Engine swap: Does it worth any power or just a waste of time/money?
Do you think engine upgrade from 2006 TL Base AT to 2007 TL Type-S worth it?
Does TL Type-S engine fits on Base compartment?
Any advantages/disadvantages?
Any inputs are welcome.. Thanks.
veggiemonster (01-27-2012)
The following 3 users liked this post by justnspace:
BANNED
The following 7 users liked this post by SharksBreath:
anthracite_ftw (01-26-2012),
DaeHanMeenGuk (02-07-2012),
Joneill44 (05-29-2012),
justnspace (05-26-2012),
P1zzaman (01-26-2012),
and 2 others liked this post.
The following 2 users liked this post by justnspace:
r3devi7 (01-29-2012),
Undying Dreams (05-26-2012)
it would take acouple of thousands of dollars.
.3 displacement isnt that much.
an Auto TL-S puts down the same power as a base 6MT TL.
with that "couple of thousands of dollars" you could just buy a supercharger or a turbocharger which will make you faster than a TL-S 6MT.
All motor
the mounts MIGHT be the same.
swapping from j32a3 to j32a5 seems like it would be pretty straight forward.
Iver never pulled the either engine so i cannot confirm if the mounts are the same. but since its the same J series. it should bolt right up.
yes, paperboy you would need the type-s ECU.
I believe Paul from AV6 has done this swap and has it documented somehewre
justnspace (01-26-2012)
The Track Terror
And I'm still in a better overall car for thousands less than zee Type-S...You'd be changing all those things with the Type-S as well, so save the $$$ and just put it into the Base...
Paddle shifters, meh...larger sway bar, i haz Progress 24" RSB, now mines bigger...aluminum subframe, meh again...Brembo brakes, I have Hawk HP+ (soon to be Carbotech XP12s) and Motul 600 fluid, mine stops *much* better..."Sport Suspension", my Koni's/H&R springs handle much better...wheels/tires, again mine better...power, i have the essential power adders to compensate...
But it's still not a Type-S
Registered Member
Yeah not that I know much about these cars just yet, but I can't see it being worth your money to swap an engine on a naturally aspirated car. Now on a turbo car, it could be worth it. I had a hybrid setup on my WRX, stock 2.0 heads and a 2.5L STi shortblock. And let me tell you the .5L made a world of difference. It raises the compression so my torque was through the roof on a turbo setup that wasn't too much bigger than stock. I think I was putting around 380 ft lbs to the wheels. And of course after the the ECU had to be custom tuned, etc.
The Track Terror
Haha! True true...every time I see a Type-S I'm like, "Ohhh, Type-S....me likey..." lol ESPECIALLY Kinetic Blue...yes, please...
And I do wantz the red light interior....and a rear bumper that will accept quads out of the box....
value, not that I agree with you. I mean 2 x couple thousand = 4 thousand+
that also brings over the 3.5 cams!
shenrie (05-26-2012)
The Track Terror
The thing is, with the amount of money I paid for and put into my Base, I have a much better performing car than a stock Type-S...and still saved thousands over said stock Type-S...
So, yes, I won't be getting as much for the trade-in/total loss...but of course I didn't pay as much either. But in the meantime (while I actually own and drive it), I'm more than enjoying it...
im sure the motor mounts would fit though, they arent the exact same part numbers, but im currently using a 2006 accord I4 front motor mount and it runs fine LOL. So im pretty sure accord,tsx, and tl all have same bolt patterns for the mounts.
3G TL/2G MDX Owner
i remember reading somewhere on here that someone wanted to do this...but couldn't. the j35 type-s engine is not a direct fit to the mounts of a j32 base engine. there were a few other details i'm sure i'm missing, but the bottomline is IIRC, the type -s engine would not fit directly if someone were to do a swap. now i'm sure with enough time and money one could modify the mount locations to get the j35 to fit in a base model. however i think you also need to swap the tranny as well. please correct me if i'm wrong.
is that an option? bolt up to tranny etc? will the nsx tranny work in our cars? forgive the noobness, but ive only fuct with older civics and integras as far as swaps go. would love to do some reading on this if theres any links to be had.
The mounts lining up will be the least of your struggles.
You guys need to get something straight....the 04-06 TL is not a BASE model to anything. It was the ONLY TL, either in AUTO or MANUAL.
And no, an engine swap for a 3.5 is NOT worth your time and money.
Paddle shifters? please!...stick with your PS3 at home lol
ABP_04TL (06-17-2012)
09-15-2015 06:44 PM
