Clutch master clutch sucks
Old 05-12-2009, 06:03 PM
Bored at work
tl2slow's Avatar
i had my clutch for less than 8k miles and its starting to slip...i broke it in for about 1300 miles and it sucks... i hate the flywheel because it makes the car sound like shit....should i just order a new disk or go with another brand.....
Old 05-12-2009, 07:30 PM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
spec has a stage 4
Old 05-12-2009, 08:44 PM
Green Machine
t0talacuratl's Avatar
Man...I'm sorry to hear that! I wonder if anyone else with the clutch is having issues?
Old 05-12-2009, 09:16 PM
runnin a little boost
Hi speed's Avatar
Are you really hard on the clutch? Is it the flywheel that is making noise or the clutch? I was planning on getting the same set up.
Old 05-12-2009, 09:22 PM
Green Machine
Originally Posted by stillhere153
spec has a stage 4
I thought someone mention that spec was a painted version of the stock setup?
Old 05-12-2009, 09:35 PM
I (don't) whine.
ussi's Avatar
same thing happened to me. PM your info, i'm going to go there to them tomorrow tomo.
do you know exactly what component failed?
Old 05-12-2009, 10:04 PM
The Kinetics of Bleu
TLAdvanced's Avatar
I doubt it. Well, the pressure plate maybe. The disc will be unique. I had a Spec stage 4 on my Camaro and it was unsprung 4 puck carbon/kevlar pads. It was a damn good clutch. I launched at 5500 rpm's with 456 rwhp.
Old 05-12-2009, 10:12 PM
Green Machine
That's good to know....might have to consider this one.
CJ0920's Avatar
Dang man, sorry to hear that! I remember messaging you about your thoughts on the clutch. I'm about ready for one soon...If I take off VSA and run hard, it slips throughout 3rd and 4th!
Old 05-12-2009, 10:41 PM
Bored at work
tl2slow's Avatar
well spec is a very good clutch i had the stage 3 on my turbo h22 accord for 2 years with no problem.... it replaced a clutch master clutch...i should have learn my lesson the first time....
Old 05-13-2009, 04:59 AM
Green Machine
^^Come to think of it, I had a spec stage 3 on my turbo eclipse for a couple of years with no issues as well. Went through two trannies during that time though.
Old 05-13-2009, 05:11 AM
4drs just wanna have fun!
Accord_V6_400m's Avatar
Suprised to hear that about the clutch slipping, usually their clutches are good, I have heard a lot about there ring gear problem causing start up grinding though.
Old 05-13-2009, 09:04 AM
"Like None Other"
djbonsu's Avatar
why not stick with the stock setup....im pretty sure it can handle the bolt-ons and boost we put on our cars
Old 05-13-2009, 11:01 AM
94 DC4 RS LSV/Turbo
here's some more info
http://www.specclutch.com/cars/Acura/TL/2004/Single
fyi anyone who goes anything but stage 1 will surely require new motor mounts... also it is highly suggested to resurface or purchase a stock flywheel
by the way... I may have an integra now... but its not going to be a 4banger for long so I researched the clutch to go with
Old 05-13-2009, 01:22 PM
CJ0920's Avatar
Humm...wonder what you have up your sleeve?
Old 05-13-2009, 02:37 PM
TYPE-S CBP MT
illstrategy's Avatar
I just had the SPEC stage 2 installed on my car, still driving the loaner car from the dealer so cant comment on how good the new clutch is. All i can say is racinghart03 said it "grabs really good"
Old 05-13-2009, 02:38 PM
TYPE-S CBP MT
I think it was EXEDY that was an OEM/Painted setup.
Old 05-13-2009, 03:21 PM
Green Machine
Good job....can't wait to hear your review!
Old 05-13-2009, 04:02 PM
JwongTLS's Avatar
Na, EXEDY is not oem painted clutch, I had the organic on the old integra and it grabbed really good..
Besides I dont think they make a clutch for TL..I could be wrong
Old 05-13-2009, 06:51 PM
Bored at work
tl2slow's Avatar
i would like to get the spec clutch but i paid so much for my setup with the flywheel and i dont want to let it go just yet....
Old 05-13-2009, 06:59 PM
TLAdvanced's Avatar
I hear ya but at this point either you get a free replacement (which probably won't happen, or cut your losses and buy a Spec. You can still use the clutchmasters flywheel just might need to have it cut and have the hotspots removed.
Old 05-13-2009, 07:11 PM
Bored at work
tl2slow's Avatar
they dont use the tl clutch...so i will have to go back to my oem flywheel to use the spec kit...besides start up, the flywheel is great....it revs up soooo fast....
