2007 TL Type-S Luk replacement parts
Apparently the Clutch Masters light weight flywheel needs to be sent out to have the ring gear replaced with the stock one for it to work on my 07 TL-S 6MT... Seems like a lot of trouble to go through so ill probably just be going with the stock Dual Mass Flywheel.
Ive been doing tons of searching on the Luk OEM flywheel and cant find any of them for sale. I believe the part number is DMF105 and here is a link, but they dont have them for sale... http://www.oemclutch.com/product/luk...l-6-cyl-dmf105
Anyone know where to get the Luk replacement dual mass flywheel?
Thanks in advance.
Thanks in advance.
so im assuming this wont fit my vehicle, correct?
http://www.carolinaclutch.com/ShowIt...0Flywheel.aspx
not sure since your a TL-S. seems like you have different teeth count on the flywheel from what you were saying in the first post. I am using a CL-S fly wheel, but that only works for accord and TL base. I never seen anyone do a clutch job on a type-s with it yet.
Anyone with a TL-S ever use that Clutch Masters light weight aluminum flywheel yet? Ive heard that you need to swap over the gear ring from the stock flywheel to this upgraded one and just wanted someones advice/help who may know more about this...
I found this for the 07-08 Type-S Im going to call them to see if its the same part you would buy from Acura Dealer.
Desert Life Sucks!!
I am looking at the clutchmasters aluminum flywheel for the Type S.
Not excited about the 700 price tag but at least it is rebuildable down the road.
1400 clutch set is better than a 2000 acura job.
SUPRMN84
09-02-2015 11:50 PM
