Any cam dynos?
Old 11-04-2014, 09:48 AM
  #81
mzilvar's Avatar
Originally Posted by thisaznboi88
^ its in my accord. J30a5 with PnP j35a8 head. Now I am waiting for camshaft gears to come out. (see image below) TB Motorworkx has been using them and rev their car up to 11k
j32a2 Adjustable Cam Gears
Cool someone is making adjustable cam gears for the j, those will fit a lot of engines most of the j series cam gears have identical part numbers
Old 11-04-2014, 01:40 PM
  #82
All motor
Sonnick's Avatar
TB Motorworx has the Cam Gears in stock for $350+ shipping.
thisaznboi88 (11-04-2014)
Old 11-04-2014, 09:06 PM
  #83
Grand_hustle17's Avatar
Waaaait wait wait..... So i can buy these and just pair em up with type S cams right?... Now that the excitement is done.... Why is this so beneficial? .. Srry dont know about cam gears and how they affect our cars
Old 11-04-2014, 09:40 PM
  #84
thisaznboi88's Avatar
they change the center line of the camshaft. Makes the valve open soon or later compared to top dead center of the piston. Shift the power band and blah blah blah. google camshaft phasing and overlap
Grand_hustle17 (11-04-2014)
Old 11-04-2014, 09:45 PM
  #85
6spd-GERCO's Avatar
Whatttt? now you want technical details???
Old 11-04-2014, 10:02 PM
  #86
Yea... Id like to know the technical details.. After i hear such details ill determine if its info i care about or not... Cams i understand the technical info.. Ppl yapping about it being hollow n light doesnt justify not even $.01 lol.. Least not for me lmao
Old 11-04-2014, 10:04 PM
  #87
#goestosearch
Old 11-04-2014, 10:36 PM
  #88
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
or you can buy it because its shinny!!
Old 11-04-2014, 11:37 PM
  #89
DomGSR-T's Avatar
This would be a very good mod but a real pain to tune them on the dyno. Would take 20-30min per degrees/settings on both cams for each test. Maybe the valve covers could be cut for easier access like the B series. Not sure if it would be enough to set them without removing the manifold.
Old 11-05-2014, 12:22 AM
  #90
Phuq all that shinny shit lmao... But no lies the online catalog sucks ass hahahaa.. I dont see where they offered anything J-series
Old 11-05-2014, 01:09 AM
  #91
screaminz28's Avatar
LOL I'm pretty sure he linked that not for items specific to the J series, but so you could find the technical details as to the cam gears benefit. Once you've read it, just imagine how much more torque you would make if you could use FOUR of them!
Old 11-05-2014, 01:49 AM
  #92
Old 11-05-2014, 07:00 AM
  #93
just image it as the toyota VVTI but you can only choose to gain more low-end by giving up top end or vice versa since they are not adaptive.
Old 11-06-2014, 07:24 AM
  #94
Would be nice
Old 11-06-2014, 11:46 AM
  #95
gerzand's Avatar
These are only for first generation jseries engine blocks guys. They will NOT work on the 3rd Gen+ TL or 7th Gen+ accord, etc. I have spoken to AD Engineering (Andy) several times over the past couple years about developing a set in tandem, yet they have just recently (in the past 5 days) began taking a serious look at creating gears for newer block designs. I am confident it will be released, but there is no ETA at this point.
Put simply: unless you own a factory drive by cable jseries equipped Honda/acura , don't bother ordering these just yet.
The following 2 users liked this post by gerzand:
Sonnick (11-06-2014), thisaznboi88 (11-06-2014)
Old 11-06-2014, 02:21 PM
  #96
3.5 psi
gnuts's Avatar
it's too bad the heads on the 1st series J didn't continue using the proper headers. although you could do what gerzand did.
Old 11-06-2014, 04:04 PM
  #97
Originally Posted by gerzand
these are only for first generation jseries engine blocks guys. They will not work on the 3rd gen+ tl or 7th gen+ accord, etc. I have spoken to ad engineering (andy) several times over the past couple years about developing a set in tandem, yet they have just recently (in the past 5 days) began taking a serious look at creating gears for newer block designs. I am confident it will be released, but there is no eta at this point.
Put simply: Unless you own a factory drive by cable jseries equipped honda/acura , don't bother ordering these just yet.
damn it!
Old 11-06-2014, 05:24 PM
  #98
gerzand's Avatar
The heads/cams are only one part of the equation. The block is also to blame. I cant run them either.
Old 11-06-2014, 05:26 PM
  #99
need a v6 DOHC with VTC on both camshaft. ;p that would be a dream come true from honda
Old 11-06-2014, 08:03 PM
  #100
FamilyGuy's Avatar
NSX? V6 DOHC right? Not sure bout vtec on both intake/exhaust.
Old 11-06-2014, 08:52 PM
  #101
anx1300c's Avatar
Seems bishi cams may be less expensive... Just called web cams for a custom reground its $950
Are you sure the person you were talking to didn't think we were DOHC, hence having four cams? I mean if Bisimoto was using Web and then turning around and selling them in the $700 range, I'd guess Bisi was only paying Web around $400-500, possibly even less if they had a high volume relationship.
