Any Cali people passing smog with HFPC
Old 07-31-2012, 10:11 PM
Bruce Banner's Avatar
Just wondering if any CA members are passing smog with HFPC on their TL's
Old 07-31-2012, 11:31 PM
Series Motor's
TrustinHFDJ's Avatar
Hey bro, didn't you just get an answer on that in the last thread? It depends on what set-up you have on the exhaust; the gentleman posted his passing with statistics while using 3 HFC and even probably passing with 3rd delete, as he stated.
pohljm (07-31-2012)
Old 07-31-2012, 11:43 PM
pohljm's Avatar
Yeah...........I thought I answered that specific question already?
Old 08-01-2012, 12:57 AM
Looking for a headcount to get a good sense of the odds.
Specifically I'm wondering about the RV6
Old 08-01-2012, 01:33 AM
gwiffer's Avatar
I'm a resident of a non-emissions testing state...
What happens if you test and fail? Can you put the OEM cats back on and test again?
Old 08-01-2012, 08:36 AM
Bleak's Avatar
Yes, you can try again. I failed in Cali with just RV6 V3 jpipe because it's missing the 3rd cat and the tech noticed and ask what that shiny pipe is. Then failed me on the visual. I switched it back to stock and went back the next day and passed.
Old 08-01-2012, 09:28 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
For what the answer is there and in previous threads
Old 08-01-2012, 09:29 AM
EvilVirus's Avatar
what do you think.......uh yeah
Old 08-01-2012, 04:38 PM
gwiffer's Avatar
Did you pass the sniffer since you still had stock pre-cats?
Does it cost money to get tested each time?
Do the testing centers report any failures (sniffer or visual) to the city/state?
Old 08-01-2012, 07:02 PM
Bleak's Avatar
Yes I was way under legal limits on the actual emissions sniffer test.
The place I went had a free re-test policy but it can vary I think.
I'm pretty sure all their stuff goes through DMV but I haven't had any bad effects from failing... I did pass it the next day so maybe it overwrites any failure messages. Dunno.
Old 08-01-2012, 07:07 PM
I failed cali smog before with a bad cat. I had it retested with a new cat and there were no consequences.
I am reading that the HFPC will fail visual.
Old 08-01-2012, 08:00 PM
runnin a little boost
Hi speed's Avatar
My feeling is once they notice you are playing with the cats or fail visual, the car is labeled a gross polluter and you are in trouble. You need to reinstall the stock cats and have it smoged, the risk of trouble is not worth the couple hrs work to change out the cats.
Old 08-01-2012, 08:51 PM
pohljm's Avatar
Of course HFPC will fail the visual if they know what they are looking at. my tech did not even do a visual on the 3rd cat.
Old 08-05-2012, 10:44 AM
Just so I know, why would a HFPC fail visual?
It's still a precat, it just flows more.
Old 08-05-2012, 11:23 AM
pohljm's Avatar
it is completely illegal to tamper with any emissions equipment.
Old 08-05-2012, 11:39 AM
Bleak's Avatar
It also pollutes more. Like the guy above me said tampering with any of them is illegal.
Old 08-05-2012, 11:49 AM
According to Wiki, it's not illegal to tamper with it, but illegal to remove it and not replace it with another immediately.
Just browsing on the net the visual is more to see if the component if there and installed correctly. A smog tech isn't going to be able to tell if that is your car's OEM cat or not.
The visual doesn't discover if it pollutes more or less, that's the emissions part.
Not arguing, this is just what I'm finding on the net and I'm trying to figure out why it would fail visual when there is a component there and installed correctly.
When my old car failed smog due to a bad cat, the authorized shop replaced it with a magnaflow that met the state emission standards, which was totally not OEM.
Old 08-05-2012, 01:46 PM
Bleak's Avatar
I think a big part of failing visual is stuff not looking OEM. Then the tech looks for a CARB sticker (Intakes are like... the only thing that have those it seems). My precats are ceramic coated and ridiculously shiny so they'd probably throw up red flags.
You're probably right though that if it looks like a cat, and is in the spot that is supposed to have a cat... it'll probably be fine on visual.
What I'd wonder though is would HFPCs even pass the emissions portion?? I'd guess no.