Old 05-13-2009, 07:21 PM
347hp/300tq @ 4psi
04accordcpe's Avatar
wow man that sucks to hear. did you breakin properly? i have about 15k or so and hasnt slipped on me yet :knockonwood:
i actually bought a spec stage 3+ before my CM kit and i wasnt impressed with the looks of it one bit. the disk did look pretty good, but it was a sprung hub disc (not rigid) and wouldnt work well coupled with a dual mass FW. PP on the other hand was nothing more than a stock one painted blue.
one other guy on v 6 P had VERY bad luck with spec clutches. he first got the stage 2 and right after 500 miles bread in it slipped first launch
then he upgraded to a stage 3 i believe and after being on his car, the fingers broke off the spec PP and was spinning around with the assembly tearing up his expensive comptech LWFW. heres a post with pics of the carnage,
http:///forums/showpost.php?p=1345749&postcount=29
^^ not pretty to say the least.
trust me, SPEC IS GARBAGE!!!! at least for our applications.
and the spec clutches arent exactly cheap either. your looking about 850 for the stage 3+ kits. if your looking for a good clutch kit (minus FW) go for the CM stage 3. i think it cost around 700 or so.
EDIT: i forgot acurazine filters EVERYTHING from v 6 P how gay!! ill copy and post the pics right here later on.,
Old 05-13-2009, 07:51 PM
race4ed's Avatar
i my self is looking for a clutch. I want something like everyone else that launches well and never slips. I just hope the CM stage 3 is good.
Old 05-13-2009, 09:11 PM
Former Sponsor
Excelerate's Avatar
You may just have to replace a disc. You'll have to pull the clutch out though to find out.
You won't be able to put the SPEC on the Clutchmaster's setup since the SPEC is designed for the OE dual mass flywheel.
Old 05-13-2009, 09:27 PM
JwongTLS's Avatar
Would you need to upgrade tranny mounts when u upgrade your clutch too?
But as I read somewhere, something about our TL mounts are probably strong enough to handle another 100 hp or so. Does that relate to the tranny mount?
Old 05-13-2009, 10:51 PM
347hp/300tq @ 4psi
ok, i copied and pasted this post with quotes/pics from the OP (6spNaviRacer)
Originally Posted by 6spNaviRacer
The tranny is out and we found more problems.
This is what a new Spec pressure plate looks like.
This what it looks like now... where did the fingers go?
the clutch disc
The flywheel got hammered from the broken pressure plate pieces.
this is why i say F spec..... painted blue OEM PP with a spec label FTL!
Old 05-14-2009, 01:18 AM
NAiL05's Avatar
I used an XTD for a while on my old h22 accord lol that thing held up pretty good and it was a stage 3 haha. Anyway I am looking for a performance clutch. I think exedy makes one for the accord and I would assume that would fit on the TL setup but I could be wrong. They do make OE setups and I would recommend them...I will have to research it a bit.
Old 05-14-2009, 02:35 PM
3rd Gear
likai19870615's Avatar
what kind of sound did you get from the flywheel?
Old 05-14-2009, 03:25 PM
NAiL05's Avatar
Heres an Exedy OE replacement part number...HCK1007 I dunno if they make performance disks for our cars but that would be great. I would go with Exedy if anything. We had a few bolt on H22A's running Exedy Stage 1's and romping them down the track it held up well. I think Exedy reported it as 20-25% more clamping force than the OEM on the H22A...As for the TL I am not sure.
Old 05-14-2009, 04:24 PM
TLAdvanced's Avatar
The rigid discs start at stage 4
Old 05-14-2009, 10:26 PM
Lt. Gamble
madcaps's Avatar
Good Ol' Chatter Master, never cared for their clutches.
Old 05-15-2009, 04:53 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
ok, i have heard soooooooo many different stories about this kit. It almost sounds like whoever installed the OP's kit messed up. everyone else has said it rocks. perhaps your kit was defective. Anyone else that has this kit needs to post their opinions pronto... especially cuz i'm about to buy one.
Old 05-15-2009, 05:06 PM
JwongTLS's Avatar
Try looking into a Spec stage 2 or 3.
Old 05-15-2009, 05:18 PM
I (don't) whine.
ussi's Avatar
I would wait, I had the same exact problem with my kit. I should have a better update for you in a few days...my case went up to their GM and they're looking at the kit closer to determine its fate/future..
Old 05-15-2009, 05:23 PM
I (don't) whine.
ussi's Avatar
dude its not that he was hard on the clutch, he had disengagement issues from the start which eventually caused the disc to fail. The flywheel noise has to do with the starter on the flywheel bc the ringgear isn't the same spec as the stock ring gear. Just hold off a bit on purchasing this...i'll have more details on it soon.
Old 05-15-2009, 10:44 PM
NAiL05's Avatar
Thats the way to do it...People with failed products should send it back and let them see WHAT failed. That way they can at least make the product better instead of constantly manufacturing an on and off product depending on usage.
Old 05-16-2009, 08:46 AM
3rd Gear
^someone already addressed the ring gear issue one year ago, when I got mine kit, same shit ring gear, they didn't fix anything even though they already knew it.....
Old 05-16-2009, 12:00 PM
NAiL05's Avatar
Well then that is crap. A manufacturer should look into there product if it keeps on coming back failing. Oh well...Sucks to be them then. I will stick with exedy.
Old 05-16-2009, 12:10 PM
1st 3g Turbo TL-S
Xiomaro's Avatar
could we use an oem ring gear instead? should be the same notch right?
Quick Reply: Clutch master clutch sucks
