Innovative SIDE Mount Install Advice
Old Oct 6, 2008 | 10:36 PM
nibalm3's Avatar
For the past weeks I started feeling some massive wheel-hoop; during hard acceleration or just by the quickl release of the gas pedal... So, I figured that some engine mount was broken.. I ordered the innovative mount setup 60a many of us are bragging about (75 and on, are for hardcore and will take the luxury away by adding more rattles and vibrations than we already have)..
Me and my mechanic started at 10am and finished exactly at 1:20pm .. We started with the b*tchy one, the scary REAR MOUNT.. Yes, it took almost 2hrs. after using many extensions and adapters.... NO NEED to remove the sway-bar or radiator, pass.fans or disconnecting battery or any other items. like other post I've read (we only un-snapped the power steering plastic bucket, BUT DID NOT disconnected any Hoses)...
During Install I came up with a problem that you will need TWO Shorter BOLTS for the SIDE MOUNT.. I'm ordering two of these, I'll tell you if did the work next week...
Part#
95701-10045-08 Bolt, Flange (10x45) ..
The original bolts (10x60).. are too long and you will damage the thread of the case if used.. In the meantime I used two big nuts I found as spacers while I receive the (10x45).. You may also need a small hand drill to re-install the ground wire on the mount, since the innovative mount does not have a hole. Here's a Pic Hope You can see:
http://pictures.sprintpcs.com/share....tate=RETRIEVED
I LOVE the Mounts, Kind of more cabin rattle while in "D" on a red light "ONLY" .. That's it... While doing the install TWO of my mounts were defectives "REAR and SIDE" OEM SHITTY MOUNTS . The front was almost intact, but I replaced it anyways.
Besides that, I realized that my upper tranny mount was gone too..
THESE Acura MOUNTS REALLY S*CK.. I will also order the Lower Tranny mounts just in case (Front and rear).. Giiiiiiiiizzzzzzzzzzzzzzzz...
My Bill so far:
300 innovative mounts
65 in all tranny mounts/Bolts acuraoemparts.com
150 Friendship Labor...
= Hope nothing else for the next months or so...
Take Care
Old Oct 7, 2008 | 11:08 AM
ussi's Avatar
I (don't) whine.
Good info. I did not know that about the shorter bolts for the side mount...I still have to install that one..
Old Oct 7, 2008 | 12:46 PM
BLACKURA_NY's Avatar
I have car ADD
Hmm... i didnt seem to have problems with those bolts.. and i removed the side mount twice after initial install
Old Oct 7, 2008 | 02:20 PM
ABP_04TL's Avatar
6-SPEED LOVER
can sum1 clarify on how would dis b a good mod 2 do
Old Oct 7, 2008 | 03:08 PM
I have car ADD
^ wheel-hop... when you floor the car, and you feel/hear the front wheels thudding, and jumping... thats REALLY bad for your car, and can do alot of damage.. wheel hop is minimized tremendously, smoother shifts, less engine movement...
only downfall, is the vibrations.... you can feel/hear those inside the cabin...its all good to some, i surely didnt mind
Old Oct 7, 2008 | 03:40 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
yo evan ur like tom (enigmaos) going hard doing research before doing the mod, like the opposite of me, i do the mod then the research rofl
Old Oct 7, 2008 | 04:15 PM
ABP_04TL's Avatar
6-SPEED LOVER
LOL
Old Oct 7, 2008 | 10:13 PM
nibalm3's Avatar
I have the big big oem part install/manual.. and you can see the side of the bolts (10x60).. Measure the width of the oem mount vs innovative, and you'll find out.. Maybe it's too late on ur case and your powertoll already threaded more inside your casing..
here's a link . hope you can see.. Part#30 attach to part#5...
http://estore.honda.com/asp/showrepairblockimage.asp?popup=1&strImageId=SEP4B4 701B.png&&popup=1
Part#5 OEM, has slight larger height (where the screws goes of course) than the innovative mount... That was my issue..
Tuo capisci ?
Old Oct 7, 2008 | 10:17 PM
nibalm3's Avatar
Homework for tomorrow:
since you have not done the install yet,. can you pliz measure the side mount vs the oem.. and confirm please, cuz I took it side by side and innovative mount was about 0.75" smaller if I remember..
Old Oct 8, 2008 | 04:00 PM
ussi's Avatar
I (don't) whine.
^ I don't have my car its in the shop (again). You want me to measure the side mount height against the oem mount height - is that right?
I do remember my mechanic saying that the my OEM side mount isnt perfectly aligned with my other mounts, that the innovative mounts actually push the engine up slightly, but other ppl who installed said this wasn't the case....anyways....
Old Oct 9, 2008 | 04:52 AM
Kennedy's Avatar
OMGWTF4THGENTL
That's wierd... I agree with you that appears to be an issue, but I dropped the side mount on 15 minutes and never noticed this. I don't think anyone has noticed this yet...
If you snug those bolts down, the milled aluminum bracket mount would be loose, and that would not be good.
Old Oct 9, 2008 | 10:52 PM
Inaccurate's Avatar
I spent the last hour invesigating this issue.
IT IS AN ISSUE !!!
In my case, I found that the bolt was barely, barely short enough. The bolt seemed to be bottoming-out at the same moment that the proper tightening torque was reached.
However, the bolt is not bottoming-out the way you think. The blind hole that the bolt threads into is actually 1/4 inch longer than needed. The bolt is bottoming-out at the shank. I placed teflon tape on the threads and torqued the bolt. When I removed the bolt, here is what I found.
to fix it, I used a thick washer for one bolt.