Old 08-05-2012, 02:08 PM
pohljm's Avatar
if they look for a third cat and its not there.............fail
if they look for primay cats and there is something there that doesnt look quite OEM then they will test it. My HFPC pass cali smog tests.
Old 08-05-2012, 03:40 PM
Bleak's Avatar
Cool, thanks for your anecdote. I failed with no 3rd cat but wasn't sure about HFPCs. I just got PCDs in the mail so smog is now a "definitely gonna fail no matter what" type of situation.
Old 08-05-2012, 03:57 PM
Let us know if that passes, might still pass emissions withteh 3rd cat.
You can do a pretest to find out before a real smog.
Old 08-05-2012, 04:03 PM
Bleak's Avatar
It definitely won't haha. I'm going to have 0 cats once I put these on. I did smog last month though so I won't have to swap them for a while.
Old 06-03-2014, 02:58 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
Has anyone passed smog in CA with hfpc AND the rv6 v3 jpipe?
Old 06-04-2014, 12:05 AM
sockr1's Avatar
Received 1,160 Likes on 909 Posts
I forget what thread but I remembered reading that it does. This week I'm doing HFPCs and HFC on v1 xlr8 j pipe which is not the same, but may provide some insight. I'm worried more about visual with the aem v2 and the HFPCs
Old 06-04-2014, 12:59 AM
yeah I do remember reading it might...but I dont really want to go get a smog check thinking it might pass when it wont. if there's any members that have done the hfpc with 3rd cat delete and passed in CA, I'd definitely like to know. it might give me the incentive to get the atlp v2 jpipe instead of rv6 v3 if it wont pass without the 3rd cat
Old 06-06-2014, 02:25 AM
ttt
Old 06-07-2014, 12:22 PM
sockr1's Avatar
My car didn't pass cali smog with HFPCs and high flow 3rd cat. You're screwed without third cat and HFPCs. The smog place didn't have a working printer so in not sure how close I was. I'm going to put back my oem 3rd cat and go to another place today
Luckily they didn't charge me for the test
Old 06-07-2014, 05:52 PM
pmed
Old 06-07-2014, 06:28 PM
thisaznboi88's Avatar
You wont pass unless u "accidently" lose 200 in their shop
Old 06-07-2014, 07:10 PM
sockr1's Avatar
Confused. What do you mean?
I'm hoping it just barely didn't pass and going back to the oem cat will put me back in legal limits
Old 06-07-2014, 07:42 PM
Pay them 200 under the table. You only fail cause of visual. Not cuz it can't pass the sniffer
Old 06-07-2014, 08:34 PM
pohljm's Avatar
easily passed each time with my Pro Cats
Old 06-07-2014, 09:42 PM
sockr1's Avatar
Pm'd
Old 06-07-2014, 10:07 PM
Your still going to fail visual unless u pay someone. They know its not OEM because no heatshieldnd no CARB OE#
Old 06-07-2014, 10:46 PM
visual is not a problem here in LA. A lot of techs will look the other way. However, rigging the sniffer to pass will definitely be extra $$$, about $200 as thisaznboi said
sockr1 is saying rv6 hfpc, xlr8 v1 jpipe, and xlr8 hfc wont pass the sniffer. are you disagreeing?
Old 06-07-2014, 11:17 PM
sockr1's Avatar
I just checked my oem cats and they have no visible casting or stamp mark that says they are oem. At least nothing is visible with the heat shields on and I know these techs do not take off our heat shields in the 15 min it takes to do the smog test
Old 06-07-2014, 11:33 PM
I@paperboy yes I am disagreeing that u will not pass smog if u have all high flow precats. It will be on the high side unless they changed the machines again. What u need to do is go out on a lot run and get those cats extra hot, it helps speed up the catalyic process. If you had pcd then that's another story
@ sockr1 Problem is you have no heat sheild that's a dead give away they are not stock.
Old 06-08-2014, 01:33 PM
iWhine
H23Accord's Avatar
Does the heat shield not fit around the PCD/HFPC? If not, is there a way to make them somehow fit?
Old 06-08-2014, 07:27 PM
so it will pass only if its warmed up really hot? thats interesting...
Old 06-09-2014, 02:11 AM
iirc werent the pro cats 300 cell on the main precats? i think rv6 v3 is 200 cell....i could be wrong though
Quick Reply: Any Cali people passing smog with HFPC
