Notices
4 inch CAI
Old 04-09-2019, 06:10 AM
  #161
Liked 13,884 Times in 10,314 Posts
^anything carbon fiber is custom made.
justnspace is offline
Old 04-09-2019, 07:40 AM
  #162
Registered Member
horseshoez's Avatar
Liked 808 Times in 602 Posts
Originally Posted by 3gtltypes View Post
Where are you finding the 4" carbon? Just pulled the trigger on the 3.7 TB and Mani swap. Are there any kits for cai? Amongst my search, have only come across a guy who makes sri kits.
Your car came from the factory with a CAI, so you're good to go there unless you want more noise. A Short Ram Intake (SRI) is often called a Warm Air Intake; no thanks.
horseshoez is offline
Old 04-09-2019, 08:45 AM
  #163
Registered Member
Liked 1 Time in 1 Post
I agree with you on "no thanks" . Since I'm going with the bigger throttle body I won't be using the factory CAI. Deciding on using the AEM V2 since it has a port for the IAT move.
3gtltypes is offline
Old 04-09-2019, 11:06 AM
  #164
2005 SSM 6MT
EvilVirus's Avatar
Liked 1,072 Times in 853 Posts
EvilVirus is offline
Old 04-09-2019, 04:24 PM
  #165
Registered Member
horseshoez's Avatar
What are you expecting from a larger throttlebody and intake? Is the rest of the engine and the exhaust also heavily modified?
Old 04-09-2019, 09:16 PM
  #166
Rotrex + Comptech TLer
Saving4aTL's Avatar
Liked 99 Times in 87 Posts
Big TB for make the vroom vroom!
I remember a guy named KingkongDave(or a variation of) who installed a Comptech Supercharger onto his TL and was planning to install a 4” CAI. He said O’Reillys(or Vatozone) had a “Piece-it-Yourself” aluminum intake section.
Do you think that would help? I suppose 3+’ of 3” intake piping would be restrictive when the S/C is spinning north of 5k RPM.
Saving4aTL is offline
Old 04-10-2019, 06:19 PM
  #167
Registered Member
Expecting around 10hp increase with larger mani and tb. Lower intake runners will be ported and polished when installing mani swap. Exhaust is Tsudo catback quad titanium burnt tips and OBX pcd's and j pipe. Do you suggest a different cai. I figured since it's going to breathe better then why not go with an aem v2. Topping off all mods with a hondata flashpro.
The following users liked this post: 3gtltypes
6spd-GERCO (04-11-2019)
Old 04-10-2019, 07:48 PM
  #168
Saving4aTL's Avatar
Crank or Wheels?
Old 04-10-2019, 07:55 PM
  #169
Registered Member
Originally Posted by Saving4aTL View Post
Crank or Wheels?
I have a choice?.... In that case put it to the wheels please!!
Old 04-10-2019, 08:12 PM
  #170
Registered Member
horseshoez's Avatar
Maybe it's just me, but that seems like a heck of a lot of money and effort for a measly ten horsepower.
Old 04-10-2019, 08:28 PM
  #171
Registered Member
To each his own. Basically heavily modding piece by piece. I'm not too loaded. But have enough to play with. Swapping the mani and tb is pretty effortless in my opinion.
Old 04-11-2019, 08:24 AM
  #172
Saving4aTL's Avatar
Would a 5” make 15whp?
Old 04-11-2019, 09:15 AM
  #173
Registered Member
If it helps you on your goal of 200mph then go for it. Good luck. Don't forget to remove the govenor...
Old 04-11-2019, 12:27 PM
  #174
Registered Member
6spd-GERCO's Avatar
Liked 333 Times in 223 Posts
That's a good plan! It doesn't hurt to get a larger induction path for your TL. You can pick whichever CAI is easier for you to tackle, build one or buy one off the shelf.
6spd-GERCO is offline
The following users liked this post: 6spd-GERCO
EvilVirus (04-11-2019)
Old 04-11-2019, 12:30 PM
  #175
Registered Member
horseshoez's Avatar
I guess that depends upon how you define the phrase "not hurt". While a huge intake will physically do no damage to the engine (assuming proper filtration), such a large intake will very likely harm mid-range torque.
Old 04-11-2019, 12:51 PM
  #176
Registered Member
Liked 82 Times in 68 Posts
I think it all depends on your modifications. If the engine and exhaust is stock then yes the stock intake is best option. For guys that modify the exhaust, intake, tb and so on a bigger cai is a good option especially with a new tune. Theres a number of dyno sheets that can show that. Yes possible loss of torque but up top there are good gains.
90foxnotch is offline
Old 04-15-2019, 12:41 PM
  #177
Registered Member
6spd-GERCO's Avatar
I really don't think going large size intake prior to the TB will have a negative impact. It's changes to the intake manifold design that would move the power around, intake runner lengths. TL can switch between a long intake path to a short path to take advantage of both, but for a track car a shorter path is favored for high rpm use.
emailnatec
29
09-28-2018 04:27 PM
ttimberlak443
21
10-22-2016 10:23 PM
InFaMouSLink
10-30-2015 09:43 AM
h22lude
Third Generation TL (2004-2008)
09-27-2015 06:22 PM
johnpancakes014
09-27-2015 12:58 PM
Quick Reply: 4 inch CAI