I've also seen online shops selling DOHC 4 cyl cams reground by Web (cams included) in the $800 (per pair) range. And regrinding two 4 cyl cams is more labor intensive than regrinding two V6 cams.
Old 11-06-2014, 08:56 PM
  #102
J-series addict
yungone501's Avatar
If you're cam designer knows what the hell he is doing, cam gears aren't nearly as important as choosing the correct profile.
Now the DOHC Honda V6...yes, please.
Old 11-06-2014, 09:26 PM
  #103
not just Vtec on both side (don't see why not since k20/k24 has), but also VTC to modify valve overlap timing.
But D16 people are running cam gears on top of camshaft.
I think if you mill your heads or add a cosmetic gasket cam gears will help bring the camshaft into the correct geometry again
** On a side note, Robert do you have extra valve spring laying around? Could you measure the valve spring press on a regular j32a3,j35a8, j35z#,and j37a#? I am just curious since I was told j35a8 exhaust springs were good up to 7500. J32a3 were good for 7300. Just I just want to verify that they do indeed have higher seat pressure.
Old 11-06-2014, 09:51 PM
  #104
J-series addict
yungone501's Avatar
Cam gears have purpose. I was just being a smart ass. But in a geometrically correct engine (especially SOHC) that has had the cam specifically designed for its application and exact combination of parts, they are practically useless due to single reason of not being able to manipulate the centerline without affecting ramp rates (both sides) as well. This literally will give the same camshaft a completely different profile even when adjusting a single degree of timing. Again, especially with a SOHC that utilizes the same camshaft for intake and exhaust.
I have the pressures already but will have to locate them. Are you meaning their individual pressures at their own, application specific installed heights?
Old 11-06-2014, 10:04 PM
  #105
anx1300c's Avatar
Forgot about Gude Performance being an option too. Their price was $540 for our regrinds two years ago. Doubt it's much, if any more expensive now.
https://acurazine.com/forums/second-...series-873639/
Old 11-06-2014, 10:05 PM
  #106
Just looking for the individual pressure. I was told j32a3 and j30a4/5 were 55psi for the exhaust. Not sure how accurate that is, and that j35a8 were 15% stiffer on the exhaust so ~63psi?
No clue what the intake were for any variation of the j30-37.
Trying to find hard evidence what they really are.
Old 11-07-2014, 04:18 AM
  #107
They said all custom regrounds are $950
Old 11-07-2014, 05:11 AM
  #108
Ill call em up
anx1300c (11-07-2014)
Old 11-07-2014, 02:16 PM
  #109
J-series addict
yungone501's Avatar
Heads up on Gude, Bill the owner is a very dishonest business man.
thisaznboi88 (11-07-2014)
Old 11-07-2014, 04:41 PM
  #110
anx1300c's Avatar
Well, do tell please....
Old 11-07-2014, 05:21 PM
  #111
I think im officially done with aftermarket cams... Some type S or RL's will do
Old 11-07-2014, 05:50 PM
  #112
just buy MDX camshaft. they are cheaper compared to RL and TL-S
Old 11-07-2014, 06:02 PM
  #113
All motor
Sonnick's Avatar
Just buy my heads.
Grand_hustle17 (11-07-2014)
Old 11-07-2014, 08:14 PM
  #114
Wait... So are they just drop ins?..... The more i think im figuring out the more i confuse myself lmao..... Soooooo mdx cams just drop right in the J32a3 heads?.. No spacers no nuttn?
Old 11-07-2014, 08:36 PM
  #115
@ Grand_ Hustle
09 MDX camshaft is the same profile as TL-s, cost less, and if its any consolation they are lighter.
I have them in my J35a8 on my j30a5 block. So in short yes they will be plug and play. I would also suggest upgrading the exhaust valve if you plan to run them. Probably not needed, but always nice to have over rev protection.
@ yungone501
My I please have the spec of those valve springs pressure? Maybe create another thread? Thanks!
Old 11-07-2014, 08:42 PM
  #116
I do have to get exhaust valves.. I was going to order it tonight.... Which ones did you go with?.. Do they all fit the j32?... I just ordered intake valves.. But oem... Whats an upgraded valve?
Old 11-07-2014, 09:51 PM
  #117
Just to be clear. Yes they will fit j30a4/5, j32a3, and j35a8. So yes they will fit your car
I have TL-S intake and exhuast valve springs. You can probably get away with the stock intake spring. Most time people that over rev destroy their exhaust valves.
SO ORDER VALVE SPRINGS!! Not valves.
Old 11-07-2014, 11:02 PM
  #118
Ah
Old 11-15-2014, 10:42 PM
  #119
Anyone has the spec on 07 mdx cams vs type S?
ExcelerateRep
10-14-2015 08:20 AM
Papa Roe
09-26-2015 11:45 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
V12 Inspire
09-10-2015 04:46 PM
Quick Reply: Any cam dynos?
