got my atlp j pipe... has a bend
Email mike to double check if that's meant to be there. When I got mine I thought it was damaged with a small flat spot but it was just fine. I have a feeling that is on all of them so you should be ok
My Garage not
1 Post
never use your fingernails you're going to scratch the heck out of the crappy acura paint. use a hairdryer and bug and tar remover and u can roll the glue right off with your finger.
to lateee
i cleaned it off good though now you can tell nothign was there.
on the j pipe we had fitment issues
there was a dapaner thing that i think helps you save your tranny if you bottom out and we took it off i took pictures and will post when i get home
If you are talking about the black piece of plastic, most of us either just cut off the overlap or removed the plastic piece entirely.
This illustrates where the engine cradle damper is located.
Under construction
Just installed my V2 J-pipe last night! No issues but I didn't get a chance to really test out my car. Will be doing that tonight along with reseting the ECU.
Johnjohn, how long did it take you to install? I had access to a lift and it took about 20 minutes
acurajj
02-14-2016 02:28 PM
IIDXholic
10-08-2015 07:53 AM
Billu99tl
09-13-2015 11:30 AM
