Does anyone run a k& n short ram?
Old 08-13-2009, 07:53 AM
  #41
ankur914's Avatar
Originally Posted by vt4lifecuf
can someone answer my question please, does it help by removing the oem intake resonator? gain and colder air?
These should help answer your question...
https://acurazine.com/forums/3g-tl-2004-2008-93/stock-cai-tech-549710/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/intake-cai-tech-resornator-removal-549720/
Old 08-13-2009, 12:15 PM
  #42
5th Gear
TLGreenBullet22's Avatar
i didnt feel like spending 300 on a intake so i got a k&n con filter and took out the air box and stock air filter and slid the cone filter on the plastic air hose and used a hose clamp and it works amazing. great sound
Old 08-13-2009, 05:38 PM
  #43
vt4lifecuf's Avatar
Originally Posted by ankur914
thank you very much
Old 08-13-2009, 06:12 PM
  #44
Green Machine
t0talacuratl's Avatar
Has anyone seen this thread? This seems like a good idea for a SRI/CAI combined.
https://acurazine.com/forums/showthr...highlight=blue
Old 08-13-2009, 06:22 PM
  #45
04' tl 6 spd
Joey tl's Avatar
If you want performance get cold air intake, AEM
Old 08-13-2009, 06:40 PM
  #46
GFN0629
gfn0629's Avatar
I saw this post, went outside, removed the rubber piece that connects the Intake box to the intake are inlet, thus removing the "Silencer" and the car sounds just as it would if it had a cold air intake... IMO. I have a K&N Drop filter in the air box, but when I took off the "Silencer", I feel as though the car his pulling more, however I am sure that this is all in my head, because it is the same functionality just removing a "noise restricting" piece.
Also, I had the mid-muffler removed last week and combined with this modification, this is definitely what I was looking for in an exhaust. The note is perfect.
Old 08-14-2009, 11:17 PM
  #47
davewhodavedunn's Avatar
how do you remove the silencer for the intake? I already have the SRI....what are the pros and cons to doing this?
Old 08-15-2009, 12:08 AM
  #48
Green Machine
If you still have the stock intake, removing the silencer makes it louder. Since you have the SRI, this does not apply.
Old 08-16-2009, 12:31 AM
  #49
really? shitty,lol...i could have sworn their is a way to do that on the SRI intake...by the way I just had it installed Friday. Regardless of the talks between SRI and CAI on the TL, I emailed K&N. They claims 6.8 Horsepower on both units. The way the TL is set up, is that their is 2 rensonator tubes, 1 near the rad, and one right by the sri intake, thus enabling the air to be suck from the bottom of the car similar to a CAI. The CAI sucks in a smilar amount of HOT AIR as well due to the fact the the roads in the summer time is very hot as well. I wanted the intake to improve the slow accelartion from 1000-3500 RPMS...with the K&N SRI this improved it significantly, as well as making the car slightly faster. So those of you that don't beleive in SRI intakes, they do work very well as simiar to CAI, on the tl atleased!
Old 08-16-2009, 12:32 AM
  #50
The other con for SRI in a climate such as canada, is the filtre when splashed from a puddle, slush or snow, will freeze with the temperature in below 0, something to keep in mind.
Old 08-16-2009, 12:42 AM
  #51
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Really? How much more hp did it make on the dyno or how much faster did it run in the quarter?
You realize, it doesn't make a bit of difference at full airflow which is at redline. Do you really think it's possible to make a difference at 1,000rpms? If you knew anything about airflow and how engines work, you would know just how rediculous this sounds.
Old 08-16-2009, 10:06 AM
  #52
ok sorry im not a mechanic....all I know is it made the acceleration from 1000 to 4000 rpms quicker than it was, as it was very sluggish in those area's.
Old 08-16-2009, 09:20 PM
  #53
mdunn1066's Avatar
Simple answer:
You lose power and gain sound. I tried it myself, its just not worth it, at all
Old 08-16-2009, 10:15 PM
  #54
Does anyone run a throttle spacer on their car? I have heard mixed reviews saying this mod does nothing, and some say it is worth it...let me know!
Old 08-17-2009, 12:19 AM
  #55
A Black TL
TL|GTX's Avatar
spacer is not worth it either.
ssjkev16
03-08-2020 08:17 PM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
PortlandRL
09-14-2015 12:01 PM
Quick Reply: Does anyone run a k& n short ram?
