4 inch CAI
#81
I'll have another one on the dyno. It'll be on a car that is nowhere near stock however. I know modified J30A5's are starving for air, I'm sure your 3.2/3.5's are as well. I can make 3/3.5/4 inch intakes.
I hope to have a dyno within this month, but i really don't know when to expect it.
#82
Actually that would be amazing. I'm not sure how fitment will be with the fog lights. I've ordered all the parts I need and I hope to have them all by Friday. Would you be available Saturday?
#83
I'm going to be in Roanoke tonight to get my Halo 4 copy out of Valley View Mall.
#85
From what I can tell it is on par with the aem v2 til about 4k rpm. Since you guys have a bigger engine, I think it will be less of a problem for you guys.
#86
#87
UPDATE
So I have made an intake that would work for you guys that do not have the IAT relocated.
You would get what you see in the video plus a filter.
https://www.youtube.com/watch?v=XU9_RUTuxhE
Let me know what you guys think!
#92
iWhine S/C 6MT TL
what you need to make is a custom one for those that have superchargers
#93
Sonnick (11-29-2012)
#98
All motor
For those with the 3.7 manifold this is a must!!
#99
takin care of Business in
Received 4,732 Likes
I concur !!! 4" Intake FTW !!!
NvrDwn (11-29-2012)
#101
All motor
^ You are going to need the larger TB/IM to take full advantage of the 4in CAI. I know you said you would be able to make 3.5in CAI's as well. That may be better for the stock IM/TB. Not fact, just my opinion.
#102
^^^ I would highly recommend that....give the customer couple options...
so have a 4" option and have a 3.5" option....recommend a filter size but do not sell filters, let that be the customers responsibility....some like KNN some like AEM and other love Ebay...
#104
As far as the filter goes I can supply any filter. Depending if you want one, and what filter if you choose to get one, would determine the price. This is a totally custom intake, even down to the color of the couplings and filter if they decide they want me to include one..
#105
^^^ couplings I understand....but some people want a bigger filter, other want to stick with a smaller filter....my point is since you wont be stocking up the filters, just sell the piping and keep items shipping ready....
a lot of members in the forum like seeing their orders within couple days of paying....by the time i pay and you order my filter and you receive it, pack it and ship everything to me, thats 2 weeks right there....
then if AEM is out of stock on a particular filter, you just received a bad rating
i have seen it happen many times....look up the JnR thread....it has everything that can go wrong for a vendor with potential in there
#106
EDIT: I will add that if I get a lot of business with this then the wait will not be as long. If I eventually get 15+ a month I will stock a head of time knowing they will be bought which will cut at least a week off.
#109
This thread makes me want to start producing intakes again... 3.5" and 4" I was using all Vibrant products except I was using the Blox Velocity Stack Filters. There wasn't an interest in this when I was planning production of several of them. :-(
#110
Honestly I'm not yet sure there is enough interest to do this yet because most people that will want the 4" will be heavily modded, which there aren't a lot of people who are. There is no prof that a 4" cai makes more power than the aem on a stock car. If there was I would imagine there would be a ton of interest as it would be the best gaining cai and cheaper than the aem.
I'll say this again, if there is someone with a stock TL or TL-S that wants one shoot me a message.
#112
blah!
I have a noob question..
I have a stock intake.
I haven't bought a CAI because most of the guys here agree that a cold air intake doesn't give much or any gains, its more for the noise and rice factor.
So what is the difference with this cold air intake? Will the extra airflow bring real gains?
Tryin to learn here.
