Engine Parameter Monitoring without gauges...Yay/Nay Thread
Old 12-28-2011, 11:47 AM
  #41
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
i think they will work great....you will see great gains...
Old 12-28-2011, 09:07 PM
  #42
endles/acura's Avatar
I got a scangauge 2 and so far so good,not a single complaint.
Old 12-28-2011, 09:36 PM
  #43
runnin a little boost
Hi speed's Avatar
But you can't see it while driving.
Old 12-28-2011, 09:56 PM
  #44
Hi speed's Avatar
Here are some pics of the dash dyno my solution to data logging and my changing gauge needs.
Old 12-28-2011, 10:01 PM
  #45
swoosh's Avatar
^^^ yes thats 1 thing i realized from Inaccurate's comment....
Logging is necessary coz u cant see while driving....
Seeing the gauges is important while dyno tuning....
and you guys are very good at confusing LOL....am more confused now than when i started....
Old 12-28-2011, 10:12 PM
  #46
Hi speed's Avatar
I watch those parameters all the time. This is also helpful durring tuning both dyno and street. I like to watch the IAT over ambient and timing changes. I am still having trouble getting the data logs to show up on my computer but it works great as just a set of gauges.
Old 12-29-2011, 10:33 AM
  #47
KN_TL's Avatar
YOU DON'T NEED A OBD-II INTERFACE.
Grab everything from the MegaSquirt 3. You just need to figure a way to get it to a readable display. If the device isn't ported to the MS3, then port it (EGT for example). The MS3 can log, so use it.
People who don't have an MS3 are just confusing people who are about to get one.
Old 12-29-2011, 10:37 AM
  #48
swoosh's Avatar
^^^ just wanted to know, how do you have MS3 take the AFR into account....since the stock ECU does not monitor AFR....
Old 12-29-2011, 11:15 AM
  #49
KN_TL's Avatar
I have a wideband gauge and feed the MS3 with that. Where did you get the impression that the stock ECU doesn't take into account A/F????????? Where do you think engine management resides from the factory, little elves?
Not sure what Rodney has in mind because it should be possible to use the stock circuits.
Old 12-29-2011, 11:24 AM
  #50
swoosh's Avatar
^^^ what i meant is none of the gauges will show the AFR directly from the stock ECU right ? I thought we need a wideband sensor directly connected to a gauge....
so with the MS3, will i need a wideband sensor or will stock ECU directly provide this detail....
i would be completely wrong here and thats why i created this thread to know more....
Old 12-29-2011, 11:42 AM
  #51
The Track Terror
the fenda rolla's Avatar
Hey Swoosh, Torque Pro definitely does read and display the AFR... (BTW, mine never goes below 14....). unfortunately the stock O2 sensor is only accurate for maybe one full WOT run...if you do more runs it becomes less accurate, hence the need for a dedicated wideband...
Old 12-29-2011, 11:43 AM
  #52
swoosh's Avatar
^^^ aaah....now it makes complete sense....
Old 12-29-2011, 11:46 AM
  #53
KN_TL's Avatar
If you want to read the stock ECU's O2 sensors without any piggyback controller, then you need an OBD-II scanner as people have mentioned with the software/hardware of your choice to display it.
If you are using the MS3 as your engine management, it still needs to know what the reading is from your tailpipe to base it's adjustments against. Be it the stock circuitry or an aftermarket gauge with an independent O2 sensor is up to you.
Old 12-30-2011, 10:33 AM
  #54
Atlas.46's Avatar
With Torque Pro on my 04 accord v6 I have seen 13.5 for sure.
Old 12-30-2011, 11:12 AM
  #55
The Track Terror
Ya know I have to say I *have* seen it dip into the 13s for a split second too, but for the majority of part and full throttle runs for me, it's *mostly* in the 14s...which is one of the reasons I'm getting the J&R ecu so I can make it richer...(among other things...)
Old 12-30-2011, 11:20 AM
  #56
Atlas.46's Avatar
Cruising and part throttle its mid to high 14s. Full throttle mid to high 13s. I will check again later. Do a couple pulls on the high way.
I havent recorded or really looked at any logs. Can you look at the logs on a normal computer or are the only to view on phone and send to the creator.?.... sorry if that sounds stupid.
Old 12-30-2011, 08:15 PM
  #57
The Track Terror
Oh no, doesn't sound stupid, I totally get what you're saying...I actually haven't logged with it yet so I don't know about that...
Old 01-03-2012, 11:35 AM
  #58
FCVadi's Avatar
so what wideband sensor are most of you using? from what I have read most of them can be used with either a droid, iphone, windows, or guage
Old 01-03-2012, 12:53 PM
  #59
swoosh's Avatar
Bosch wideband I have heard works very well....but yeah i would like the know which is the better one as well....
Old 01-03-2012, 01:42 PM
  #60
FCVadi's Avatar
Bosch is in the Innovative and AEM.. I think it is the same hardware for all of them.. its the guages after that does the tweaks/readings
well from reading up on the product sites... googled to see which one is better and getting toss ups between AEM and LC1.. seems like most Hondas/Acuras run AEM.. Mustangs and domestics are running more LC1s... again this is from my google search
Old 01-03-2012, 02:35 PM
  #61
KN_TL's Avatar
Almost all seem to run the Bosch sensor. I've read better things about the Innovate Motorsports wideband but at the time wanted to match my boost controller so I ended up with an AEM UEGO to go with the Tru-Boost.
