Installed TB Spacer...Dont make the mistake I did
I just installed my TB spacer about 30 minutes ago. Thanks Excelerate!! Anyway just thought I'd let you know one mistake I made so you dont do the same. After I completely installed the spacer (bolts tightened and everthing ), I realized that one of the gaskets I installed was on backwards. (The white heat gaskets that come with the spacer.) I made sure the indentions were all facing up like the video but didnt realize that it was possible to put them on backwards. After I got it all together I realized I needed to turn one of them around. Pretty minor to fix but it did add a lot more time. Other than that it went together like a breeze!
AZ Community Team
Received 7,770 Likes
Ahem .... :cough: :clearsthroat:
.... - Play with the Spacer and Gaskets a little when you get them. They are not symmetrical; the thermo gaskets only fit properly one way, they have a "front" and a "back". Just make sure the bolt holes and the notch all line up.
https://acurazine.com/forums/showthread.php?t=172288
3G Garage FTW!!
3G Garage FTW!!
Make Nice, Not Rice
Damnit, so I installed this morning, and I turned on the engine before attaching a hose back onto the intake. Car was revving awkwardly so I shut off, checked, and slapped myself in the head. I connected everything back and double checked this time, and the car still has the CHECK ENGINE light on. Is this going to go away?
Green Machine
There is an easier way to get rid of the CEL and you dont have to enter your codes after. Simpley pull the ECU fuse for 5 -10 seconds. Does the same thing, but doesnt cut power to the radio.
Not sure, I just got my car a month ago and havent even begun to check that stuff out. I would assume its in the engine bay, but look in the owners manual, and there should be a break down of where all the fuses are.
black on black 04 TL 6MT
i don't know if this will help, but when i installed my cold air intake, it threw the check engine light. this bothered me at first, i then took it for a drive and had an idea.
i got onto the freeway on-ramp and cracked v-tec.
check engine light gone.
the end.
the end.
AZ Community Team
Nevermind.
cycdaniel
12-17-2019 10:58 AM
johnpancakes014
04-08-2016 06:47 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
