Excelerate Performance: Now a Distributor for Ultra Racing Chassis Bars and Braces!!!
Old 12-21-2010 | 01:44 PM
Excelerate's Avatar
Former Sponsor
Excelerate Performance is now an Official Distributor/Importer of Ultra Racing Chassis Braces and Bars. Established in 2002, Ultra Racing is a Malaysian-based specialist manufacturer in Chassis Handling and Tuning components. They research, design, test and manufacture high quality chassis strengthening bars to cater for all types of vehicles. They are also the first in the country to introduce the multi-point bars, which gives superior performance against conventional bars.
Ultra Racing products are constantly improved through intensive research, followed by feedback collected from street and race track testing. Their products are proven to improve dynamic safety, road holding and provide you with a sensational driving experience. By installing specific bars,a vehicle’s cabin can be strengthened to improve safety in case of impact. You will find all types of bars for your chassis tuning needs, ranging from Front Strut Bars, Rear Strut Bars, Side Fender Bars, Front Lower Arm Bars, Anti Roll Bars, Side Floor Bars to Torsion Bars. Made-to-order service is also available. All the products are designed with safety and superior handling in mind.
FENDER BARS
Fender bars can give extra support and strength to the chassis especially during cornering. As most of the vehicle’s front chassis over hanging is designated to carry the vertical loads from the front suspensions, it is vital that this part of the chassis is strong enough to take the bounce and rebound force of the suspension. Else, the effort of a good suspension will lose its meaning if the chassis absorbs all the forces from the suspension and not letting the suspension does what it suppose to do. Therefore, these high quality 3-Point Fender Bars strengthen and reinforce these essential areas of your car and help maintain the suspension in position from all kind of vertical loads.
http://store.excelerateperformance.c.../i-403227.aspx
FRONT LOWER BAR/ FRONT MEMBER BRACE
The Ultra Racing Lower Arm Bar is designed to reduce the flex of the vehicle chassis where it is connected by the Lower wishbone of the suspension system, thus to lessen the distortion of the vehicle lower suspension when it is under load, especially during hard cornering. It is installed at the lower mounting points between the left and right suspension and the vehicle chassis. Tremendously improving the stiffness at the area where the lower arm is connected to the vehicle chassis. The Ultra Racing Lower Arm Bar also keeps camber accurate during hard cornering.
http://store.excelerateperformance.c...630&Make=ACURA
FRONT STRUT BAR
Mounted at the front chassis for strengthening purposes Front Strut Bars help eliminate all the suspension noise and provide you with more stability during acceleration, hard driving and braking ( simulating race track conditions ).
Every vehicle’s front chassis is different therefore Ultra Racing designs and develops the front bars based on the actual conditions of the vehicle, repeatedly testing and proving to its perfection. High attention is taken during the design and development stage to ensure the chassis is able to withstand the load when a bar is being installed.
Ultra Racing is proud to bring to you the first of its kind in the country, the MULTI-POINT Front Strut Bar. The Front Strut Bar is installed to minimize the weight transfer of the vehicle body, therefore the vehicle will not loose traction easily during cornering.
http://store.excelerateperformance.c.../i-403261.aspx
REAR LOWER BAR/ REAR MEMBER BRACE
http://store.excelerateperformance.c...634&Make=ACURA
REAR LOWER CROSS BRACE/ SIDE LOWER FLOOR BAR
It is the bar linking both the B-Pillars within the passenger compartment. The effect of room bar is particularly obvious for a four-door sedan. This is because four-door sedan has a longer body than the hatch-back or coupe, the chassis is by nature weaker than the later two.
http://store.excelerateperformance.c...635&Make=ACURA
Old 12-21-2010 | 01:47 PM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
do they make the front strut bar for a tl??...the link is for a tsx
Old 12-21-2010 | 02:06 PM
Excelerate's Avatar
Former Sponsor
The front strut bar is only for the TSX. Sorry.
Old 12-21-2010 | 02:10 PM
07tl-s6spd's Avatar
^^just my luck....lol
Old 12-21-2010 | 03:11 PM
EL19's Avatar
They make great products.
Old 02-21-2011 | 05:54 PM
Excelerate's Avatar
Former Sponsor
All bars good in stock and ready to ship!!!
Old 04-14-2011 | 07:49 PM
a.patel's Avatar
im gonna really have to consider getting these soon.
Old 04-14-2011 | 08:16 PM
hp1kw's Avatar
Just a note, the rear lower bar/rear member brace IS NOT compatible with XLR8 V1 resonated exhaust. Personal experience.
MrHeeltoe
20
02-23-2023 02:54 PM
tsx_boy
12-13-2019 09:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 09:09 AM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
