Finally!! RV6 V3 JPIPE & HFPC INSTALLED!
Old 02-02-2012, 11:16 PM
  #41
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ da fawk !!! really ???
man am not moving to CA....
Old 02-03-2012, 12:01 AM
  #42
Andy270211's Avatar
Originally Posted by Hacura
I can't remember for sure but believe the HFC's won't pass smog here only path is to install and remove every 2 years after the first.
No no no no no way!
Old 02-06-2012, 12:49 AM
  #43
05 SSM
KidChenz89's Avatar
Heres my vid with atlp..took me about 4.5 - 5 hours diy HFPC over the weekend.. I drop the F bomb at least 50 times while installing it but pretty happy with the result..
http://youtu.be/POycJ72OYWo?hd=1
Old 02-06-2012, 02:36 AM
  #44
Andy270211's Avatar
^ That doesn't sound stock, what else is added?
EDIT: Duh, just read your signature. Cool
Old 02-06-2012, 06:16 AM
  #45
vp55's Avatar
Sounds good. Did you notice any gains/torque after installing the HFPC?
Old 02-06-2012, 01:45 PM
  #46
swoosh's Avatar
holy shizzzz i got a bonnneeeerrrrrr.....
sounds good....the camera was picking up some other noise but damn it sounds good....
Old 02-06-2012, 06:10 PM
  #47
05 SSM
KidChenz89's Avatar
you can definitely feel more torque
lol I leaned my phone on a bottle
Old 02-07-2012, 02:27 PM
  #48
04TL4P3's Avatar
Is your atlp resonated or no? Sounds good just a little rasp, im about to install yhe same setup soon unresonated and thinking i might need to add a resonator. Any suggestions on which to go with?
Old 02-07-2012, 04:00 PM
  #49
N0w $hiftinG N/A
GtMaxx's Avatar
same here i tink his base exhause is non resonated because you hear the rasp but it actually sounds good and this was the setup up I was going for. I was looking for more of an exotic sound I think I would like to hear a setup with the resonated version if not then I might switch to either the true dual exhaust instead of the atlp base since im looking for that exotic sound.I feel that the resonated version might give this setup that exotic sound im looking for but yours almost close to a m3
Old 02-07-2012, 04:03 PM
  #50
N0w $hiftinG N/A
GtMaxx's Avatar
can you make some drive by vids including a little WOT and cruising because your setup is really helping me to decide before i order an exhaust system. As i have the v3 rv6 as well but arghh that little rasp hurts as I hear it now on my car lol.
Old 02-07-2012, 06:32 PM
  #51
05 SSM
KidChenz89's Avatar
I have the unresonated version but welded 2.5 Aero resonator. If you dont have a resonator it will rasp with this setup, If you dont want any rasp at all probably go with the 18in or 22in Magnaflow resonator.
I will post some vids on the weekend check my youtube channel, I dont really want to jack this thread.
Old 02-07-2012, 07:10 PM
  #52
N0w $hiftinG N/A
GtMaxx's Avatar
Deffinatley bro will follow your youtube channel thnx and yea that true a 22" magnaflow res will tame the rasp. Ill be waiting to see lol niceeeeeeeeeeeeeeeeeeee menggggggggggg
Old 02-07-2012, 11:17 PM
  #53
04TL4P3's Avatar
Hmmmm ok i want to hear a clip under load and looks like im def getting a resonator just have to decide which one...
Old 02-09-2012, 11:38 PM
  #54
04TL4P3's Avatar
Installed my high flow cats today and there is definitely a bit of rasp between 2900 and 3400 rpm :/
Old 02-09-2012, 11:56 PM
  #55
swoosh's Avatar
^^^ whats you exhaust mods....
Old 02-10-2012, 12:05 AM
  #56
05 SSM
KidChenz89's Avatar
is it under load or just reving?
Old 02-10-2012, 01:20 AM
  #57
04TL4P3's Avatar
I have the hfpc and rv6 v3 jpipe with mid muffler delete...its a bit when revving and more under wot...it actually doesnt sound that bad i got used to it and almost like it but at first i thought it was a metal vibration
Old 02-10-2012, 02:00 AM
  #58
04TL4P3's Avatar
Forgot to mention u can actually feel a noticeable increase in power! More than i expected
Old 02-10-2012, 07:20 AM
  #59
gwiffer's Avatar
@04TL4P3: Will you post up a sound clip/vid?
This is not good news; I thought the HFPCs did not have a rasp problem at all. I guess the only cure is to install a HFC or an additional resonator after the jpipe...damn. I was going to purchase those HFPCs.
Old 02-10-2012, 08:51 AM
  #60
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
mid muffler delete is your problem. just weld in an 18-22" resonator and you'll be fine. it's a night and day difference.
melvin2816 (02-10-2012)
Old 02-10-2012, 10:37 AM
  #61
05 TL NBP 6spd S front
melvin2816's Avatar
Is your car manual or auto.
I just ordered a pair of HFPC and have the same set up as you do. I am imterested in the gain.
Old 02-10-2012, 10:54 AM
  #62
melvin2816's Avatar
Aaron do you mean replacing the OEM resonator with a magnaflow resonator.
