Aftermarket drl projects defect or hid bulb
Acurazine Members,
I have the Acura TL LED Signal DRL Projectors Headlights (PRO-JH-ATL04-DRL-BK) installed on the Drivers Side and the OEM on the Passenger Side. Noticed the vertical light output on the Drivers Side above the cut-off lines which is not there on the Passenger Side. Because of this, I have decided to forgo installing the Passenger Side DRL Projector until this issue is resolved.
Please share your thoughts on whether the below image displays a defective headlight? Initially, I was going to replace the HID bulb, however, I don't think that would resolve the problem. Could it be something inside the HID compartment defecting the small amount of light upward?
Thank you, and looking forward to your thoughts.
Yup i wouldn't be happy with that..
https://www.google.com/search?q=squi...wrV-hyrVNVmivM
In the headlight retrofit world, that leakage is known as "squirrel finders"
Slpr04UA6 (01-20-2021)
Thoiboi,
Thanks for the insight. Did not know about "squirrel finders". Must say I learn a lot from this forum. Because others from the forum has installed the DRL Projectors attached below with no reported issues, I will try to re-aim the Headlight to see if that resolves the problem.
The following 2 users liked this post by wlbolton:
noturmothersua7 (09-22-2021),
Hate the amount of leakage on the 2G MDX, 3G TL has the best projectors I've seen and most aftermarket units can't compete.
The following 2 users liked this post by csmeance:
pohljm (01-30-2021)
Sempiternal94
01-19-2021 12:46 AM
hondeducation
12-22-2017 02:37 AM
