ATLP test pipe vs RV-6 J-Pipe
whats the point of getting the whole j pipe when you can just get the test pipe. the gains would come from deleting the 3rd CAT so can someone justify that the j pipe would be better. is it just a larger diameter than stock?
Yes, it is a larger diameter. It is also engineered to improve flow and reduce the restriction that is inherent in the stock j-pipe. If you look at the two side by side it's a bit more obvious.
This is the RV6 v3 but other pipes work on the same principle. For some reason Acura used a pipe that is quite restrictive, especially on the outlet from the rear cylinders. In addition, each outlet has its own dedicated pipe rather than sharing one like in the stock. This is probably why the jpipe is considered one of (if not the) best bang for the buck mod for the TL.
nice more than i expected as far as info. im going to order that v3 looks like its built well. how are those HFPC. i got an ATLP base exhuast and wanna add this V3 but is it useless without moding the pre cats?
and have you ever had ur car on a dyno? i have access to one through ivy tech but am just waiting to finish moding? i hear different things as far as gains. love this car just wish it had more balls sometimes.
J-pipe adds 10-15 hp. The J-pipes are bolt on and deletes the 3rd cat.
J-pipe wouldn't be useless, if you added HFPC or deleted cats you'd just add to the performance.
The HFPC's are great. Here's my review:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/review-rv6-hfpcs-852685/
No, I've never dyno'd. Just go by the seat of my pants really
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
