Installing catback soon, anything I should watch out for?
If you're doing a Comptech exhaust, be careful on the middle clamp (v-clamp?). CT's directions say to tighten until it wont tighten anymore (or something similar). Mine broke when I did so I ordered a new one, which I tightened until it was very snug.
Turd Polisher
Ifirahse, make sure you're in a comfortable work space with plenty of space between the ground and the car. I had to drive my car up on 4x8 beams with jackstands underneith it to insure stability.
Installing a catback exhaust can be kind of tricky with all the hangers.
If you hit a snag and get frustrated, just take a 20 minute breather.
Also, to make sure to coat the nuts with WD40 .. put a lead / copper pipe on the end of your ratchet to get the extra leverage. Same can apply for putting it on .. you want the nuts SNUG!
Good luck man, enjoy your new catback
94 DC4 RS LSV/Turbo
Also dw40 on those rubber hangers let's you pop them right out, and pop the atlp right in
The 3rd cat bolts will be the toughest, for easier comfort you should unbolt the driver side muffler first although it is not required
07 TL type S NBP!
Took me about 2.5 hours to jack up the car, do rear camber kit install, then catback install. Everything was pretty straightforward...remove old parts, pop in the new ones.
I was dreading the 3rd cat, but my car only has 5k miles so it was easy.
Also,for some reason the tips aren't uniform, meaning one side kinda sits lower than the other, but that can be easily fixed with some hanger modification next week.
It feels good working on your own car and not paying someone to do it for you.
LIST/RAMEN/WING MAHSTA 짱
For some reason, on our cars, the canister on passenger side rear always sits a bit low.
BoricuaTL
04-08-2016 01:08 PM
