E-106: Official Pre Cat Delete HOW TO DIY
#82
really no different than traditional "headers" for american and other makes. remove cats (restrictive), and make smoothest, most efficient path to j-pipe. scavenges exhaust gases more efficiently = more power. it's just top end bias in the TL but I certainly didn't lose power down low.
#95
Is the half-shaft heat shield still needed with the PCD's? I was thinking of leaving it off. Doing this install with nothing but a pair of ramps SUCKS! I'm about worn out after about nine hours spread over two evenings. All I have to do is reinstall the j-pipe, fan, and strut tower brace and I'm finally done. :/ I'm just praying I didn't damage any 02 sensors and wind up with a CEL.
#98
#101
FYI below is a link to a DIY I wrote for the 8th gen accord on installing pcds there is also a video in it that could likely help 3rd gen tl owners install pcds in the future...
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/diy-ceramic-coated-pcds-843253/
justnspace (04-07-2013)
#104
F^@^!&!()&$^%$*&_!
so i just tried to do this today...got the front cat out adn teh PCD installed adn teh j-pipe off and followed instruction but i could not fig for the life of me how the F#*@% to get that rear cat out....soooo on top of that i couldnt even get the 3rd cat bolts in the rear to break loose i even used mechanical leverage and i almost busted a vein in my neck trying to break it loose...i used jacks and i have a good amount of good new tools....sooo on top of the 4n half hrs taking everything out, i ended up having to put everything! back to stock cause i coulndt get the rear cat off or even really fig out how to get to the bolts to the rear car adequality, and then the 3rd cat....well tomorow i am going to a shop and having the install my j-pipe and magnaflow resonator and build me a cat back piping to my oem mufflers.....trying to get this sound
so as far as i know he used pcd a j-pipe magnaflow resonator and 2.5 inch piping back to the mufflers not quite sure if its oem mufflers or not but they look oem.....any ways any help advice pictures to get that rear off since i cant get a shop to do it in california cause its illegal would be soooooooo much appreciated!..........and yea i read through this entire thread, and have been looking through other threads as well....i had to put it back to stock because i only have one car...i.e. my 2007 acura tl type s 5at, and i need a way to work and the shop and deff not gonna pay someone to come tow it....so looks like ill be trying to get at this some weekend from now when im not frustrated and im inspired again to get at it
#106
richie from rv6 also recommended this and he has installed it multiple times, he mentioned it in one of the threads on here. just be patient and you will get it done.
#107
i have a flexible 3/8 ratchet with an adjustable extension on the handle to give it an increase in mechanical leverage and i freakin love that ratchet.....
and not drunk but super frustrated typing really fast
DerrickW
11-15-2015 06:52 PM