#113
now this only works until a certain level....another point is that you want the intake and the exhaust to be as free flowing as possible....
imagine you are out for a run and your nose is choked with sinuses....its harder for you to breath and hence your system has to work "harder" to get power out....similarly you want the intake and exhaust track of your car to be as free flowing as possible so the engine can breathe well and hence generate the power more efficiently....
now add to this the funda that cold air burns better that warm air....since the engine is sooo hot that warm/hot air fuel mixture in the combustion camber can at times burn before the spark from the heat in the combustion chamber....because of this the the ECU retards the spark timing and hence robs you of the power....
when you look at all these together....what you want is more air and cooler air into your system....a lot of us have upgraded to a better flowing and lightweight 4G SHAWD manifold and throttle body.....this allows for more air available for combustion....because of this, we need a bigger intake....hence the 4" intake....
if you put this 4" intake on a stock TL, you might not end up gaining any power as your stock diameter Throttle body restricts the amount of air entering the manifold and the bigger intake will reduce your intake velocity which you want to keep as high as possible...
hope this will help you understand the full intake scenario
NvrDwn (11-30-2012)
#114
#115
blah!
Thanks for the answer swoosh! Clears it up. I don't plan on (at least not yet) on getting the 4G intake mani and throttle bottle. (btw what are the gains on that? and won't the car run too lean without a tune?)
I just slapped the preorder on the RV6 true dual and will likely be picking up the RV6 V3 Jpipe and HFPC soon. I've been debating if I should get a cold air intake or stick with my stock box. It seems as though most people agree that aftermarket CAI with the stock throttle body does not give many gains because the stock air box is already very efficient.
#116
the car has a fixed CR/AFR which is runs on....no matter how much air you give it or how much fuel you adjust its not gonna gas AS MUCH until you tune it....
you will not run lean...nor will you run rich on a OEM ECU/map...only once you have an aftermarket tune is when you run into rich/lean issues....the only time you will run lean is if you have a upstream o2 sensor messed up....that does all the trimming....
there has been a lot of debate on the CAI....i love mine....even when I had the AEM CAI, i loved it....the car did feel a little bit quicker on the throttle response and i loved the growl from it....
if I had to do it all over again, i would buy the CAI....
#118
^^^ as I said you can if your upstream O2 sensor "modifies" the map depending on how you are running....
but with just bolt ons, i doubt you will run very rich or very lean....you should be between upper 12's/lower 13's at WOT and 14.xx at idle/normal driving....
then again, am speaking from experience....I have every bolt on possible and my AFR gauge reads between these figures
#119
There are several fundamental things that are never brought up in these threads.
The old saying is "leaner is meaner" which holds true most of the time. If leaner brings detonation with it, you lose power. Turbo cars run richer to bring the high combustion temps down and to help prevent detonation when there's already tons of power to spare. The TL does tend to run on the lean side at part throttle but in vtec I don't see why anyone would ever want to add more fuel to the fire.
The single biggest restriction is important but it's the sum of all restrictions that determines total restriction so even though the throttle body is the largest restriction, anything upstream of it that causes restriction hurts power.
On the flip side, if there is no restriction with the typical 3" CAI you're going to get zero gains with a 4". Someone throw a sensor in there and measure, I have.
More power needs more air. I look at CAI and exhaust as supporting mods. Give the engine what it needs for the rest to work well. In this case, a 4" may only be beneficial on the larger 3.5l or 3.7l or highly modded 3.2s where airflow requriements are increased.
From years of testing, the taper from the 4" pipe to 3" (or less) throttlebody is the single most important part of the CAI system. It needs to be a slow taper, not a 45 degree taper.
The colder air you get into the CAI, the more air you're getting. Cold air is denser so you can fit a larger mass in a given size pipe. Cold air is the same as fitting a larger pipe except you're not just able to get more of it thorugh the CAI, you're fitting more air through the intake manifold, through the intale ports in the heads, and into the combustion chamber where it will be less succeptable to detonation. This is another reason why a SRI has no place in a TL unless you consider a pipe with a filter near the fender well a CAI, then it works.
You guys focus way too much time and energy into CAI systems. Just throw something on there that picks the air up somewhere, anywhere outside of the engine bay and make sure it's large enough to not cause restrictions and call it a day. It's so damn easy to have a non restrictive CAI and never have to worry about hydrolocking or air filter life but no one ever does it. I'm seriously thinking of making a CAI the right way and selling it.
kjelly (12-04-2012)
#120
Before I had the 3.7 manifold/TB I was running hella rich at 11.6 with all my exhaust mods. Once I went to the larger intake manifold I leaned to 12.3-ish
