Any cam dynos?
#81
^ its in my accord. J30a5 with PnP j35a8 head. Now I am waiting for camshaft gears to come out. (see image below) TB Motorworkx has been using them and rev their car up to 11k
j32a2 Adjustable Cam Gears
#82
All motor
TB Motorworx has the Cam Gears in stock for $350+ shipping.
thisaznboi88 (11-04-2014)
#83
Waaaait wait wait..... So i can buy these and just pair em up with type S cams right?... Now that the excitement is done.... Why is this so beneficial? .. Srry dont know about cam gears and how they affect our cars
#84
they change the center line of the camshaft. Makes the valve open soon or later compared to top dead center of the piston. Shift the power band and blah blah blah. google camshaft phasing and overlap
Grand_hustle17 (11-04-2014)
#86
Yea... Id like to know the technical details.. After i hear such details ill determine if its info i care about or not... Cams i understand the technical info.. Ppl yapping about it being hollow n light doesnt justify not even $.01 lol.. Least not for me lmao
#87
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
or you can buy it because its shinny!!
#89
This would be a very good mod but a real pain to tune them on the dyno. Would take 20-30min per degrees/settings on both cams for each test. Maybe the valve covers could be cut for easier access like the B series. Not sure if it would be enough to set them without removing the manifold.
#90
#92
Would be nice
#95
These are only for first generation jseries engine blocks guys. They will NOT work on the 3rd Gen+ TL or 7th Gen+ accord, etc. I have spoken to AD Engineering (Andy) several times over the past couple years about developing a set in tandem, yet they have just recently (in the past 5 days) began taking a serious look at creating gears for newer block designs. I am confident it will be released, but there is no ETA at this point.
Put simply: unless you own a factory drive by cable jseries equipped Honda/acura , don't bother ordering these just yet.
The following 2 users liked this post by gerzand:
Sonnick (11-06-2014),
thisaznboi88 (11-06-2014)
#97
these are only for first generation jseries engine blocks guys. They will not work on the 3rd gen+ tl or 7th gen+ accord, etc. I have spoken to ad engineering (andy) several times over the past couple years about developing a set in tandem, yet they have just recently (in the past 5 days) began taking a serious look at creating gears for newer block designs. I am confident it will be released, but there is no eta at this point.
Put simply: Unless you own a factory drive by cable jseries equipped honda/acura , don't bother ordering these just yet.
#100
I've also seen online shops selling DOHC 4 cyl cams reground by Web (cams included) in the $800 (per pair) range. And regrinding two 4 cyl cams is more labor intensive than regrinding two V6 cams.
#103
not just Vtec on both side (don't see why not since k20/k24 has), but also VTC to modify valve overlap timing.
But D16 people are running cam gears on top of camshaft.
I think if you mill your heads or add a cosmetic gasket cam gears will help bring the camshaft into the correct geometry again
** On a side note, Robert do you have extra valve spring laying around? Could you measure the valve spring press on a regular j32a3,j35a8, j35z#,and j37a#? I am just curious since I was told j35a8 exhaust springs were good up to 7500. J32a3 were good for 7300. Just I just want to verify that they do indeed have higher seat pressure.
Originally Posted by yungone501
If you're cam designer knows what the hell he is doing, cam gears aren't nearly as important as choosing the correct profile.
Now the DOHC Honda V6...yes, please.
#104
J-series addict
I have the pressures already but will have to locate them. Are you meaning their individual pressures at their own, application specific installed heights?
#105
Forgot about Gude Performance being an option too. Their price was $540 for our regrinds two years ago. Doubt it's much, if any more expensive now.
https://acurazine.com/forums/second-...series-873639/
#106
Just looking for the individual pressure. I was told j32a3 and j30a4/5 were 55psi for the exhaust. Not sure how accurate that is, and that j35a8 were 15% stiffer on the exhaust so ~63psi?
No clue what the intake were for any variation of the j30-37.
Trying to find hard evidence what they really are.
#107
Are you sure the person you were talking to didn't think we were DOHC, hence having four cams? I mean if Bisimoto was using Web and then turning around and selling them in the $700 range, I'd guess Bisi was only paying Web around $400-500, possibly even less if they had a high volume relationship.
#108
anx1300c (11-07-2014)
thisaznboi88 (11-07-2014)
#111
I think im officially done with aftermarket cams... Some type S or RL's will do
#113
All motor
Grand_hustle17 (11-07-2014)
#114
@ Grand_ Hustle
09 MDX camshaft is the same profile as TL-s, cost less, and if its any consolation they are lighter.
I have them in my J35a8 on my j30a5 block. So in short yes they will be plug and play. I would also suggest upgrading the exhaust valve if you plan to run them. Probably not needed, but always nice to have over rev protection.
@ yungone501
My I please have the spec of those valve springs pressure? Maybe create another thread? Thanks!
@ yungone501
#116
I do have to get exhaust valves.. I was going to order it tonight.... Which ones did you go with?.. Do they all fit the j32?... I just ordered intake valves.. But oem... Whats an upgraded valve?
#117
Just to be clear. Yes they will fit j30a4/5, j32a3, and j35a8. So yes they will fit your car
I have TL-S intake and exhuast valve springs. You can probably get away with the stock intake spring. Most time people that over rev destroy their exhaust valves.
SO ORDER VALVE SPRINGS!! Not valves.
#118
Ah
#119
Anyone has the spec on 07 mdx cams vs type S?
ExcelerateRep
10-14-2015 08:20 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
