3G light flywheel for 6 speed TL?
I bought a stage two clutch a couple months ago, now I need a light flywheel. Does anyone just sell a light flywheel and not a kit or just a clutch. Also I'm not trying to break the bank either. Thanks
Originally Posted by callahan
(Post 12732588)
luk stage two clutch
Luk stage 2? There's no such thing. Luk is the OEM manufacturer for our clutches, as well as many others. Where did you buy it?
SPEC has a lightweight flywheel, as does AASCO. They are both about $550. No other options are available at this point. You can buy the CM kit, which is a FULL kit, or there is another kit on this forum from J&R performance. |
Hmm I'll double check which clutch I got when I get home.
I have a Kevlar stage two Clutch, is it possible to buy a different brand flywheel and use it with it? Also have you guys ever heard of Kevlar are they any good?
The ThunderHill Racing TL used a CL-S Comptech Lightweight Flywheel...
I was wrong it a Phoenix Friction Clutch Kit.
Oh I saw that company online. They actually sell stage 1/2 for us. Idk how much I trust them though...but let us know how it works!
Search lightweight flywheel there's only 1 or 2. I'd get the AASCO as they are used with the ClutchMasters kits. |
Does the TL have a dampened flywheel? If so, you may notice some clatter at idle with a new flywheel. How light are the they? Too little and you'll get sick of getting the car rolling from a stop.
I look at one awhile ago I believe it was 12lbs, will any flywheel work with that clutch or am I sol?
