Drag racing and problems with stock 6MT.
Old 09-28-2014, 04:51 PM
Tony K's Avatar
Hi, I got a 04 6-speed Tl and I love to drag race. I have been to the track a couple times and the results are posted below. The only thing done to the car is a CAI. I am worried about the strength of the factory manual transmission. Have any of you drag race guys had any problems? This is my first Japanese car. I'm running street tires and cutting 2.2 to 2.3 60ft times. I'm probably going to bolt on a pair of Mickey T radials and see how fast the car really can go.
Best pass so far is a 14.39 at 98MPH.
Sonnick (09-28-2014)
Old 09-28-2014, 04:59 PM
anx1300c's Avatar
That's a pretty solid time, especially considering the DA was 1691 at the time of that run. It corrects to a 14.1 @ 100.1 mph, which is strong as hell for just an intake! Your car is on the stronger side for sure, unless that's a fast track.
FYI, there's a racing & competition section for this stuff.
Tony K (09-28-2014)
Old 09-28-2014, 05:01 PM
Tony K's Avatar
Hey anx1300C can you link me the racing link? I only see 5 subforums under the 3rd gen section and I don't see the racing forum listed.
Old 09-28-2014, 05:08 PM
runnin a little boost
Hi speed's Avatar
If you hit the TL button on the top of the page there is a racing and competition area at the bottom.
Tony K (09-28-2014)
Old 09-28-2014, 06:35 PM
All motor
Sonnick's Avatar
Nice time, man. I go to the track relatively often and the trans holds up well unless you grind a lot, which I had done. I had to get a new trans because I broke 2nd gear. However, I also shift gears like my life is on the line (lol) so I'm sure that didn't help. I've been taking it easy on the new trans tho. You can get into the 13s in better weather and a better launch. Any plans on modding the car further?
Old 09-28-2014, 07:00 PM
Tony K's Avatar
Yes, I plan to replace the exhaust, bolt on some DRs and skinnies, and maybe spray it till the engine gives up. The fact its not my daily driver is a plus. A clutch will be on order soon as well.
The following 2 users liked this post by Tony K:
3gstealth (09-28-2014), Sonnick (09-28-2014)
Old 09-28-2014, 07:49 PM
anx1300c's Avatar
What's wrong with your clutch? How many miles? I just hit the big 100k Friday and my clutch is holding strong, knock on wood. And trust me, I've got more than a few no lift shifts under my belt, lol.
Old 09-28-2014, 08:05 PM
Tony K's Avatar
124,000 miles. I didn't know there was any other type of shifting at the track. My 2nd to 3rd shift I can feel the clutch slip. Its a never ending battle more traction and power = more slip. I dont see it lasting much longer. Its fine on the street but 7k rpm powershifts are going to kill it.
Old 09-28-2014, 09:50 PM
screaminz28's Avatar
I would worry about the clutch, then axles on some Mickeys. MT's aren't anything like what most people think of drag radials. They make Nittos seem like they're made of plastic.
Tony K (09-29-2014)
Old 09-28-2014, 10:20 PM
anx1300c's Avatar
I've got some 245/45-17 Nitto DR's I was running on the stock wheels a few years ago. TBH, my 235 Continental DW's (summer tires) hook just as well, if not better on the street.
I should find a set of lightweight 17's to mount the Nittos on and see if I can cut a 1.9x sixty foot. I'm just so sick of dumping money into this damn car though. 105K service is coming up and I'm thinking of doing some MDX cams at the same time. Plus, I need either snows or all seasons for the stock wheels. All that'll run a good $2500. And these damn Contis are only good for two summers, so I need them every other spring. I'd probably save $ if I bought a 335, lol.
If my clutch goes any time soon, I'm setting the damn car on fire.
Tony K (09-29-2014)
Old 09-29-2014, 09:21 AM
All motor
Sonnick's Avatar
If you continuously Powershift and are going to get DRs, your clutch & flywheel will need to be replaced. Ask me how I know.......
I now have the CM FX250 and LW flywheel, so I will be back to the track soon. Unfortunately it will most likely be on street tires and maybe even my stock catback...either way I miss it
Good luck man and keep us updated!
Old 09-29-2014, 09:47 AM
FamilyGuy's Avatar
Have you removed the check delay valve from the slave cylinder? That should help a bit.
The following 3 users liked this post by FamilyGuy:
hondazex (09-30-2014), Sonnick (09-29-2014), Tony K (09-29-2014)
Old 09-29-2014, 05:05 PM
Tony K's Avatar
I haven't removed the check valve. Im new to the TL game so I have never heard of this check valve. The world I come from we still have adjustable cables to work the clutch.
Old 09-29-2014, 06:22 PM
Slot Machine Lubricator
1black_seven's Avatar
I've never seen a stock base MT break < 14.5. Holy shit.. You got a hell of a TL
Awesome reaction time too.
Tony K (09-29-2014)
Old 09-29-2014, 06:30 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Or it's one hell of a driver!
Tony K (09-29-2014)
Old 09-29-2014, 07:09 PM
Tony K's Avatar
Thanks man, That night I had a -.003, .006, .045, .079, .142 and my slowest was a .270 RT
Old 09-29-2014, 07:14 PM
Tony K's Avatar
Sell me that intake, Hondata Flashpro, and your exhaust first then I will give you the box of matches. I will even bring the cold beer.
Old 09-29-2014, 07:33 PM
anx1300c's Avatar
I'm warning you. I like expensive beer.
The following 2 users liked this post by anx1300c:
Old 09-29-2014, 11:07 PM
All motor
Sonnick's Avatar
I've never seen a stock base MT break < 14.5..
If that's the case, you're not looking hard enough.
