'08 TL-S Steering rack in Base 04 TL Auto.
Ok well I don’t have Pic’s or anything but I do have Info for any of you Base TL owners out there not liking the lose sloppy feeling in your Steering. I just had an 08 TL Type-S Steering Rack put in my 04 TL Base auto and that is all gone and in it’s place a nice tight Steering I had an 08 Rack with all the Tie Rods and Tie Rod ends put in and was a 100% swap.
bluetl04 (01-28-2022)
You will love it I tell ya why could they not make it like this from day one.
Here is what is new with the 07/08 Rack
STEERING
The TL uses torque-sensing, variable power-assisted rack and pinion steering. The engine-driven variable-output pump provides the kind of steering feel that driving enthusiasts like: modest steering effort at low speeds and precise feel at higher speeds.
For 2007, the TL Type-S receives revised power steering pumps and steering gearboxes to improve steering effort build and feeling while maintaining a confident and stable feel. To this end, the power steering pump has been retuned for decreased flow at 3250 rpm for increased effort build up. Additionally, the steering gearbox tuning increased effort by 15 percent at high speeds for better on-center feel. The rack has also been retuned for better damping feel. To keep up with the demands of spirited driving, the TL Type-S also features a new aluminum power steering fluid cooler.
Hydraulic steering dampers built into the system further improve stability during cornering and at high speeds. A one-way kickback valve decreases kickback to the steering wheel that can be caused by road irregularities. The hydraulic valve closes when it senses road irregularities, impeding disturbances to the steering wheel.
Increasing the stiffness of the steering gearbox mounting and the rear sub frame also maximizes steering linearity.
The following 2 users liked this post by Anarchy919:
Midnight Mystery (02-05-2021),
paperboy42190 (01-08-2013)
Oh wait you said 04 TL auto... is there a difference between that and an 06 6mt, and then even more of a difference between the 07 TYpe-S steering rack? How was install? TOugh? I got lots of questions cuz I never thought about this, and it seems daaaamn interesting, especially since I'm toying around with getting S/C in my mind.
And that is just what the Base needs, it's steering has no feel to it and when you turn the wheels it's slow to turn and respond and on top of that you add milage to it and you get a very unresponsive car good time to put in an 07 to 08 TL-S rack like I did.
It will work for you and I tell you after driving my car all day today there is nothing bad I can say about this Mod, It would have been nice if I had done this Months back there are 100% no issues with it at all.
TEAM_SONIC
They said my steering rack was an issue when I went to Town Fair Tires to do a changeover for my wheels for the summer. Will there be any problem if I do this mod? My car is an 04 TL Auto. BTW the link you provided did not work. Can you please provide me a link to where you bought the item? Any additional item I have to buy besides the steering rack? Thank you.
Also on a side note I also put in the 08 TL-S power Steering pump but you don't need it. I did it couse over 3250RPM's it cuts back flow to make the Steering harder at higher speeds.
But if you can't find a TL-s rack at a good price I still have my Base Rack you can have for $100+Ship
Yes auto or MT will work for all years from 04 to 08 all the cars use the same Rack it's just the inside ratio that was changed but how it mounts to the subframe are all the same. All TL-S Racks from 07 to 08 are the same Auto or MT. You just need an 07/08 TL-S Rack and you can also do the Power Steering pump if you like.
6-SPEED LOVER
thnx bro
^ He said you wouldn't need to but he did b/c the PS pump for the type-S has some kinda of cut off at higher speeds. I'm assuming it gets 'less' sensitive at speed for more control. Correct me if I'm under the wrong assumption.
Na you correct it slows down flow at 3250RPM for a Firmer feel at higher speeds and I have tested it and you can feel it. But anyone that can't buy a TL-s PS pump you can use the one in your car now I drove on the two of them and there is no diffrence below 3250rpm's they feel the same it's that 15% flow cut after 3250.
OMGWTF4THGENTL
So this is a great post... I too have noted my 2006 has the steering response of an Oldsmobile, and I also noted the stiffer, more responsive steering of the TL-S during a test drive. Good to see this is a relatively bolt on upgrade, other than you have to drop the subframe to get the rack out.
I'd reccomend upgrading to the TL-S FSB during this install, as when the front subframe is down is the only way to get the FSB replaced as well.
So here's a few Questions:
How does the pump do this? Is ths ECM controlled or just RPM driven? What I'm asking is there any link to the car's brain for this function to work, or is it purely mechanical in the pump. I'd for folks to install the upgraded pump and have these updated functions be controlled by an ECM that doesn't exist in our car.
Did you do the cooler? Any plans to?
I assume these are all functions of the new "rack"? I think this feature exists in our racks as well...
If the new rack is a direct bolt on, where/how are these reinfocements made? And what about the rear subframe? What's different, where are these reinforcements?
Looks like a great mod, I'm just wondering how we get all the intending handling upgrades...?
OMGWTF4THGENTL
FYI... The tubing difference seem a bit different, wondering if the PS cooler can be bolted on as the seem to terminate in the same place...
2006:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
2007 TL-S
2006:
2007 TL-S
Second the pump has a tuned Spring in the flow valve that cuts back flow along with the valve.
next up is the improvement comes from the change in the Ratio in the Rack and the 15% increse in Steering stiffness.
Next is the Dropping the Sub from it was not lowerd at all once the lines and 4 bolts are out of the way it comes out from the drivers side wheel fender shop Charged me 2.8hr to put it in by the Book.
I did the FSB at the time it was put in Rack came with it.
If you need any info you can call me I'm kicking this and that around as things to do to my car.
407-242-2712 Luis
If you look up the part numbers you will see they are not the same the Base 08 TL was set up for a nice soft ride and the TL-S is set up for a Performance stand point. But they are close as I did the same thing when I was thinking of doing the Rack Mod drove an 08 Base and then drove an 08 TL-S.
The steering really isn't as bad as everyone is saying, then again I don't remember how my car handled stock...but it really isn't THAT bad. Its still firmer than the Lexus IS350 I test drove, and after driving a loaner 09 Altima 2.5S for 3 weeks, I can safely say you can't even begin to compare the two. Get into and Lexus or Mercedes, then talk about numb steering I swear, it felt like there was nothing attached to the steering wheel in the IS i drove, kind of like those wheels they used to have at playgrounds.
With that being said, there is still room for improvment. I might try this mod out....but that damn PS pump is $265 alone! The steering column is $209...I wonder if you have to install the radiator with the PS pump...