For the other bolt, it has a grounding cable on it to provide clearance. So, I don't think that my bracket was loose because of this grounding cable. Plus, while tighten this bolt during the install, I know it was not bottoming-out because I watched the bolt crushing the ground cable as I tightened the bolt.
Old Oct 9, 2008 | 11:22 PM
Inaccurate's Avatar
Just went back outside to verify the fix. I used the teflon tape again around the bolt. With the thick washer, the bolt is no longer bottoming-out at the shank.
Old Oct 13, 2008 | 02:22 AM
ThezeSkillz's Avatar
NOT my TL or ME
Thanks!!!!
Old Oct 13, 2008 | 05:05 PM
OTSB708's Avatar
Well, I'll be getting some washers to fix that now....
Old Oct 13, 2008 | 05:29 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Nice, I'll have to keep this in mind...
New bolts, or get some washers, what do you guys think?
Old Oct 13, 2008 | 07:34 PM
Excelerate's Avatar
Former Sponsor
Good info to have and very observant of you.
Old Oct 13, 2008 | 09:32 PM
Kennedy's Avatar
OMGWTF4THGENTL
Considering this issue... anyone else think Innovative owes us a couple of proper fitting bolts?
Old Oct 14, 2008 | 12:17 AM
THERUIZFAMILY's Avatar
4th Gear
What is the washer's thickness ?
Old Oct 14, 2008 | 12:02 PM
pinina's Avatar
I agree, It should have come with the mounts.
Old Oct 14, 2008 | 06:05 PM
4th Gear
We're better off just getting the size and buying them at HomeDepot considering they're going to cost around 50 cents a piece
Old Oct 14, 2008 | 08:40 PM
Inaccurate's Avatar
Mine is 0.100 inch.
Old Oct 20, 2008 | 08:57 AM
RACINGHART03's Avatar
A word of advice to all you mount installers. At the meet this weekend I noticed a bunch of guys with the side mount installed and the small ground tab floating around in no where securely mounted land. I would have to say that this is a serious design flaw if Innovative does not provide you with a relocation strategy. Maybe they do and no one did it I dunno. When I blow my mounts out and install these I would drill a small hole in the top of the side mount. Tap it with a 6x1.0 tap and make it nicey nice.
Old Oct 20, 2008 | 12:00 PM
94 DC4 RS LSV/Turbo
^ I wish I had a glance at who had it in nowhere's ville, I tucked the ground wire under one of the bolts metal to metal
as for that bottoming out issue, it is news to me I've done the install 3 times and torqued everything down nothing was left loose, guess when I get under wanderer's engine bay I know what to check
Old Oct 20, 2008 | 12:02 PM
Lookout Al!
Old Oct 20, 2008 | 12:06 PM
In the event I was maimed in a freak accident and lost my hands, and had you install my mounts, you know damn well that wouldnt fly with me. Heres another one oh wait....stand still anddddddd hyughhh
Old Oct 20, 2008 | 12:22 PM
94 DC4 RS LSV/Turbo
o'cmon bro thats fine location for it
Old Oct 20, 2008 | 12:40 PM
Cmon Al. I am taking you to a broadway show..The Rockettes!!!
Old Oct 20, 2008 | 12:46 PM
94 DC4 RS LSV/Turbo
this is what happens when honda's are reliable... the techs go on azine
Old Oct 20, 2008 | 12:49 PM
lol. When the Economy is in the toilet and no one fixing their old cars, buying new cars, or even spending money on gas to show up.... Bored techs who have computers in on their tool boxes go on Azine lol.
Old Oct 20, 2008 | 04:37 PM
OTSB708's Avatar
This is where I relocated mine to:
Old Oct 20, 2008 | 04:55 PM
94 DC4 RS LSV/Turbo
it is different on the accord for some reason lol
Old Oct 20, 2008 | 04:59 PM
OTSB708's Avatar
lol figures!
Old Oct 20, 2008 | 10:17 PM
Inaccurate's Avatar
Regarding the ground cable.
I used this as an oppurtunity to upgrade the ground. I bought an Everstart brand cable (16" length) from Walmart. The eyelet was the perfect ID for the bolt shank.
Old Oct 21, 2008 | 07:29 AM
Here is a fine example on how to ground a wire Al.
Old Oct 21, 2008 | 02:02 PM
4th Gear
I did the same thing as Incacurate for my grounding wire and then I tucked in the previous ground that attached to the inside fender wall. For the washer issue I used a 1/2 pressures washer from Home Depot. The washer was only $0.16 ...I have a V6 Accord automatic so I'm still getting more vibrations than I would like.
Old Oct 23, 2008 | 09:44 PM
Inaccurate's Avatar
Here is the info for the ground cable that I used from Walmart.
They are found in the Walmart auto department where oil and oil filters are sold.
Look for the green colored package called Everstart "Lawn & Garden".
You want the 19" length and 6 gauge.
The UPC barcode number should be (the last group of numbers) = 11196
Old Oct 24, 2008 | 12:07 AM
94 DC4 RS LSV/Turbo
Old Oct 24, 2008 | 01:09 AM
04accordcpe's Avatar
347hp/300tq @ 4psi
wait a minute! what is stopping you guys from relocating the stock ground wire like me and OTSB708 did??
his,
mine,
isnt your guys TL abs bracket in the same place as ours accords??
Old Oct 24, 2008 | 02:22 AM
94 DC4 RS LSV/Turbo
I dunno but I like innacurate's relocation lol
