Difference between UA6 and UA7 subframe?
Old Apr 1, 2011 | 05:11 PM
lumyeinjun's Avatar
Sorry if I posted in the wrong section. I don't know where this would go
I was wondering if anyone knew what the differences were between the UA6 and UA7 subframe. I messed up my front end in a collision a little over a year ago and it just occurred to me that the body shop put in a subframe from a 2005 TL (UA6) in place of my damaged 2008 TL type-s (UA7) subframe. Anybody know the differences between the two? Weight? Strength? Rigidity? I hope it's nothing major
Old Apr 1, 2011 | 09:01 PM
libert69's Avatar
18psi
subframe part numbers
04-06 TL 5AT & 6MT.........50200-SEP-A03.......$1104.86
07 TL................................50200-SEP-A04.......$1104.86
07 TL-S 5AT......................50200-SEP-A04.......$848.00
07 TL-S 6MT.....................50200-SEP-A12.......$771.20
08 TL................................50200-SEP-A05.......$1104.86
08 TL-S 5AT......................50200-SEP-A05......$1104.86
08 TL-S 6MT.....................50200-SEP-A13.......$1104.86
These are the differences I found in the pictures
Old Apr 1, 2011 | 10:07 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
looks real minor
Old Apr 4, 2011 | 01:52 AM
lumyeinjun's Avatar
hmm... i just hope the material/rigidity is the same :/
Old Apr 4, 2011 | 02:09 AM
paperboy42190's Avatar
i noticed that my 07 tl-s subframe is silver and that other hondas and some acuras i see are black colored.
this leads me to the assumption that the acura tl has a different material front subframe than hondas.
however...i did not know the 07 and 08 tl-s have different part numbers...i hope that doesnt mean my 07 tl-s isnt as good as the 08 ones... :/
Old Apr 4, 2011 | 11:09 PM
n3o's Avatar
n3o
The subframe in the TL is aluminum, hence the silver color so your assumption is correct.
Old Dec 13, 2011 | 12:17 AM
lumyeinjun's Avatar
wonder why the '07 type-s subframes are cheaper than all other years
Old Mar 13, 2012 | 09:05 PM
lumyeinjun's Avatar
Hey guys I'm reviving this thread because I took my 2008 6MT TL type-s to the dealership under warranty this past weekend because the transmission was giving me problems. The reverse gear lock-out would engage even when the car was at a standstill. They've tried to fix the problem before but were unsuccessful. This is the third time they've "attempted" to fix the gear problem, however, I just received a call from the service manager saying that they will not work on my car because it has the wrong subframe on it ('05 subframe).
However, the reverse gear problem occurred before I even replaced the subframe therefore I don't understand how the subframe could be the cause of the malfunction.
Under the Magnuson-Moss Warranty Act I believe Acura can only refuse my warranty if they can prove that my '05 subframe is the cause of my reverse gear lock-out, correct? I need some techs and experts on transmissions to chime in on this please!!!
Old Mar 13, 2012 | 10:14 PM
Richie v6's Avatar
Former Sponsor
The reverse lockout is purely electrical. I would go to a different dealer, this one is trying to pull something over on you.
Old Mar 13, 2012 | 11:36 PM
thisaznboi88's Avatar
that and don't say anything about the subframe. Just say it came like that.
Old Mar 13, 2012 | 11:41 PM
lumyeinjun's Avatar
Thanks Richie, I think going to another dealer would be a good idea. I know the reverse lockout is electrical, but I wonder why they told me that my reverse gear solenoid was damaged and replaced it the last time
and I don't think it will be a good idea to not tell them haha I forgot to mention the '05 subframe has "05 TL" written on the bottom of the subframe haha
Thanks for the input guys!
Old Mar 14, 2012 | 12:07 AM
they won't know if they are not looking. lol Some of the tech are honda and acura are ..... hahah
Old Oct 3, 2012 | 10:10 PM
mashie210's Avatar
I know this is late guys but I recently mess up my 05 acura Tl sub frame and I was wondering if an 07 type s front sub frame would fit in an 05 Tl ? Thanks in advance if anyone have any idea.
Old Oct 3, 2012 | 10:39 PM
type-s subframe is aluminium and weight less, base is steel. Thats why its powdercoated black. to prevent rust
not sure if it can be swapped to answer the second op question
Old Oct 3, 2012 | 11:00 PM
mashie210's Avatar
would you know if its okay to keep driving the way i am while the sub frame is mess up until i locate a used one. Thanks again
Old Oct 4, 2012 | 04:07 PM
KN_TL's Avatar
I've got an 06-6MT and I am pretty sure it's aluminum.
Old Oct 4, 2012 | 06:48 PM
pohljm's Avatar
Base is aluminum!
Old Jun 5, 2019 | 01:58 AM
Anthony Lynn Davis Jr.'s Avatar
6th Gear
subframe
are you saying the an 06 base model tl wouldnt have a aluminium subframe
Old Jun 5, 2019 | 02:03 AM
Midnight Mystery's Avatar
Null and proud of it
Mega-bump...
Old Oct 20, 2020 | 02:51 PM
Bense's Avatar
I pulled a subframe from a 2004 TL base 6MT last week. It is aluminum. I'm putting it on my 2006 Accord Sedan V6 6MT, which has a steel subframe. All TL are aluminum.
Old Oct 22, 2020 | 04:37 PM
oraclem20's Avatar
I was just wondering about this looking at my few subframes. Accord subframe was significantly heavier than my base 2005 TL 6MT. It may be TL 6MTs got the aluminum subframe?
Old Oct 26, 2020 | 06:16 AM
Bense's Avatar
I measured about ~48.8 lbs for the aluminum subframe (this weight includes a 2x4" piece of wood I placed on my scale).
https://www.v6performance.net/thread...8/post-2614260
Old Sep 19, 2024 | 04:47 PM
07touringluxurytypeS's Avatar
04 to 08 Acura TL subframes are all aluminum
I I have had 2005 2007 base and 2008 Acura TL Type S and they all had aluminum subframes I do not believe that there is a steel subframe that is powder coated black if you have that it did not most likely come off an accurate TL but maybe a Honda Accord
Recipe7
3G RLX (2013+)
45
Dec 7, 2015 06:43 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
eastcoastguy
Sep 23, 2015 06:29 AM
