How to UNLOCK the speed limit 135mi/hr??
Your Friendly Canadian
Received 1,484 Likes
Um, I don't think the ECU cuts the oil. That would result in a simultaneous and catastrophically epic destruction of your engine at 135 mph. IIRC, the cars are DBW, so the ECU just cuts the throttle.
Only way to go around it is an ECU reflash I think, but those aren't cheap.
The ECU cuts the fuel at 135Mph because the Type-S' 5AT is sourced from the '05-'08 RL which is also governed to 133Mph.
My first question is why? Unless you can drive on the autoban why?
I think 135 mph is more then enough. The car feels weird at 100+ already and you want it to go even faster?
runnin a little boost
The 06 six speeds don't cut out until 155+. That's a scary speed to driving the TL at, the six speeds do have stiffer suspension and sway bars, but 155 is scary going straight. ( I hear). Also the CHP use planes on hiway 5 that track you and ground units who make the stop, not a good place to be doing top speed runs. The plan spots you and times you from one mile marker to the next figuring your speed, they like to use the freeway over passes since they are easy to see when you cross over.
Sorry, but if there's no "chip" for these cars. If there is, you'll hear about its breakthrough on AZine first.
I think the only way is rewrite the ECU........guessing
J36Twingt28r's,nextgt30r
yup no chip for out cars. the only chip i can think of for a j-series is this one http://www.aemelectronics.com/series...a-j-motor-1112
however, since we all have dbw the above chip/ecu cannot be used for our application without custom speedometer, cable conversion. even with it TCS, and ABS would be lost.
Look at the KPH lines on your speedometer. Then you'll feel like you're doing 200!
Seriously before you get yourself or someone else killed I think you can live with the limiter.
All motor
Unless you're doing 135 on your daily commute, there is absolutely no reason to remove the limiter. Do you drive that fast normally? Is this a routine? I sincerely hope not. Do you know what your car would look like hitting anything @135mph?
Not to mention what YOU would look like.......you'd be in more pieces than the car. Please drive safe.
I'm not gonna lie I took my car to where it doesn't accelerate anymore once on a similar road which was straight as an arrow with 0 cars. Doesn't mean it's okay.
No offense, but I find it a bit strange you're giving him criticism on speeding & what he'll look like in an accident when you're one of the most active topic starters about what car you just street raced against.
That turbo though.....
Is that a jet?
how old are you ??
2006 6spd
i've went 130 before!!! and man i cant wait to go faster!!! im gonna go try my top speed again right now ill be back and let yall know if i can beat it!!! (LOL LOL LOL YEAH RIGHT!!!) ive done it once why the hell would i wanna try in again!!!!!!!!!!!:ugh ::ugh ::ugh :
yeah keep trying your cool!!!!!!! N O T !~!!!!!!
There are computer add-ons that will allow you to go past the 135 that is limited, but why go that fast on a daily commute? Granted we all want to go faster but is it worth the risk to yourself and others? The limiter is in place to keep people such as yourself from killing other folks. Have you ever driven past 135 and see or experienced what can go wrong? DO you know what to do when something does go wrong? 98% of the population doesn't and that 2 percent that does will go past 135 in something designed to go past that and that doesn't have a limiter.
I always wanted to see how fast i can go in my TL-S but im always scared of getting a ticket. Fastest i went was 100 mph. and started to slow down after about 5 seconds.
Veni, vidi, vici
y do u need to go more then 135 mph? unless ur running from the law, or running from a crazy x-girlfriend, then theres no need to go that fast. Besides it's all 0-60 times, any modern car can reach 135, it's about how long it takes to reach it, that matters.
All motor
None taken. Thought I don't reach speeds that high, if you think about it, the damage @100+ is really negligible. Meaning crashing @100 or 135mph will yield the same result so you're right.
05 NBP
i'm not going to argue about crashing at 100 vs 135, they aren't the same, but both are most likely going to kill you. However, the time you have to prevent that crash is much lower going 135 than 100, it's pretty low at 100 too, but lower enough at 135 to make a notable difference.
