Exhaust parts
We dont have headers.
as our heads are cast into the block.
instead, the exhaust exits into the primary cats. bank 1 and bank 2.
you can replace these cats with straight pipe, but depending on your state, you will/will not pass emissions.
these straight pipes, also known as pre-cat-deletes can be found here:
http://rv6-performance.com/index.php...mart&Itemid=83
The following 3 users liked this post by justnspace:
Registered Member
kingtwin34 (11-26-2011)
The exhaust manifold is cast with the cylinder head as one solid part. The TL engine is a V block, you have two main exhaust ports for all 6 cylinders. Each head has a primary catalytic converter (pre-cat).
You could do a Hi-Flow pre-cats w/ Hi-Flow Jpipe, or pre-cat deletes w/ Hi-Flow Jpipe.
Former Sponsor
Our XLR8 V2 J-pipe will pick up as much power as a typical V6 header would pick up: 10-15 hp and 15-20 tq.
http://store.excelerateperformance.c.../i-494454.aspx
handsom-hustla
11-13-2015 05:04 PM
Billu99tl
09-13-2015 11:30 AM