Old 09-30-2014, 10:57 PM
I've seen consistent 14.6-14.9s from a base MT.
I'd like to see what OP can do with a UA7 MT
Sonnick (10-01-2014)
Old 10-04-2014, 05:37 PM
-NoSuchThingAsTooLow-
StanCeD_J32's Avatar
14.3 is crazy for a stock tl with just an intake. Next time you go post a vid =)
Tony K (10-09-2014)
Old 10-05-2014, 08:38 PM
Grand_hustle17's Avatar
Probably not much more...
Old 10-06-2014, 12:49 AM
anx1300c's Avatar
There was actually a 13.9 @ 99 mph on a base model 6MT with just an intake way back in 2007. The planets were well aligned that night. Think his sixty was like 2.10-2.15
Old 10-06-2014, 12:28 PM
All motor
Sonnick's Avatar
Yea that was done by Type-s 09 way back. He had CAI/Pulley from what I remember, nonetheless that's the best I've seen for such little mods. I went 14.04 @99.71 (best trap 100.82) with CAI/RV6 V1 Jpipe way back too. That was with a 2.24 60' I believe. Unfortunately it took me forever to run 13s after that
Old 10-06-2014, 05:00 PM
anx1300c's Avatar
I thought he had just CAI and throttle body spacer (in other words, just a CAI...lol)
I'm still pissed he never put tires on his car and broke into the 12's when he was trapping 107 with the S/C.
And I'm still more impressed by CBR169 going 13.30 on only 102 mph. Pretty sure his sixty foots were in the 1.90's.
Old 10-06-2014, 09:07 PM
All motor
Sonnick's Avatar
Agreed on both points. CBR's times still haven't been beat. I think he had I/Jpipe/PCDs/Ported intake and runners. Did he have weight reduction?
Old 10-07-2014, 08:13 AM
Yea thats my friend... He had stock j-pipe IIRC and gutted all the cats and rv6 j-pipe.. He did have weight reduction.. Seats out.. I cant remember if passenger seat was in
Old 10-09-2014, 07:58 PM
Tony K's Avatar
I plan to go back to the track next month. I have a friend with a G8 trying to break into the 11s. We are hoping for some cool air and a Low DA. I will put my go pro in the car and get my girl to video the next time I run the car.
Sonnick (10-09-2014)
Old 10-12-2014, 11:41 AM
Mr. Detail
Scottwax's Avatar
Really common for stock 6MT '02-03 Maximas though. But the Maxima isn't nearly as nice a car as a TL or even an Accord.
Old 10-12-2014, 09:50 PM
Does anyone think an 8th or maybe 7th gen Accord 6MT can drop the same or similar time?
Old 10-12-2014, 11:22 PM
Mr. Detail
Scottwax's Avatar
I think most 6MT Accords run in the mid 14s in the upper 90s. There are a lot of modded ones on v6performance well into the 13s at over 100.
Old 10-13-2014, 08:29 AM
All motor
Sonnick's Avatar
Stock 7G has gone as fast as 14.2 @99 bone stock from what I've seen in Canadian air. I ran 14.0 @100 with I/Jpipe and some dude way back went 13.9 @ 101 with I/E. The 8G 6MTs are faster than even the TL-s in bone stock form, some going 13.8 @ 102.x
Old 10-13-2014, 08:56 AM
Ive got a mechanic friend of mine who is suggesting a 6MT swap from the Accord. Wondering if they were both (8th V6/TL-S) the same car minus LSD.
Old 10-13-2014, 10:24 AM
All motor
Sonnick's Avatar
I'm almost positive the bell housings are different on the J35a8 and 7G Accords. And the Accord doesn't have LSD, so I wouldn't necessarily go with that suggestion lol.
Old 10-15-2014, 11:42 AM
Tony K's Avatar
I would try looking up the part number on the transmission case at Acura Parts | OEM Acura Parts | Factory Acura Parts. See if they cross-reference.
Old 10-15-2014, 05:53 PM
i_love_cars's Avatar
probably not worth your hassle at this stage in the game to swap to an accord 6mt transmission. And the LSD on the TL is a big help. Any gearing differences between the two in stock form won't amount to much.
FWIW the guy who bought my TL-s put a Stage 3 clutch in, had a problem with 2nd gear and couldn't shift into it so he had to go 1 -> 3 -> 4 and still ran 13.8 @101 on his first time out, even without 2nd gear. You can get some decent times in the 13's if you have decent flow and good enough driver mod to make good 60'
Old 10-15-2014, 06:38 PM
I am loathing the auto in my type-s so ive been entertaining ideas.
I am still mostly geared to a K24 RSX and just save the TL as a cushy car.
I "drove" a b18 civic with a stage 2 last week. I dont know how folks do it but that was brutal. The car was flailing like I'd never drivin stick before.
Old 10-16-2014, 09:46 AM
All motor
Sonnick's Avatar
It really depends on what clutch too. My Clutchmasters FX250 feels just like stock yet I know Simione's Spec Stage 2+ (?) is very stiff. Some people like it soft and some like it stiff (yea I said it), it really depends.
1black_seven (10-16-2014)
Old 10-19-2014, 09:56 AM
ReDevil
r3devi7's Avatar
I like a stiff clutch. I have yet to do the ss clutch line, and remove the check valve, but I get the bad slip if I try to hammer gears too. Other vehicles have distracted me this season lol
Old 10-19-2014, 09:03 PM
Tony K's Avatar
So this checkvalve mod. I looked at a couple forums that show how to do it. Has anyone done this and did you shave anytime off your 1/4 mile? Did it really help with the clutch slipping during high rpm shifts?
Quick Reply: Drag racing and problems with stock 6MT.