Now that the MS3 is controlling boost, I am thinking about a different set of gauges.
Old 01-19-2012, 12:46 PM
  #62
Brock
Euro-R_Spec_TSX's Avatar
Just thought I would post about the DGauge I have in my TSX. It fits perfectly in the storage compartment and should fit in the TL storage compartment as well. I don't have a smart phone, so this seemed like the best option and I must say I'm very happy with it. It even has a couple of external sensor inputs which I plan on using for oil temp and oil pressure. Here are pics from the Brockway website (too lazy to go out to the garage and take pics):
In a TSX (seeing this pic is what prompted me to buy one)
Old 01-19-2012, 01:02 PM
  #63
swoosh's Avatar
^^^ that actually looks damn goooooddddd....
adding color to the whole thing....
Old 01-19-2012, 01:25 PM
  #64
Brock
Yeah, it does look really good. And easy to read. Plus I just close the compartment door when I park the car.
Old 01-19-2012, 01:37 PM
  #65
Hi speed's Avatar
What is the point of gauges you can't read while driving? I could see using this for a data logger, but looking down while driving is a bad idea. If this thing is super cheap them run it but if you can afford the dash dyno it allows a much safer view of the gauges.
Old 01-19-2012, 01:58 PM
  #66
Inaccurate's Avatar
The DGauge looks suspiciously like the DashDyno. So, I checked the DGauge website. Appears to *not* be a updated DashDyno as I first thought. I do like the colored display. But the DGauge has no built-in logging capability. And the lack of logging is a deal-breaker for me.
Old 01-19-2012, 03:01 PM
  #67
swoosh's Avatar
i agree with you....this is something for you to look at when on the dyno i guess....
ps: i will be running the logging software when i get my ECU....so it will log the data while i drive....i just wanted to see what people are using the display the data, as i hate gauges....
yes, after you posted i did my share of reading about Dashdyno and I was super impressed....i really liked HOW MUCH MORE this thing logged....
since am getting the MS3 and it has its own logger am kinda conflicted, but i think to be on a safer side i might put dash dyno to see how different are the logs....
Old 01-19-2012, 03:57 PM
  #68
Inaccurate's Avatar
They all log the same stuff. One company may display more stuff in their advertisement than the other. But that is just "in general, your application may vary."
All of them just query (poll) the oem ecu. They can not display more parameters than what the oem ecu has to offer. With the exception of external (add-on) signals, which is a pain to setup in real life.
Old 01-19-2012, 04:11 PM
  #69
swoosh's Avatar
^^^ what i meant is the availability and display of data available....
yes all data loggers will log the same stuff, since different units connected to the same ECU...but presentation does matter to me
sorry been an IT/Marketing/Sales guy for a while now....
Old 02-26-2012, 01:23 AM
  #70
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
Bump for tommy. How did the bluetooth and torque pro work out?
Old 02-26-2012, 02:03 PM
  #71
swoosh's Avatar
^^^ PM the fenda rolla (I dont know his name) but he has the torque pro and swears by it....actually he got me convinced to get the torque pro
Old 02-26-2012, 03:26 PM
  #72
Its only 25 bucks together... I've seen the Elm327 v1.5 for $20 shipped from the us. Having the ability to check codes and see data and log data is def worth it. Ima get it plus my af,fp,boost gauges. I just wanted tommys view on it and a free bump to the thread
Old 02-26-2012, 03:45 PM
  #73
swoosh's Avatar
^^^ aaahhh....
i was thinking of getting the bluetooth OBDII scanner and torque pro (combined $25) and will have all gauges on the tablet or a phone....also use the ECU the for data logging....
so wont have gauges sticking out like a bunny tooth and logging is also taken care off
Old 03-23-2012, 02:30 PM
  #74
Just got my bluetooth adapter and torque Pro. what all setting did you set everything at? ima go play around with it right now..
Old 03-23-2012, 02:38 PM
  #75
swoosh's Avatar
^^^ PM the fenda rolla....he is already using this app.....am more of a planner....
Old 03-23-2012, 02:49 PM
  #76
Inaccurate's Avatar
If you mean "with the new torque Pro", then WE NEED PICS
If you meant something else, no pics please
Old 03-23-2012, 02:53 PM
  #77
swoosh's Avatar
pix on page 1 buddy.....
btw i didnt get a reply back to my email
Old 03-23-2012, 03:31 PM
  #78
LMAO. What you want pics of?
first impressions. Nice and easy. Need to set up my personal gauges that i want to see/use. Theres iirc 7 or 8 screens i can scroll thru and each one can have 6 gauges/graphs/ or 1 big gauge/graph.theres traffic right now but i got a 88 second 1/8 mile!!!
Old 03-23-2012, 03:37 PM
  #79
KN_TL's Avatar
The bluetooth adapter was quite easy to setup w/tunerstudio. Just pair it up using 1234 and figure out what com port your machine assigned it to.
swoosh (03-23-2012)
Old 03-23-2012, 03:44 PM
  #80
You can change the number of dashboard screen from 7-15 so you can set up 15 different screen with 1-6 items. they have all needle gauges/ digital
Quick Reply: Engine Parameter Monitoring without gauges...Yay/Nay Thread
