Notices
Exhaust Help Clamps Vs. Welded
Old 06-09-2017, 02:01 PM
Registered Member
LTON's Avatar
I was searching around and I found out that some people use stainless steel clamps to secure staight pipe and after market parts on thier exhausts. My question would be is it ok for me to use clamps on my exhaust if I were to straight pipe the oem mid muffler and resonator?
LTON is offline
Old 06-09-2017, 02:04 PM
Received 14,119 Likes on 10,496 Posts
yeah, but it would totally be easier if you just went to an exhaust shop and had them cut out everything and weld everything back into place for $60
justnspace is online now
EvilVirus (06-12-2017)
Old 06-09-2017, 02:06 PM
Registered Member
LTON's Avatar
But if I clamp it I could also switch between the resonator and the straight pipe if I ever get tired of the sound.
LTON is offline
Old 06-09-2017, 02:08 PM
as you wish.
but im telling you, it's easier to have an exhaust shop do things for $60
the way you are trying to do it...it means you have to source the straight pipe. and clamps...where as an exhaust shop has everything on hand and can do everything in like 15 mins.
Old 06-13-2017, 01:55 PM
Registered Member
guitarplayer16's Avatar
Received 2,245 Likes on 1,662 Posts
Clamps are fine, I'm pretty sure those $1000+ aftermarket exhausts made for our cars are all clamped together.
You're looking into a lot of work doing this yourself as stated before though.
guitarplayer16 is offline
justnspace (06-13-2017)
Old 06-13-2017, 02:00 PM
if he had a lift and some basic cutting tools, then yeah.. it would be okay for him to do clamps...
Old 06-15-2017, 06:58 AM
fsttyms1's Avatar
Received 3,005 Likes on 2,085 Posts
Dont get the typical clamps that crush the pipe, you wont get the pipe apart. If you get anything welded spend the money on V band clamps. Best exhaust clamp/joint possible. If you are against any welding, Get the Stainless band clamps, i have used them for years on multiple vehicles and they work really well. Even have them on my Explorer Sport which is twin turbo and they are leak free and hold well and you can remove the pipe even years later.
fsttyms1 is offline
justnspace (06-15-2017)
Old 06-15-2017, 07:09 AM
Received 5,925 Likes on 4,754 Posts
Or just get it welded properly .
thoiboi is offline
rockstar143's Avatar
Received 15,057 Likes on 11,209 Posts
and this one time, at band clamp...
rockstar143 is offline
Old 06-15-2017, 01:26 PM
Registered Member
LTON's Avatar
I just ordered the Dynomax 24215 resonator, should be in by next Friday. Ill update this thread with pics and videos of the install.
LTON is offline
