Accurate J series engine weights
Brock
Reference info here for those that are interested...
I weighed a J37A2 and J35A8 (what I have on hand) and thought it would be useful for others to know. Both engines were identically equipped, but the J37 might have had a bit more coolant in the block. Both engines still had oil in them. A few things to note: both of these engines have magnesium valve covers; the J37 does not have iron cylinder liners, but it has extra valvetrain hardware to accommodate full VTEC.
Engine assemblies minus:
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
![](http://www.brockwayengineering.com/pics/j37_engine_2.jpg)
The following 4 users liked this post by Euro-R_Spec_TSX:
Acura TL Builder (06-20-2020),
paperboy42190 (07-07-2014),
Richie v6 (07-07-2014),
smcafee (01-14-2022)
Brock
I also weighed a TL Type-S manual trans, no gear lube and no release bearing: 103 lbs
The following 2 users liked this post by Euro-R_Spec_TSX:
Mustafa Muhammad (06-20-2020),
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
Intake manifold
Exhaust manifolds
EGR valve
Flywheel
Engine mounts
Wire harness
All accessories
J37A2: 298 lbs
J35A8: 296 lbs
Brock
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
09-15-2015 06:44 PM
