Acura TL Builder's Ultimate Boost Thread
#122
What are you going to run for methanol? I'll be running Snow Performance Boost Juice this spring on the BMW with the Burger WMI kit. It's convenient, relatively inexpensive and comes in at 49/51 meth/water ratio.
#123
It was 16.4 seconds, but my best time was 15.8. Why did you back out of the CT SC? Saving for a Rotrex?It makes me so happy to work on my car! I find joy in knowing it will soon be a whole new experience driving it.
Dillydly44 (05-29-2021)
#124
Nope, sold it. Loved the car to death after owning it over 9 years, but wanted something smaller, faster and rear wheel drive, hence the M240i. TL is still in the family though. Nephew bought it.
#125
- Just ordered x6 (genuine) RDX injectors
- Cold air intake from ebay is on its way(aswell as some intake piping).
- Dom will tune my car up to the full exhaust and CAI after those are installed next week.
I love living in the PNW! Not a hint of rust.
#126
My dad bought me x6 ik24 Denso Iridiums for my birthday!
https://www.youtube.com/watch?v=F8V1...ature=youtu.be
#128
Finally fixed my non-lifting trunk. Spoiler made it too heavy, so I did the spring trick.
Before -
After - https://www.youtube.com/watch?v=nuefemPeJRI&feature=youtu.be
Finally no more people slamming my trunk not knowing theres no resistance when closing.
Before -
#129
After doing some research on exhaust I have come to these conclusions:
- ATLP Is spot on, low key European sounding without any drone or rasp.(they should make the base single tips again).
- XLR8 has a raspy idle and a high end rasp
- VR6 sounds good but way too much rasp across the powerband
- EndlessRPM sounds nice but has high end rasp
- Magnaflow Rasp/drone
- GReddY sounds good, but the mufflers look ricey
ATLP will be installed this weekend!
Perhaps users of these products have a better opinion? I generated these opinions from Acura TL youtube vids.
#130
I've had the pulley on for about a year now, each year I try to go up. But like I said, I'm still effy about putting on the 2.4in pulley. Each year is a hastle getting the TL to pass inspection, I have to revert back to stock. Plus tuning & data recording, etc, there a lot that goes into maintenance & tuning. I have a manual TL so I lucked out, but I would look into a transcooler. Theres a vent where the rear taillights are, I just stuck the tube there to vent. The methanol kit really does help out though, especially during the summer.
#132
I ran my battery cable from the trunk to under the back seat and then ran the cable along the fuel line. There is a grommet there to pass it through. Also removed the stock battery cable, used 0/1ga for the main cable and 4ga to the under hood fuse box.
Would also suggest that you add a large fuse or circuit breaker right after the the positive connection to the battery. I'll try and dig up my old pictures if you are interested. I had documented all that here using photobucket but they were all lost.
You'll have to do some modifications to the existing fuel pump cage. If no one else has any examples, I will see if I can find any pictures before I went to a return style system.
Nice to see activity here!
#134
Thanks for the suggestion KN-TL, why must I use a fuse, and which size fuse is best for this application?
Duronn - Thanks for that! Did you bolt down your battery box? If so, was it just to the fiberboard?
#135
So I have:
- AEM Water/Methanol Kit
- Denso Iridium IK24 spark plugs
- Supercharger unit x2
- S/C Surp. Belt
- RDX 410cc injectors
- Battery relocation kit
- CAI + Intake piping/couplers
- Hondata Flashpro Acura TL
- Tuner(our main man Dom Toretto)
- ATLP v2 J-pipe, Hi flow Cat., v2 Cat-back exhaust
- RV6 v3 HFPC
- Fiberglass heat wrap
- Laptop with Hondata Software(like Brian Earl Spielner had in Fast n furious)
I still need:
- Waiting on Nate at CT Egnineering to email me back for the remainder of the parts I need. Its Christmas weekend of hopefully soon after.
- You tell me!
