Innovative Mounts Review
#362
18psi
if you dont plan on ever putting the oem mounts back in the car then just pull out all the vacuum lines, take that little vacuum module off the back of the intake manifold and put a little rubber cap over the nipple on the manifold.
If you want to keep the lines then use zip ties to seal them and make sure they are tight so you dont have a vacuum leak.
As far as the ground cable is concerned for the side mount, install it the same way it originally was in the new mount
#363
takin care of Business in
Received 4,732 Likes
^^^ this
well explained
well explained
#365
to be honest I thought the engine sat lower.....
a lot of people on the forum installed the MDX spacer (had stock mounts) and had to cut their hood in order to have the spacer fit but I installed it and didnt have to cut anything....
#367
WOW....i didnt notice that....i did notice the mdx spacer but well....any reason why you ask ?
#369
312 HP 271 TQ Dynapack
IM mounts update;
My mounts just recently busted! I have the 65A, I believe. havent removed them yet, but judging by visual, the rear mount looks like its sagging, front mount bolt that connects to motor is missing, (most likely broken off), and both side mount bolts broke off clean. The engine seems to be sitting like 3/4 inch lower right now...sucks.
I noticed something wasnt right when I started feeling some erratic and heavy vibration, (heavier than normal) and when starting, the engine will jolt pretty bad.
Back to the lab again....and I just recently took the s/c off for battery replacement, now this.
I hear there's a significant reliability issue with these? Sorry, but I havent kept up with the reading. What other options are out there, if any?
#370
just did some reading....looks like the best thing for me to do is go to IM for warranty exchange and upgrade to 75A. According to Exelerate's HP guidelines, I should've picked those up in the first place.
Scott,
I see you upgraded to 85A last year? How those holding up?
Scott,
#371
75A is good enough until 350-400hp....now if your gonna throw a turbo in her and or track her, go 85A....
#372
Scott,
Scott,
#375
LIST/RAMEN/WING MAHSTA 짱
Scott,
Scott,
But, you know I'm a track addict.
Too bad we never went, Mario!
#376
3M Window Weld
List Mastah Hyung!
Hope all is well. Any Orochon #2's lately?
APC miss you.. don't be a stranger.
#378
Former Sponsor
Well, if the Innovative mounts aren't working out for some of you anymore feel free to check out our XLR8 mounts. Our bushings have a much larger surface area and therefore 75A should be the most anyone needs.
http://store.excelerateperformance.c.../i-300870.aspx
#380
So here's the status on my bushings....done! :
Took only like 90 min to pull them out, no broken hardware to drill out from the front mount, like I suspected, didn't have to pull the blower out (yaaAAaaY!!!) And Innovative has the 75A's ready to go. They say they will replace all bushings and broken hardware, no prob.
#381
#383
Scott probably bought a mazda..
Innovative Mounts = Garbage. I said it.
#385
Ownership and receipts don't matter. they are warranted for life. As long as the mount bushings say "innovative" on them, they'll swap them out for ya. They are in Anaheim, so I just drove up with bushing assemblies and broken bolts and they swapped out the bushings (upgraded to 75A) in 5 minutes. The hardware they gave me wasn't great (grade 8.8, no flange) but I can get em somewhere else. They're super nice people, no questions asked. Give them a call, I'm sure you can ship or make other arrangements.
#387
^^^ think you should....even if they are 60A and you wanna go for 75A, use the 60A for a while and as they donut, order the 75A replace the 60A with 75A....ship the 60A back to Innovative and get your money back (what you paid for new 75A bushings)
#389
^^^ was waiting on a review....i might get mine switched out as well....
#390
N0w $hiftinG N/A
mrlunecy congrats on the new mounts bro. im here waiting for the review on the innovative 75A mounts since im ordering a set soon so im debating if to go with innovative or xcelerate 75A. I previously had the 62A in my old 05 A/T TL and since it was auto the vibration was pretty shaky when coming to a complete stop. Now since im 6mt vibration at a stop would not really be any concern and as far as HP goals if u might ask what kind of setup so i do it once and right the first time im aiming for 340+ might stay N/A running meth and nitrous.......
#393
I love the solid feel it gives you when you crank it up and when you get on it the shifts are soooo much smoother I love em I hope I dont have to swap emout for the 75a's anytime soon..
#395
I took the motor mounts outafter a few weeks and they already were failing... And I have an auto... I guess I will upgrade to the 75a's but I loved the way they felt in my car
#400
