Acura TL Builder's Ultimate Boost Thread
Old 12-06-2018, 07:37 AM
  #601
rockstar143's Avatar
Received 19,914 Likes on 14,457 Posts
the one he takes pictures of is a detailed model of one...
but the one he's buying is in NY or NJ or something, although I had a hard time following the story.
Old 12-06-2018, 09:15 AM
  #602
Acura TL Builder's Avatar
I’m not buying the NY TL. I bought a used one from a dealership in Seattle.
Since I’m flying to Portland through Seattle, I will skip my flight from SeaTac to PDX and take a 24 minute Uber
from Sea-Tac to the dealership in east Seattle. Sign the release paperwork and drive the car with wifey back to PDX airport to pick up our checked luggage(which will be at the “left and found” areas once we will be there two hours after our final destination flight comes in.
Its only a 15 minute ride home from there. Then it’s back to reality on Monday!
Old 12-06-2018, 09:17 AM
  #603
Damn, really?
That's exciting.
and your story is much easier to read when you're sober, bro.
Old 12-06-2018, 12:32 PM
  #604
Received 1,731 Likes on 1,389 Posts
Does that 'reality' include the expedited install of the Rotrex?
Old 12-06-2018, 12:41 PM
  #605
I’ve been putting a lot of thought into that. Because of the condition and mileage of the car, I’m willing to drive it as is for some time. You know, enjoy it the way it was ment to be enjoyed.
Im worried that if I install the Gerzy Bear Performance goodness then I’ll expediatedly wear out the otherwise good clutch. Not sure yet. Whatchall think?
Old 12-06-2018, 01:19 PM
  #606
of course you will...
you'll be sending it all the time.
Old 12-06-2018, 01:27 PM
  #607
I plan to keep the Rotrex as the garage queen and daily drive the Comptech.
Old 12-06-2018, 01:36 PM
  #608
hey man, you said you would do it, and you have.
kudos on that.
Acura TL Builder (12-06-2018)
Old 12-06-2018, 01:42 PM
  #609
kudos on that.
Thanks buddy! It’s important to do so. Otherwise, regrets and frustrations from unappreciated goals add up.
Old 12-06-2018, 01:47 PM
  #610
well, your goals could change and no harm no foul
but being a guy that's all talk is fucking annoying...
Old 12-06-2018, 02:19 PM
  #611
Goals change, but a goal should always be there.
Who is all talk? You talk about that a lot
Old 12-06-2018, 02:35 PM
  #612
When you first got here and posted your plans you sounded a lot like most members that are all talk.
Old 12-06-2018, 03:16 PM
  #613
Come on brah!
With two to four jack stands, a couple of good hydraulic car jacks and the hand tools you already have in your garage, I bet a 'spring buck' like you could replace a 6MT clutch in 36hrs or less. Along with that time investment, if you purchase an appropriately researched/rated clutch/PP/FW package for the hp level the Rotrex will deliver, you'll be set and DONE.
Old 12-08-2018, 02:36 AM
  #614
Originally Posted by zeta
Come on brah!
Lol, thank you for the encouragement. I still have not picked it up from the dealers. It will be fun to drive with my wife, three airport bags, and four tires from Seattle to Portland.
Old 12-08-2018, 10:06 AM
  #615
I drove the blue TL from Ohio to Ft Lauderdale with 4 rims/tires and a aspec side skirts in the car
Old 12-08-2018, 01:38 PM
  #616
ohnoitspiter's Avatar
How hard/often does your friend drive his TL? Seems 450whp is on the low side for a built engine + Rotrex.
I drove it every day as it is my only car. Put anywhere from 40-120 miles a day. And 450whp was low due to the auto trans which sucks a lot of power and the pistons lowering the compression. With E85, I was at 484whp. If it was a manual, I wouldn't doubt 540-560whp
Old 12-08-2018, 01:42 PM
  #617
alltrac's Avatar
Good luck getting 4 tires and 3 bags in your new TL.
Old 12-08-2018, 01:45 PM
  #618
Originally Posted by 6spd-GERCO
Replacing the stock sleeves with aftermarket one is never a bad idea if you are putting in pistons and rods. 480WHP is an awful lot on stock sleeves and 93 pump gas.
If you do go with aftermarket sleeves with new pistons, consider increasing the bore diameter for more jam. I went +3mm bore on my B series and made +15WTQ across the entire power band on a sub 2.0L engine.
Stock sleeves can hold their own. There are turbo Js holding more than 500whp on stock sleeves no problem . My case was unique and unfortunate...for the second time as the first rebuild I bent 4 rods. The Jseries service limit is +1mm bore btw.
Old 12-11-2018, 12:02 PM
  #619
Managed to get all four tires three checked bags, and four carry on bags in the car! Wife and I fit comfortably aswell
Old 12-11-2018, 12:11 PM
  #620
Finally took it out for a drive!
Old 12-11-2018, 12:44 PM
  #621
they did a good job cleaning it up although hard to tell from an overcast day...
congrats, man...you must be very happy
Acura TL Builder (12-11-2018)
Old 12-11-2018, 01:56 PM
  #622
Jeremy, I am overjoyed to finally have another 12 y/o automobile in the driveway. Really though, I just looked out and am in disbelief that it’s actually here.