Heres the list I sent Nate at CT-E:
355-145 MAP SENSOR PLUG, 04 TL 1 39.00 39.00
805-052 MAP SENSOR O-RING 1 1.99 1.99
800-4013 M5 X .08 X 16 BOLT 1 0.50 0.50
355-112 ALT / BLOWER MOUNT - STEEL 1 149.00 149.00
901-508 THROTTLE BODY GASKET 04 TL 3 2.86 8.58
805-027 EGR GASKET, V6 1 12.00 12.00
Lower Air Boot Brace Bolt (6x21) (Auto) 800-2014
(2) Alt/Blower mount Bolts (8x20) 800-3025
Lower blower Brace Bolt (10x41) 800-4006
(2) Cam Seal Bolts (8 x 30) 800-3006
TL coolant Hose kit (355-231)
- S/C Surp. Belt
- RV6 v3 HFPC
I still need:
- You tell me!
#136
My ATLP exhaust was at my door yesterday and I wasn't home! No! They will be back Tuesday. So Ill install it midweek.
Acura TL Builder (12-24-2017)
The following 2 users liked this post by KN_TL:
Acura TL Builder (12-24-2017),
teh CL (12-25-2017)
#138
Thanks guys! I ordered this one on ebay. Looks exactly the same except for the clear plastic cover. Cheap!
https://www.ebay.com/itm/450-AMP-1-0...4383.l4275.c10
#139
Circuit breakers are awesome. Ran a 150amp one when I relocated the battery in my trunk. I used a sealed battery just because I was worried about the hydrogen out gassing from the battery
#141
I installed Dom's tune to my stock TL today. OMG what a difference! I feels like the car either lost weight, or the car gainer power(specially low end power). The pedal is so much more responsive and torquey.
It seems like the engine and tranny are insync now. I used to have to kinda play with the pedal to get what I needed, now the tranny adjusts to my driving. Most noticeably, it wont shift into the next gear prematurely like it used to.
Its has suddenly become so much more of a pleasure to drive! Dom said I was riding too lean on my stock ECU. Whatever he did has made the experience of driving the TL that much Mo Betta!
Anyone else notice this with their tune on hondata?
Dom is a tuning Wizard! An ECU sorcerer!!
PS bought a gallon of boost juice
#142
#145
Just make sure you measure everything and then compare it to the pump you will be purchasing. I had a Walbro 255 originally and the pump diameter is larger and they just cut the cage where the body slides in and then used nylon tywraps to secure it. I later modified it a bit and used stainless steel tywraps with a foam sleeve to give it some bite. I was later given an Aeromotive pump which I am still running today. I don't recall the model, I will see if I can find any pictures of it when I get home, but it also was in service when I was running on the in tank FPR.
#148
RV6 was the shit, IMO...
I had the V3 Jpipe wrapped in header wrap and high flow cats...
Basically no rasp.
https://www.youtube.com/watch?v=AcsvcwICMbc&t=65s
Basically no rasp.
I watched that clip a few times, the RV6 is good, I really like the ATLP. Sounds heavenly, but it comes down to preference.
#153
How do you guys daily drive a car so loud? I just installed my ATLP j pipe, high flow cat, and resonated cat back, and it's prettttty loud. At 3k rpm my head vibrates. But maybe cause they are not broken in yet.
This is only my opinion. I'm the guy who thinks resonated ATLP is too loud, lol
Acura TL Builder (12-27-2017)
#157
Heres the thing, I tried to get the ATLP with the base tips, but couldn't. I didn't know I would need a new bumper to fit the quad exhaust, so I ghetto rigged it! I bought a new rear bumper for the paintjob im getting soon, I will just send it back and order a type-S, or possibly buy the A-SPEC lip if I can find it.
I take back my "opinions" about the Exhausts. They all sound good in their own respect. What happened to mine was whilst ghetto rigging it, I didn't Ghetto rigged for now.
Ghetto riggy
Old exhaust system,
Second supercharger!!
AEM Water/Meth kit came in!
notch out enough bumper and the muffler tip was hugging the plastic and creating vibrations into the cabin.
Ghetto riggy
Old exhaust system,
#158
Here is a Test Drive of the new Exhaust. Still waiting on the v3 RV6 HFPC to come in.
https://www.youtube.com/watch?v=cNrU...ature=youtu.be
#159
When is comes time to reseal your new S/C'er at the snout, the flange sealant on the link below works well.
#160
https://www.amazon.com/SEPTLS4423915.../dp/B0026GOLJW
Btw, I know its winter and the car is dirty and ghetto rigged int he back. But she will be brought back to life with new bumpers and fresh paintjob(after the S/C goes in).
Can someone give me a suggestion on what to do about the bumper situation? I bought a new one, but its a Base bumper. So these quad tips won't fit the new one.
