Introducing RV6 V3 Precat Deletes Taking Deposits
#81
Might as well. Couple hundred extra bucks and a couple whp penalty for no smell and minimal, if any rasp. Most of the guys that get the deletes are going to end up spending close to the extra cost of the HFC's getting a resonator installed and then they'll end up losing a couple whp in the end anyway.
#82
2005 AM at/navi
#83
Being in Cali, you should consider the HFC's. I've heard that the cops out there are well trained when it comes to "sniffing out" cars without cats. I'd imagine it's a pretty stout fine for running catless.
#85
2005 AM at/navi
but believe me that is also a big reason why i never bought the v2. i do often find myself speeding so i guess im running that risk if i do get the v3. i want to see power difference between the 2 and maybe you're right i should maybe go for the hfc.
#87
Former Sponsor
BANNED
were rootin' for you richie!
can't wait to get these installed!
#89
All motor
If I had to guess, I'd say these would flow maybe 10-20% better than the V1/V2s. I say this because the flange is MUCH smoother inside. So I wouldn't be surprised to see another 2-4whp from these. Honestly, since the metal is thicker, I could also see the sound of air rushing through go away. With the thicker metal, this shouldn't be a problem.
ANX: Good point about the resonator install. However, if you go with a straight through resonator, you really shouldn't lose any power at all. Maybe 1-2hp. Depending on the resonator though, you are right.
I am excited about these. Slightly more power plus less "air w00shing" noise?
Richie, have you decided what to do on the V1/V2 trade in? Would we get the V3s first, install, then send the V1/V2 back? Or the other way around? Or, send you a larger deposit to get the V3s, then once we ship out the other PCDs, get the money back?
#90
For others reading this - the ting sound of the prior V2 was not a problem. It is just that the ting sound confused many new PCD owners after listening to their car idle for the first time with the PCD. They would wonder where that ting sound was coming from and they would erroneously think that it was an exhaust leak.
All "thin metal tube" headers on all engines have a ting sound at idle. It is the shock wave from the exhaust gas rushing out of the valve and hitting the thin metal tubing and making it ring/ting (just my theory as to the cause). However, the thick casting of the V3 will not ting.
#91
Richie, I'm finally back from Iraq! Hitting you up on PM for the v3 as previously discussed. However, with your new HFCs starting to roll out, I may be sending more $$ your way than previously anticipated!
Could I get an estimate for the HFC (with their cores, obviously) and the ceramic coating? Is this coating sufficient to contain the heat, negating the need for the heat shields (ie more weight reduction)?
#94
Former Sponsor
I don't have all the details worked out yet. I am thinking are around $120 for the V2 and $190 for the V1 upgrade. I will need some type of deposit or the old parts back first.
#95
I was thinking along these same lines as well. I've only been here three years, so I came toward the end of the whole Procat era, but I know the cars with them were making gains similar to what the PCD's make.
#96
All motor
Don't most cars with HFCs (350z/G35/370, etc) make more power with test pipes? Albeit 2hp or so, but still.
#98
2005 AM at/navi
wow more low end tq from the hfc would mean better acceleration right? hope this is so like a few here mentioned above because i feel so slow off the line. cant wait to see responses from members getting theirs on.
#101
BANNED
^yeah i hope richie can give us some updates as to the major difference in powerband between the pcds and the hfcs
#103
All motor
Guys, stillhere chimed in and said he thinks that the HFCs will produce more torque and almost identical power numbers. However, this is speculation. We won't know until they are tested back to back on the same car on the same dyno on the same day.
#104
Dyno will tell. The full deletes may make more torque; who knows.
And yeah, I'd guess most cars will make a little more with full deletes, but not much. What were the V1 and V2 good for on the TL, like 15 whp?
#105
2005 AM at/navi
haha, i know right. lol. but i just couldnt pass up on the deal i got these 20's for and they are actually really lightwieght when compared to the stock set-up, the only bad thing is about 1/2 - 3/4 inch more mass that i have to move off the line due to the larger circumfrence of the 20's. i dont want it for racing but if im gonna buy performance parts i do want it to benefit me the most in the low end. i do ocationally put my stock black painted wheels to mess around though.
#108
2005 AM at/navi
#109
Former Sponsor
Same as the PCDs we are just waiting for the castings to be finished. We are looking at early Feb.
#113
BANNED
#115
All motor
#119
When I saw this thread I had to take a peek. It's been awhile since I've done anything to my car. Looks like you may have given me the itch again Richie These HFC sound very interesting. I can't wait to see some dyno results. I think I may be on board for this.
