Going to try methanol injection...
I finally made up my mind to do this. Long story short, took my GN to the bodyshop, heard some suspicious things, got it towed back home while I was out of town and what I got back was a shell but fortunately still has the mechanicals. That's a lawsuit and a whole different issue.
What I've decided to do is pull the methanol injection off the GN until I get it up and running again and try it on the TL. I'll have to change some settings, like the kick on point to ~0 vacuum vs 5psi boost. Not sure how I'm going to prevent it from discharging with the key on and engine off yet.
On the GN, there are two benefits. Higher octane and cooler charge temps. The latter is what I'm going after on the TL.
The pump is capable of 300psi and I was using about 20% methanol for fueling. Going to have to find a much, much smaller nozzle for the TL so I don't drown it.
Here's why I want to do it. I have tons of data logs from testing it with everything from water to water/alcohol to methanol. Methanol gave the best cooling and the TL hates heat.
On one pass, ambient was 80 degrees. Turbo outlet was nearly 280 degrees at 26psi. Intercooler outlet was 120 degrees. Air going into the throttlebody after a fine mist of methanol was 45 degrees. So basically it took 120 degree air and knocked it down to 45 degrees
It may or may not work on the TL but it's free and I'm bored. I can't spray nearly as much since there's no way to back off fueling so cooling might not be as great but the potential is there to have winter power in the summer. I'm also going to play around with 87 octane and injecting it at a lower throttle %.
As a side benefit, running a little water through it every now and then does the same thing as seafoam. I tore down one of my motors at 25K and there was no carbon on the turbine, headers, heads, or pistons.
'06 750Li Sapphire/Creme
"TL hates heat"? Turbo? Whatchu talk'N 'bout Willis? All that makes sense on the GN but the TL isn't really a heat sensitive creature. Oh yea, and the high 10.5:1 compression on the TL is VERY sensitive to boost so if you DO meth your 3rd-gen TL, you''l probably be back on here "crying in your beer". But, since your board... let us know how it works out for you in the end
Uses turn signals in my
Italiacls on the 2nd Gen CL (where I'm at) is running meth injection on his supercharged CLS, he has a couple of threads about it that may give you some information to help you out since our engines are pretty similar. I don't know too much about meth injection myself, so I personally can't help you there.
B A N N E D
I am running meth injection and it's been nothing but great. Intake temperature would stay steady at 80~90F under boost. Also it allows me to run a pretty aggressive timing with its octane boost.
it's me, Alan Rickman.
Are you trying to blow the fking car up before you trade it in?
Your last few posts have been off the wall modfications and changes to a car you don't appear to like...
we have used it pulling tractors for years. most just use water. diesels would run 4-5 gallons of fuel and maybe a gallon of water on a 300 foot run. guys are running 3 to 4 turbos too. heard horror stories of a guy that thought nitromethane would be interesting. instant ruin your motor so just dont do that!
Former Sponsor
AEM just released a similar setup:
The AEM Water Injection Kit is a safe and economical way to reduce air
inlet temperatures to increase boost pressure for more power in your
DSM.
Lower air inlet temperatures allow users to advance timing without having to
run higher-octane fuel. This is the most complete kit available on the market
straight out of the box- no additional parts required.
AEM 30-3000 WATER INJECTION KEY FEATURES:
• Includes everything you need for installation
• Progressive, controller-driven 150 PSI pump
• One-gallon tank with integral fluid level sensor
• Dash light for system status and low fluid warning
• Alcohol Compatible (up to 50% in solution with water)
• Progressive controller, provides boost-dependent
variable flow
• Output provided to either decrease timing or boost if the system runs out of
fluid or detects an error
• Includes three jets to match your power requirement
It's going to be about $425 shipped.
DSM.
variable flow
For "alcohol" injection can't you just use windshield washer fluid (concentrate)? And if it's too rich, just water it down? I've looked into it before. It's cheap, effective, safe, and not car specific.
http://www.snowperformance.net/products.php?p_cat=324
Always inject methanol after the blower/turbo. It's hard on aluminum and sometimes not compatable with supercharger seals. It also gives maximum cooling with the hot discharge air vs ambient incoming air.
By injecting water into stock TL engine you will get nothing. Actually you will loose some power. If you supercharge it and get boost to the limit you will still get way more by using proper intercooler and high octane fuel than by injecting water. Methanol is useless there anyways. Its cooling capacity is smaller than water and it has 20% less energy than gas. Octane number boost is not nearly enough to compensate for that.
I (don't) whine.
Originally Posted by ussi
I just installed the snow methanol kit to spray in through my CAI, you think I should move the nozzle to behind the SC?
Methanol vaporizes in the intake tract drastically cooling the air. Water vaporizes in the combustion chamber which would do nothing on a NA car. I have data logs of methanol, water, alcohol, and a combo of both. The methanol cools intake air by over 70 degrees.
- By injecting anything anywhere in between air inlet and valves you are reducing amount of air going into cylinders - equals less power.
- Methanol lowers temperature but takes some oxygen to burn. That leaves some gas unburned and that gas contains more energy than burned methanol - equals less power.
- Methanol takes less energy to evaporate than water, so it lowers temperature less than water – equals less power.
Originally Posted by csmeance
inject it on the part of the blower that attaches to the throttle body/intake manifold.
Yes.. You will see a huge difference after the blower. It will make a much bigger difference cooling 300 degree air than 90 degree air.
Sure it does. But that is not all:
It displaces some oxygen but it's proven not enough to make a measurable difference.
