CAI intake with foglights
http://www.aemintakes.com/store/prod...Prod=21-2047DK
I have the dc sports intake as well and noticed that the vibration mount is what pushes the intake out and then pushes the bumper out . Take the vibration mount out and replace with a bolt and a few rubber washers . I used some foam around intake opening to protect the wires and the intake from rubbing . That let the intake sit closer to frame and let the bumper fit the way it should . You could also shorten the pipe and use a different filter oorrrr use the stock intake again .
You can cut a few inches off the end of the CAI then put the filter back on to give you a little more clearance. Thats what I had to with mine.
quanaman
01-09-2023 07:33 PM
lanechanger
10-13-2015 10:56 AM
