Brake Upgrade on 04 AT TL
#41
tehLEGOman
Received 1,983 Likes
#42
AZ Community Team
Received 7,771 Likes
#44
tehLEGOman
Now for the 6MT, it's almost possible to run anything you want. You will need a thicker bracket, or some type of spacer to make it work. I thought about going this route yesterday, but didn't want to risk it.
#46
tehLEGOman
#50
It may be me, thought the dealer said 16" vs. 17"... basically the Brembo rotored cars are an inch larger in diameter than the normal calipers.
#51
#53
tehLEGOman
#55
tehLEGOman
#56
Did anyone solve the problem with the knuckle?
I've the same problem, but i'm here in Germany. I've a 05 AT TL and the Type-S Brembo's with Type-S Rotors and Pads.
#57
i personally did the swap, and you WILL need the knuckles.If you get really lucky then you might be able to save the bearing without having to seperate it from the hub, you will also need the flex-hoses with the little steel line that goes into the calipers.backing plates and rotors are different(11.8"-AT,12.2"-MT).
if the ABS sensors are siezed to the knuckles then you are gonna have to get new ones(i had to get new ones). dont forget the shims that go between the calipers and the knuckles. I had Hawk HPS pads in the calipers i got and they have been pretty good. no noise or squeal.
#58
Oh, it don't sounds good for me. I belive, i'll take porsche calipers on the TL rotors. It's cheaper for me. I don't know, how much i have to pay for knuckles.
#61
tehLEGOman
#62
Feenin on some 20's
Would you happen to know about the RSX BBk's and if it would fit the TL? THe product number's are like 1 # away and i am wondering..........
Thnx Eric.
From my 1-2 hour research yesterday night.. I found that these 3 cars can fit the BBK.
From the Brembo GT BBK kit,.
- 2004 - 2006 HONDA ACCORD V6 COUPE
- 04+ Acura TSX
-04-06 A/T Acura TL
These 2 supposedly fit our cars. I was also noticing soemone who said that their Endless BBK on their RSX WIll fit on a TSX, all you need to change are the brackets, so since that being said, does this mean that this RSX BBK will fit the TL/TSX?
The RSX BBK comes with the bracket that suppsoedly fits on on AP1/AP2, DC5, EP3
I just need a conformation!!!!
TIA guys.
#64
AZ Community Team
John, you can look 'em up here:
http://www.acuraautomotiveparts.org/...omp=List%20All
Most dealers charge the retail price; the parts depot locations charge the discounted price plus shipping.
#66
tehLEGOman
So the BBK's from the TSX's are a direct bolt on for the 5AT TL?
Thnx Eric.
- 04+ Acura TSX
-04-06 A/T Acura TL
TIA guys.
Thnx Eric.
- 04+ Acura TSX
-04-06 A/T Acura TL
TIA guys.
Any kit intended for a TSX will fit the 5AT base model 3rd gen Acura TL.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
04, 45018sepa60, 45022, 45251sepa11, 51215sepa11, a01, a60, acura, brake, brembo, diagram, sep, tl, types, varisengineeringcom
