3.7 Acura TL SH Intake Manifold!!!!
#41
All motor
I haven't seen anyone with the ZDX throttle body yet, but had I known it was cheaper and was compatible I would've 100% bought it instead. I would've saved $200. That could've went towards my new intake lol.
Let us know how you make out fenda. Definitely excited to see some more people do this swap. And I agree with ANX, definitely do ported/polished runners as well. With that said, you may want to gasket match the new manifold to the OEM gasket since the ports are ~1mm smaller (I believe they were 43mm when I measured the lower TL ports). The gasket matched PERFECTLY with my polished runners, so now the transition from IM to lower runners is smooth as glass.
#42
The Track Terror
Sonnick (09-21-2012)
#43
All motor
I'm not sure what I'm gonna do with the intake yet. I think I'm going to use AIRAID. Someone linked me on V*6*P and it seemed pretty legit. Still undecided on whether I'm doing 3.5" or 4". I'd rather not have to squeeze the piping/filter in for the 4", but I do want the most power...not sure yet. I'm assuming a larger intake will make at least another 5-7whp on my setup.
#46
takin care of Business in
Received 4,732 Likes
sub'd LOL
#47
Still don't see this as being a good idea unless someone can prove otherwise. I just see excess turbulence when the intake is considerably larger than the TB opening, thus slowing intake air velocity. It'd be a different story if we were dealing with a 100 mm TB. Excess turbulence is what causes VQ cars to lose power with an aftermarket intake. I think the TL might escape this issue though since it's speed density rather than MAF, but bigger still isn't necessarily better. 3.5 should be ideal.
#51
I see recommendations for the ported runners, and what about the manifold (3.7 swap) , sure port match but what about a full port and polish?.... Overkill? I I just ordered my parts and just trying to figure it out.
hondazex (09-23-2012)
#55
All motor
I have to assume a 4" will work for these cars. The K series, H series, and even B series have all seen gains going from a 3" intake to a 3.5". I can see the J gaining some power with a 4".
#57
^^^ the problem with a 4" intake is that it wont fit through
I know Andy made it fit but cutting the pipe/various bends/couplers and making it fit but i just dont see any metal pipe which will fit as a direct bolton
#58
All motor
Hmm. I'll have to ask the guy on V*6*P take some pics. He said the 4" AIRAID tubing fit in his fender. Seems to be a good product. Won't get as hot as the aluminum
#59
^^^ wrap your tool
wrapped alum intake = lower intake temps
hondazex (09-24-2012)
#60
All motor
Lulz. AIRAID isn't aluminum ftw
#61
#63
All motor
^ I bored out my TL throttle body to 81/72mm. It's definitely worth it. These motors love air and the more you give them, the more power they make.
NVA-V6 is making a dual TB setup that will surely outflow the 3.7 manifold/TB. He hasn't dyno'd it yet, but it looks promising, especially for the 3.5-3.7 guys.
#64
Sonnick (09-27-2012)
#66
^^^ THIS
now i feel like an idiot arguing with IHC about it
#67
^ Who said there are no gains? Check my graph below. Keep in mind my stock manifold was ported before the upgrade. Only differences are the 3.7 manifold/bored 3.7 TB/polished runners. Oh, and I left the butterfly valves in on the 3.7 manifold. Definite lost low end with them out between 2.5-4K. This is still on my AEM V1 CAI, which is 3in...smaller than the TB.
Damn I would have love to see a sae CORRECTED dyno of before and after
#68
All motor
^ That's exactly what my dyno shows. Both runs were SAE Corrected.
#71
From all the runs I made on winpep software dynos since 1998, the applied sae correction factor was marked at the end of the run names like on my last runs with latest winpep 7 software:
http://i1108.photobucket.com/albums/h405/DomGSR-T/DynoTL-SPart2.jpg
Smoothing lets you to show six different levels of
detail in the graph. Level zero shows the most detail
while level five shows the least detail. Level three is
the default setting. (-----taken from winpep pdf.
So maybe there's a way to show or not the temp/humidity/pressure/sae correction in the run names. That must be why it don't shows on your dyno. I just thought all winpep7 were the same.
#72
All motor
If you're talking about CF, I have that as well at the bottom of my sheet. My pic didn't get it. I can post it if you'd like, I believe the 'before' run was .96 and the 'after' run was 1.03. It was much hotter and humid for the after run, hence the CF. it was something like 65 degrees with minimal humidity compared to mid 90s and 40% humidity.
#73
#75
All motor
Not sure why the same question (answered more than once already in this thread) keeps popping up. Thankfully there wasn't another thread started about it, but jeez....does anyone do research on their own anymore? I loved researching about the Venturi collector when I was doing my exhaust, and keep doing research with each part. It's part of the fun!
justnspace (09-27-2012)
#76
^lol why do you think IHC's doesnt post in the performance section any more!?!?!??!?!?!
lol because PEOPLE SUCK and dont know how to read.
Butt, i bet they'll read that and get angry at me.
*edit
I do thank you, Sonnick as I've learned a lot from you.
keep up the good work and push for 300 on that little 3.0!
*edit
The following 2 users liked this post by pearlUA7:
justnspace (09-27-2012),
#78
but seriously now, 3 and a half years ago racinghart03 installed and removed, said it wasn't worth it. that was over three years ago and the parts werent on for longer than a day. im already committed to this swap but just want to know which one is it, worth it or not. there are talks back then bout losing too much at the bottom, talks now how a full 3.7 pnp along with runners and a bored out tb is way to go. i leaning towards goin all out but am still conflicted with old news. can someone shed some light please. stillhere, justinspace, etc (azine veterans) just a plain yes or no would be fine, 3.7 swap fully modded (ported runners, matched and pnp mani, bored tb)?
#79
All motor
Thanks Justin. I've learned from you as well We'll see about that 300......
#80
I concur with mr crabby....i wish people read a little more and not only on this section but also in other parts of the forum....they still create threads with "where do i buy switchbacks" and "whats the best CAI"
Dom, Sonnick is legit he is not a guy who bloats numbers....i trust him