I'm thinking of using it strictly for the cooling effect. It doesn't take much to signifigantly cool the charge air. Not using it for the octane.
Methanol will always lower intake temps much more than water. I have logs to back this up. In fact water didn't show a difference of more than 10 degrees on the guage. Methanol completely flashes in the intake tract. Water enters the combustion chamber in droplets so it doesn't release much energy in the intake tract. I've spend many hours trying to get the best results on pump gas. Regardless of theory, methanol lowered temps 7X more than water.
If just enriching the mixture would provide the cooling effect of methanol, everyone would be doing it. Fuel injectors are aimed at the intake valve and all the fuel doesn't have time to evaporate and cool the intake charge.
I don’t think so. Same amount of injected methanol (no matter what I think about it) will take same energy to evaporate wherever you inject it. It may not evaporate that quickly if you inject it before buster, but it will eventually. Resulting temperature will be the same.
I believe that your results are accurate, but you actually do not care about temperature in your intake manifold. You care about temperature at the end of compression cycle and by that time all water evaporates taking about three times more energy.
Actually everybody is cooling mixture by enriching it. That’s exactly what all engines are doing at full throttle – enriching mixture by up to 15%.
Originally Posted by I hate [url="#"
cars[/url]]Not true. Again, got the data to back it up. I've injected pre-turbo, tried a dual nozzle setup with pre and post turbo, and just post turbo. Post turbo showed a much, much bigger difference. Pre turbo benefits are mostly octane related, not cooling.
uh... I may not be that good with cars, but from what I have seen and read all these years this is what I think. A supercharger makes the air hotter when it is compressed, right? Well if it does, cooling it after compression would make more sense rather than cooling it before compression, as it will become hotter. Second of all, injecting methanol/water before the blower can cause damage to the blower. Damaging a 5K blower isn't the best thing. This is just what i can say after reading all of the stuff on the forum since I joined. Just to reiterate, I have no first hand experience with this, this is just based off of reading stuff. A-Train, you should comment...
The reason I think it will make a small improvement on the TL is I gained power on the turbo car without turning up the boost.
You have to take into account water doesn't burn and methanol does. Water will make a NA car lose power.
Again, when injecting methanol we always do it at least 12" before the throttlebody. This gives it time to cool the air. Fuel injectors squirt right on the intake valve or in the combustion chamber on direct injection motors.
Last, I probably wouldn't bother trying this normally but I already have the kit, the GN is down for the year, and I'm bored.
This is what I wanted to say but I was running out of time. You are correct.
T
It could be that mixture was a bit lean so with methanol you just got it right. May be that it was knocking a bit so that sensor could not detect it. I doubt that TL has any of those problems. Another problem is how to measure it? Successive runs on a dyno would be the most reliable way.
I agree with that.
You just need time to evaporate whatever you are injecting and it has to happen before the end of compression.
Well I am not trying to make you not to do it. I just think that you will not get anything, but I may be wrong. At least you won’t be bored for some time.
I agree with that.
I agree with that.
I will say that I agree, gains will probably be very minimal and would not be worth the money. Just something I've wanted to try on a NA car for a long time now to satisfy my own curiosity.
I picked up .2 seconds on the turbo car without changing boost or timing. Granted, the inlet air was hotter than a TL will ever see so the gains might be less. Then again it was in the high 11s back then so I might see the same gains on a 14sec car.
It was, however tuned very well before. Audible knock detector and wideband 02 to monitor things so the meth didn't cure any preexisting problems. My TL for some reason needs octane. The surging came back today so I finally put some 100 octane and it seems to have cured the surging. Has to be knock. Unfortunately the octane is just masking the real problem...
Originally Posted by DMMTL A-SPEC
As close to the Tb as possible is best. Which nozzel are you going to use.
You could use a check valve to lower the pressure.
Sounds like a cool idea on NA,I ran it on my evo and it worked great with fail-safe built in..
Here is a good thread on Alky kits and flows....
http://forums.evolutionm.net/showthr...=292953&page=8
Good luck and keep us updated
My experience...
I hate cars,
N/A you're wasting your time. I think we established that part so we'll move on.
Boosted without an intercooler...yes it will help. How much, it really depends on a few factors.
Dealing with "other" types of vehicles on the dyno and at the track, the "other" vehicles showed tremendous air charge temperature drops from 60-100 degrees F. depending on ambient and the mix of methanol.
On one test with 7-psi of boost from an Eaton M112 blower and NO intercooler we saw as much as 110 degree F. drop in ACT's at WOT.
With the set-up I was using (intercooled M90S) one person tried to spray the methanol injection into the I/C brick (after the supercharger and after the intercooler heat exchanger). The results were less than spectacular but the ACT's dropped off another 40 degrees F at WOT with 9-psi of boost.
I say just use nitrous oxide. It cools the air charge and brings oxygen to the table. All you need is more fuel.
A-Train
A-Train
Originally Posted by Atrain
I hate cars,
A-Train
A-Train
I was leaning toward this when I had the surging problem as a way to cure it. Now that it's gone, this thing is dead. If I ever do any real mods, I may use my progressive kit for the fueling since so far there's no way to add additional fuel yet.
You've got to love methanol on the FI cars though. Nothing like running 28psi boost with the charge air cooler than ambient.
Nitrous would be the smarter choice on the TL but with my type of pesonality I would end up with a 250 shot before long lol.
Lol...
mishar,
Acura engine's do not follow the same laws of physics that other engines do, you know that right?
Yes...it's a gamble either way. Those connecting rods were damaged Naturally Aspirated.
A-Train
A-Train
Former Sponsor
