
Two 3G TL Baller
http://www.heeltoeauto.com/pitboard/?p=149
FYI, I was getting my info from reading this outline ("An Outline Of The Converter Layout On J-Series Honda V6 Engines") on HeelToeAuto's website. I know he sells the various ATLP exhaust component upgrades, which many on Acurazine consider to be top notch.
you will pass emissions inspections as long as your car isn't putting out an excessive amount of toxins. You can swap the exhaust system (ATLP Catback, Comptech, etc)
You can still get away if you modify the catalysts. You can replace the 3rd cat with a test pipe and put the shields back on, if the shop asks why the bolts have been touched you can say to fix an exhaust leak.
Fear and Loathing in my
From my understanding, there is not much of a HP increase by replacing the 3rd cat with a test or race pipe. It helps when the rest of your exhaust is upgraded to increase the flow. Just getting a test pipe and nothing else will not increase hp, maybe by 1 or 2 hp at most.
Chapter Leader (Central Florida)
If your state does a visual inspection, then youll have to follow the above ideas, however if your state just does a OBD plug and go, youll be good as long as you dont have a CEL!
Two 3G TL Baller
^ The several states that I've lived in thus far usually just clamp a sniffer on the tail pipe, and don't bother looking under the car.
I take it from the responses that I can replace all three (pre-cats, J-pipe, and 3rd cat) with higher flow versions that will probably pass the emissions testing as long as there isn't a visual inspection involved.
Without precats you have no chance in hell of passing the sniffer test.
When I was going to gut my 3rd cat I took it off first and drove to my friends smog station to have it smogged. It did pass but it wasn't all 0s across the board like when it was stock.
Gutting the 3rd cat does practically nothing performance wise.
Technically the J-pipe is illegal too since it's in front of the 3rd cat. You can't touch anything in front of any cat, at least not in CA, without a CARB or EO number. Most shops won't care since it really won't effect emissions and most won't recognize it as an aftermarket part.
The only legal options are high flow cats and it's iffy whether or not it will pass emissions with high flows in the precat position. Going from a 1,200 cell factory cat to a 300 cell aftermarket is a pretty huge change.
Personally I would do precats and a test pipe in place of the 3rd cat and swap it all out when smog time comes. If it's only visual you have to worry about, there are many ways to fool them. Being in CA where they can take you car away for running no cat, I chose to gut my existing 3rd car so visually it looks completely stock.
v 4910shp/19,600ft-lb v
As a side note: When I lived in NC, I passed the emissions test with all three PRO-cats installed (I know it's not an option anymore, but felt it worthwhile to mention).
just purchased my v3 jpipe from richie lastnight and he shipped it out today, and its saturday lol pretty pimp cant wait, wanna do precats next and wait for his exaust if it out soon
move to alberta, now test what so ever here, lol i took a drivers test like 6 or something yr ago, was hard lol
Former Sponsor
The exhaust system and the J-pipe will not effect emissions at all. The converters will and no matter what anyone says about passing inspections these parts are completely illegal to replace.
I would have a hard time believing this because it does make a significant difference on other cars. The major choking is in the precats for sure. But to say that the 3rd pipe doesn't do anything for power is not something I can agree with.
Except for the fact that it is all shiny and aftermarket-looking. And the emissions will test higher without that 3rd cat in there.
If you really want to have all of the mods out there including(test pipe, rv6 pre-cats, and j-pipe) and you don't wanna take them off when emmisions come around. DONT! Instead register your car in a small county where smog tests aren't required. Tell them you recently moved into your gfs apartment so the adress on your drivers license hasn't been changed yet. Just be sure to have memorized a random apartment adress in the county you're registering at, and that should be all the information you need.
BTW I tried this in Fort Collins, Co and it worked.
Good luck!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Of course I actually was moving into my gf's apartment in Fort Collins, so I didn't actually lie. But none the less, my idea still would have worked if I had, just don't expect a reminder to come in the mail when your registration is up.
Good luck!
Most any modification to a vehicle, especially exhaust related is illegal or will cause hassles. It all depends on the state you live in, and how much the local cops and shops know and care about the law. I know a guy that got a ticket for not having a muffler, on a 100% stock vehicle that came without a 'muffler' from the factory.
That said, I drove without any catalyst or mufflers for years in NY. One just needs to 'know a guy' and the visual inspection part is taken care of. Of course the computer needs to think everything is fine for the OBD portion, but thats really simple.
This is just my personal opinion and my plans for exhaust. I wanted to get a high flow cat and the high flow precats along with a j-pipe. I believe XLR8 has a version without the cat delete. I could change out my mods for inspection but honestly I would rather just keep the cats. I also don't want to deal with the smell or the yellowing you get on your bumper and exhaust.
I think most people who live in emission areas change back to stock or know people who will throw a sticker on.
IIDXholic
10-08-2015 07:53 AM