I’m having a hard time convincing myself to modify this TLS.
It drives like a dream. Everything about it feels so sharp and crisp. The rowing of the gears is so smooth and effortless, while maintaining its integrity and rigidity.
If I modify this TL, I’ll feel like I’m ruining a near prestine example of the 6MT Type-S. I’d like to buy another TLS 6MT with higher mileage, 140-200k depending on maintainence history. It would allow me to daily this one, and install the GBP Rotrex into a well used unicorn. This plan would have me sell the Comptech due to space constraints. Someday I’d like to buy a house with a barn dive shop like all those fancy pants people in the countryside like Horseshoez.
On the other hand, I could install the Grizzly Gerzy Bear Performance system into this fine example and enjoy it. This would allow me to daily the Comptech TL. Which I strived to make reliable, because I picked fast and reliable.
Old 12-11-2018, 01:59 PM
  #623
BreezyTL's Avatar
Lets be honest. Rotrex the bitch!
Acura TL Builder (12-27-2018)
Old 12-11-2018, 02:43 PM
  #624
90foxnotch's Avatar
Looks a lot better now, glad to hear it all worked out. As far as modding goes it'll be fine, boost with a 6mt would be fun. Just keep all your stock parts that you take off.
Old 12-21-2018, 08:48 AM
  #625
Thanks guys,
I got got a new camera to take pics of the cars.
Old 12-21-2018, 08:51 AM
  #626
It’s only been 12 months since that fateful day when I bought a 2G Comptech Supercharger thinking I could make it fit onto my 3G.
Old 12-21-2018, 08:59 AM
  #627
hmmm...
Old 12-21-2018, 03:09 PM
  #628
You don’t like the camera made by Acura?
Old 12-21-2018, 07:13 PM
  #629
I don't think you ordered it.
Old 12-22-2018, 08:58 AM
  #630
To say the least, now you know to be wary of jonesing 'tweekers' bearing gifts looking for their next 'hot rail'.
Old 12-22-2018, 12:12 PM
  #631
Those people were scary. But luckily we have @gerzand to sell us high quality products through Gerzy Bear performance.
@rockstar143 it’s coming soon. The cup matches the 6MT.
Old 12-22-2018, 05:16 PM
  #632
Got two Thor hammers with Acura logos, part of marvel comics/Acura collaboration.
Old 12-23-2018, 07:30 PM
  #633
Red face
Washed, clay barred, waxed the 6MT today.
Old 12-23-2018, 07:49 PM
  #634
-------Tim-------
Slpr04UA6's Avatar
^Nice!
Old 12-25-2018, 06:20 PM
  #635
runnin a little boost
Hi speed's Avatar
I have been away from this forum for a while, did any SC get installed?. Forced induction is a lot of fun on the TL, the only downside I have experienced is the need for a more high performance clutch which takes some of the smoothness out of driving that I liked from the car. I loved the whine and extra 100 WHP of the Comptech SC, but the additional 500 whp the turbo provides is slightly wining out. Big HP in the TL is a lot of fun, very expensive but a lot of fun. Nobody expects the car to move the way it does and there is pretty much no one who can touch you. It does make the car most impressive at freeway speeds but pulling on anything like they hit the brakes is fun. Since turbo is not really an option anymore the SC is the way to go. Don’t be discouraged but the Comptech haters 100 whp increase really transforms this car especially with a 6 speed.
Old 12-25-2018, 11:08 PM
  #636
No rust or oxidation on anything.
The calm before the storm.
A/C radiator all gone!
A/C radiator and fan ready for storage.
Removed plenum
Always serviced at Acura.
I installed the Comptech Sports S/C, currently installing Rotrex on another vehicle.
Old 12-26-2018, 06:14 AM
  #637
I can only imagine how much fun it would be...
why is turbo not an option anymore?
@Hi speed
Old 12-26-2018, 06:34 AM
  #638
@Hi speed How is your motor, tranny, and setup doing so far? Any issues?
Old 12-26-2018, 07:14 PM
  #639
Hi speed's Avatar
The car is doing great, both the engine and transmission are holding up perfectly. I am running 24 psi at this point so I’m far above my 500 whp start point.
I don’t slam gears and only get into boost once the clutch is engaged so the stock transmission is doing well. The car is really a beast and will smoke the tires well into triple digits. I love it, full sleeper status and more WHP than most super cars all wrapped in a amazing looking luxury wrapper.
To answer the question about the turbo no longer being an option. I have been out of the Acura scene but know only 15 ish P2P kits made and not many members are willing to part with such a nice kit.
The following 2 users liked this post by Hi speed:
Acura TL Builder (12-27-2018), rockstar143 (12-27-2018)
Old 12-27-2018, 08:35 AM
  #640
This rotrex is my turbo. Someday I’ll upgrade the engine components and put on a larger Rotrex unit.
Quick Reply: Acura TL Builder's Ultimate Boost Thread
