Cold Air Intake vs. Short Ram
6th Gear
short ram intake vs cold air intake.
voice your opinion on which one you thinks is better.
What brand gives the best sound and most gains.
Also if anyone is selling a used one I'm looking to buy one of them.
Received 6,470 Likes
joexchoi (02-24-2013)
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/experiments-air-intake-temperatures-868353/#post14031468
Colder air = more denser air = MORE POWER
My first ricer
SRI = hot engine bay air, CAI = fresh air from outside engine bay. Both sound cool, only one performs better than stock. Only real risk is if you're driving through a flood... the filter is much closer to the ground.
Both will definitely produce more volume and maximum butt dyno. For looks put it in. For butt dyno put it in. For real acceleration, save your money don't put it in, find a girl and put it in.
That's all folks.
That's all folks.
The following 3 users liked this post by beyond 1000:
^ You're point is invalid. See 2:17 :ghey:
LoL. Just kidding. I said it before in my other thread on this subject:
By the way, it's IAT, not AIT. Apparently I'm a
Really though, you probably won't notice a night and day difference with a CAI because the stock intake already pulls relatively cool air from outside the engine bay. I think the stock intake was designed this way because the Honda engineers knew that their agressive timing would have to be adjusted when hotter air was introduced into the engine, thus reducing output. A ram air on the other hand seems to be worse (in my observation) than the stock intake because most of the air introduced this way is from the engine bay. This is unless some sort of system is used to route cool air to the ram air filter.
These are just my observations. Take them for what they're worth. But if you do either, I'd recommend the CAI. I believe the SRI is a downgrade from stock. And while the CAI isn't a massive upgrade, it's a little cooler and a lot less restrictive (and lighter) than stock.
First, I've noticed that the TL is especially sensitive to AIT's. Yes, I know this is already well established around here. But there are several videos and threads discussing the real power output effects of AIT's with some of them stating that it's not as big a deal as some think. With some cars, this may be true. But with the nature of the j-series engines (aggressive timing, compression ratio, etc.) AIT's are a pretty big deal and can significantly affect power output.
Cliff notes - Basically measured temps with CAI vs. SRI. Average IAT's with CAI = 10-20F higher than ambient. Average IAT's with SRI = 40-60F higher than ambient. Went two days, about 100 miles total with the SRI before I swapped it back to the CAI. Unfortunately I didn't have the stock to compare the two. Would have been interesting to throw that one in the mix. Butt dyno's are unreliable at best but the difference between CAI and SRI was dramatic. Considerable drop in response and output.
I've done the UCM however, which might change the dynamics of airflow under the hood and change the way air enters the engine bay. I doubt it has a huge impact but it's worth considering. SRI might be more reasonable in the winter when ambient temps are very low. CAI the rest of the time :P
^he didnt use feelings.
he measured temperatures and based off cooler temps, the CAI is better. duh
IAT = Intake air temperature
the higher the temp = the worse its for your car = reduced timing
the cooler the temp = the more power you will gain.
simple car stuff, evil....
i'm tipsy right now, so excuse me.
butt, I thought thats what this was...
I will gladly take the 10-20 degrees over ambient temps than the 40-60 degrees over.
for example, lets take HOUSTON's ambient temp of 100 degrees.
would you rather be at 120 degrees or 160 degrees!?!?!?!!?!?!??!!?!?!?!?!??!?!?!?!?!?!?!??!? !?!?!?!?!??!!??!?!?!?!?!??!?!?!?!?!?!?!?!??!?!
the engine will perform better at 120 degrees than 160 degrees, do you not agrees!!?
i guess this is what i was referring to a complete experiment. just like they tested this:
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
justnspace (09-25-2012)
I put my money down that stock is better then cai or Sri. I tried both for longer periods of time and sri is more responsive but no power to back it up, only noise!! Cai, response sucks and low end also. Maybe with the cai you would gain 2-3 hp over stock in top end but in terms of regular driving it doesnt even compare. That is the reason why mine is in fhe closet. But to each their own. Its just a noise maker....
Yeah, I don't have quite the budget that the U.S. department of Energy has, but I suppose it would be easy enough to measure whp with IAT's at a certain temperature, say 80F, then introduce 130F air to the engine and remeasure. Although it would be interesting, I don't think it's a critical experiment to conduct. I'm pretty sure I already know what the outcome would be. I doubt it would be a matter of whether power is lost but rather, exactly how much is lost.
Back in college my chem instructor used cold air intakes on automobiles as a case study to demonstrate the Ideal Gas Law and Charles' Law. Not to get too "sciency" or anything but basically put, colder air means more oxygen molecules. This is sort of a "duh" to most of us but it's still sometimes forgotten how much air compresses and expands with temperature since the things we see on a daily basis (solids and liquids) don't expand very much with temps.
Here's a chart showing relative volume of air in relation to temperature:
http://www.engineeringtoolbox.com/ai...ume-d_853.html
As you can see, the difference between air at 70F and 120F is 10% (1.00 vs 1.10) meaning that the amount of oxygen (and all other components in the atmosphere) is 10% higher between these two temperatures. That's pretty significant. Imagine a bottle of water expanding by 10% when heated 50F or a chunk of wood or metal expanding like that. The ECU in any given car also knows this and is programmed to inject the corresponding amount of fuel which theoretically, in this case, should result in a 10% increase in output. That's not always the case as there's lots of factors to consider. But in general, cooler air allows for more output.
EvilVirus (09-26-2012)
I just ordered a cheap SRI on e-bay for about $50. If it's only a noise maker, sure why not. People do cosmetic mods that don't add power. TL (especially with 6MT) is plenty powerful for what it is, at least for me. I wouldn't care about debatable power decrease.
Guys, I believe everything written in this thread. But I can tell you one thing...my Type S feel like it has more power and it feels peppier with the TBS, SRI and J-pipe.
Maybe I'm dreaming, but it's the truth-irregardless.
Actually Justin, I don't hear a whole lot of noise. I never drive with the windows down, so I don't really hear it. I just know the Type S seems to have more pep and more power.
What can I say......
Absolutely...I agree.
My thoughts is if you live in CA, TX, or FL wher eit gets hot, you'll notice the SRI/CAI difference vs people living in Canada and the Northern states. Again, it's preferences where you live and to your power goals in the RPM as well.
You guys posted some great threads on SRI and CAI... BUT what is your opinions on the best CAI on the market today> Meaning the best overall(price,looks and real hp gains). And yes I did my research but I would like to hear your opinions. 2008 Tl 3.2 Thanks if anybody can help.
Now with different brand comes with difference pricing. K&N is going to be the most expensive of course since it's so widely popular and advertised in autozone/o'reilly auto parts.
The following 2 users liked this post by vietxquangstah:
Grob844 (10-02-2012),
HangryMachinist (05-01-2020)