I tough the OEM resonator will help with rasp since I already have muffle delete.
Thanks for your feedback
Old 02-10-2012, 10:58 AM
  #63
swoosh's Avatar
Aaron (Sharky) beat me to it....
Mid muffler is your problem....also the sound does seem to "tone down" after carbon deposit....just FYI
SharksBreath (02-10-2012)
Old 02-10-2012, 11:32 AM
  #64
BANNED
^what Anil (swoosh) said.
you're gonna want to keep your mid muffler on (square muffler) and take out the stock resonator and replace with something larger to muffle the sound.
Old 02-10-2012, 11:34 AM
  #65
04TL4P3's Avatar
I figured this also since now thats it brand new and clean u can see light right through it..my car is a 6mt, ill take a video and post it up but wont e great since its a camera phone
Old 02-11-2012, 12:34 AM
  #66
04TL4P3's Avatar
ok heres a sound clip hope it works...
btw Im planning on installing the atlp base soon and adding on the vibrant ultra quiet resonator...should that do the trick or do i need a second resonator?
melvin2816 (02-11-2012)
Old 02-11-2012, 05:22 AM
  #67
gwiffer's Avatar
I can't decide if I want to go PCDs & HFC after the jpipe or HFPCs and jpipe (no 3rd cat). I know these J series motors suffer from heat soak which pulls timing and decreases power. I don't want any rasp and I want to run some kind of cat for emissions and odor purposes...
Option 1:
HFPCs (ceramic coated) -$555
Jpipe (no 3rd cat) -$409
stock CBE
~$964
Pros: solid gains, no rasp
Cons: risk of heatsoak from keeping cats inside engine bay
Option 2:
PCDs (ceramic coated) -$355
metal catalyst HFC (welded in after Jpipe) ~$100(???)
stock CBE (after HFC)
~$864(???)
Pros: most power, reduced engine bay heat
Cons: possible rasp, slower warmup in winter, added expense from welding in HFC
Any suggestions?
Old 02-11-2012, 06:29 AM
  #68
melvin2816's Avatar
http://youtu.be/s2VKuUD5uN0
Does not sound bad I though it was going to be worse. I just got wait to install and see.
If is not to much to ask can you do a cabin video while driving at normal speed.
Old 02-11-2012, 08:39 AM
  #69
05 SSM
KidChenz89's Avatar
FYI Vibrant resonator on atlp + v3 jpipe = silence.
I've rode around for a while with that setup and wasn't a big fan of it.
04TL4P3 (02-11-2012)
Old 02-11-2012, 09:56 AM
  #70
04TL4P3's Avatar
Dammit lol i dont want silence either! Vibrant also has a straight through version maybe ill try that one? I read somewhere that the magnaflows dont last very long?
Ill make a cabin vid today and post it up later but i doubt u will hear any rasp
Old 02-11-2012, 12:50 PM
  #71
swoosh's Avatar
dont get the vibrant resonator....the HFC's and ATLP base go good together
Option 1:
stock CBE
~$964
Option 2:
~$864(???)
Any suggestions?
The difference in power is like 3-5 horses between the 2....what you might wanna think is whats allowed in your state....
If you live in Cali then forget PCD's or any other state that does a sniff test and a visual inspection.....
If you state does only a safety and OBDII port check (plug the computer in for codes) then get the PCD's and call it a day....
and why are you welding on a 3rd cat ?
Old 02-11-2012, 01:52 PM
  #72
gwiffer's Avatar
I don't have any emissions testing, but I don't want to be a jerk to the enviroment or have the catless smell (it's my daily driver).
lumyeinjun (03-02-2012)
Old 02-11-2012, 03:32 PM
  #73
swoosh's Avatar
^^^ in that case keep the HFC's and dont worry about the 3rd cat, it does nothing
HFC --> Jpipe (which deletes the 3rd cat) --> Catback Exhaust
Old 03-02-2012, 04:25 AM
  #74
lumyeinjun's Avatar
+1 and if you're worried about heat soak try to get an outer ceramic coating on the HFPCs; it should keep a lot of heat in the pipes and keep engine bay temps down.
Thank you for being environmental friendly! I myself am getting HFPCs and retaining my 3rd cat (it has a low cell count compared to other cats, but at least it HAS cells in there! Plus the gains from deleting the 3rd cat is very minimal. 1hp and maybe a very very slight increase in mpg iirc.
Old 03-02-2012, 04:28 AM
  #75
lumyeinjun's Avatar
ahhh you're right I hear ze rasp!
what is your setup anyway?
HFPC->V3 J pipe->dynomax resonator and mid miffler delete?
do you have rasp only when revving, or do you still have it under load (driving) as well?
jspangan
ILX
19
08-30-2016 05:37 PM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
usual suspect
2G TSX Photograph Gallery
12-07-2015 10:52 AM
o8 ENVII 8o
11-30-2015 04:23 PM
MonkeyTrucker
09-14-2015 11:57 PM
Quick Reply: Finally!! RV6 V3 JPIPE & HFPC INSTALLED!
