DIY: 2004-2008 3G TL Clutch Master Cylinder Replacement
Old 04-29-2019, 09:24 AM
  #41
AT_AT_888's Avatar
Originally Posted by Silver06TL(Mt)
this post hands down helped me so much seriously great write up. I did the check valve delete and for the last 3 days I've been trying and trying to bleed the system. Decided to go for the CMC and when I took the pin out of the pedal assembly the plunger literally fell out. I'm still baffled at how I even had a clutch before all of this. But after new cmc and check valve delete,I've never has such a firm pedal nor grabbed so firmly.
Do you mean you're having trouble fully bleeding the system? Or is everything good?
Old 04-29-2019, 09:32 AM
  #42
Silver06TL(Mt)'s Avatar
I was having problems bleeding . Air kept getting into the system, come to find out the seals were completely blown out on the plunger for the CMC. How I even had a clutch pedal before all this truly baffles me. But after I replaced the CMC I had no issues bleeding the system out.
cobra10363
01-16-2021 08:12 PM
wilztlxs
12-01-2015 09:16 AM
HOWELLiNC
09-05-2015 03:09 AM
heyitsvic
09-04-2015 09:38 AM
Quick Reply: DIY: 2004-2008 3G TL Clutch Master Cylinder Replacement
