First AutoMeter shift light install on a MT TL-S (with pics)
today i installed an autometer shift light for my friend Scott or princelybug, as you might know him on the forum. he said he felt the need for it when he was tracking his car. "cant really take your eyes of the road" he said, this should help or assist him when shifting. oh yeah he kinda helped
the shift light gauge was installed in a modified S2K pillar pod, they don't make pods for the TL so i to Scott to get the S2K pod. it was close to our pillar. trimmed it down some used some heat to give it the correct shape of the TL pillar, then wrapped it in headliner material to give it that OEM look.
the gauge has a digital readout of the current rpm's, there are also a few other settings you could dial in. you could set and adjust the rpm shifting points to what ever you like when it reaches that rpm point the gauge lights up a pyramid of yellow lights, indicating when to shift to the next gear. wiring was straight forward, not difficult but time consuming. power, ground, and tach signal. our cars dont have and individual wire for the tachometer reading, rather a signal wire that goes to the gauge cluster with multiple info for the tach, speedo, fuel etc...
to remedy this we had to install a tach adapter to provide us with the correct tach signal readout, this adapter had to be wired in series to each of the six coils on the TL-S. this gave us the the individual tach signal.
overall the gauge light works perfectly i think the install looks really clean and tasteful. but most of all i think it looks cool
here are some pics of the install
here is the shift light gauge in a modified S2K pod
mock up install unwrapped
wrapped pod
drilled a small hole in the a pillar for the wires
tach adapter
power signal for each of the six coils had to be cut to wire the adapter, to reverse this it just a simple matter of soldering and shrink tubing. its only a small wire don't be scared.
crimped connectors for power side and coil side of the wire
coils wired in series to the tach adapter
small push button switch for power to the gauge light
i used some epoxy to mount the pod to the a pillar, looks pretty OEMish to me
outside view of the pod
comments welcome
wrapped pod
tach adapter
comments welcome
Whoa! That's pretty bad.
I actually like that setup, never seen one with the digital tach and light combined in one small guage. Very tasteful. How bright is it in the daytime? I like that it could be hidden out of sight. In my other car I have a shift light hidden in an AC vent. The downside is the vent has to be open when racing.
I can't believe you had to take a lead off of 6 different coils. I wonder why one wasn't good enough??
i called AutoMeter they recommended it to be installed that way. earlier model cars im sure wouldn't need every coil, the Dodge Hemi for example requires 4 coils wired in series. could be for a more accurate reading, too many wires in these damn later model cars.
^ that's what I was bout to ask you... the airbag question... then I figured you were the guy to ask (sorry) but yea... the curtains come out from the top right? So I can put my boost gauges and stuff on the pillar?
That is why I thought you couldnt get the rpm signal...
whenever i do something i always incorporate my own little touches to make it custom and clean looking. even if it's not my own car. this combo pod and gauge was perfect.
the pod for the S2K must be cut and modified to make it fit like i did. i trimmed it on all sides and use heat, via open stove top flame to heat up one side of it bend and shape it to give the same contour as our pillar.
Modding my TL in
1 Post
Well, someone in this thread tried and failed.. https://acurazine.com/forums/showthr...5#post11208205
94 DC4 RS LSV/Turbo
yea if you did 1 coil you wouldnt get a precise read... you def got pretty darn close to the oem fabric on that wrapping....
now all you need is an a/f gauge, oil temp, egt... I kid I kid
So is there a dual pod mount? Or you just gotta buy each one separately? Like stillhere says... a/f, oil temp, boost gauge, shift light. Buy the way I saw stillhere's video on youtube a while back... didn't you have it mounted in the airvent?
Hi all,
I'm new to this site, but wanted to know how the Shift light is holding up with time?
Also, interested to see if anyone had success with DPSS Gauge, Level 2. I'm looking to have it installed on my 07 TL-S.
What matirial did you use to wrap the pod in?
LIST/RAMEN/WING MAHSTA 짱
Send me an email to: scott.k.yun@gmail.com.
